Confused about indexing into lists...
11-05-2017, 01:36 AM
My understanding was that in CAS mode, lists should be indexed using square brackets to avoid confusion with function calls, so I tried the following....
L1:={1,2,3,4,5,6,7,8,9}
When in Home mode, I can type L1(3) or L1[3] and I'll get 3 back....correct...both braces work.
Now, go to CAS mode.
L1(3) works and returns 3...so next I tried the square brackets...
L1[3] gets converted to at(L1,2) and {1,2,3,4,5,6,7,8,9} gets returned??????
So, then I typed...
at(L1,2) and it returned at({1,2,3,4,5,6,7,8,9},2) ????
So, what am I doing wrong?
11-05-2017, 02:17 AM
RE: Confused about indexing into lists...
(11-05-2017 01:36 AM)webmasterpdx Wrote:  My understanding was that in CAS mode, lists should be indexed using square brackets to avoid confusion with function calls, so I tried the following...
Almost. Use () with all home variables and objects.
TW
11-05-2017, 03:08 AM
That's confusing. How does one know if a variable passed into a program is a CAS or Home variable?
11-05-2017, 03:27 AM
So you're taking arbitrary input into your program and not checking type or what the user gave you before attempting to do something to it?
TW
11-05-2017, 03:57 AM
Hmm....if I pass in a home list to a cas function as a list, it gets converted to a cas list and can be addressed with []. So I guess that solves that problem.
It's still pretty confusing though (from the command line).
The other thing that really bugs me is if I am looking for a function that is a cas program, it should be accessible from the toolbox menu, under the USER submenu, like the home functions. It's pretty disconnected to have the cas ones under the variables-CAS-Programs submenu....
