Bug? Tricky syntax? Finding items in a list
11-03-2017, 03:28 PM (This post was last modified: 11-03-2017 09:16 PM by StephenG1CMZ.)
This program is meant to find the positions of items in a list.
A simple FOR loop, yes?
No, it has problems if the list contains lists.
It gives a Bad Agument Error...unless you insert a diagnostic print, in which case the inner list is printed, and nothing after that.
 EXPORT ListFIND(LST,ITEM)
 //Find all instances of ITEM
  LOCAL II;
  LOCAL LSTPOSNS:={};
  PRINT();
  IF SIZE(LST) THEN //
   //LOOP COULD BE OPTIMISED BY USING POS TO LEAP TO NEXT MODE
   FOR II FROM 1 TO SIZE(LST) DO
    //THIS LOOKS EASY BUT FAILS IF LST CONTAINS A LIST
    //EG ({1,{},3,4},3) BAD ARGUMENT TYPE
    //BOTH EQ AND == FAIL
     //WITH PRINT:NO II=3 PRINTED
     //WITHOUT PRINT: BAD ARGUMENT ERROR
    //PRINT({II,LST(II)});
    IF EQ(LST(II),ITEM) THEN
     LSTPOSNS(0):=II;
    END;//IF
   END;//FOR
  END;//IF
  //Return Positions that match ITEM
  RETURN LSTPOSNS;
EXPORT FINDER()
  MSGBOX(ListFIND({1,{},3,4},3));
Example: Find({1,{},33,4},33) should yield {3}
But (1,{} ,3,4},3 fails.
Stephen Lewkowicz (G1CMZ)
List API V1.1: http://www.hpmuseum.org/forum/thread-9411.html
11-03-2017, 03:53 PM
RE: Bug? Tricky syntax? Finding items in a list
  LOCAL II;
  LOCAL LSTPOSNS:={};
  PRINT();
  PRINT("List: "+STRING(LST));
  PRINT("FIND: "+STRING(ITEM)+"\n");
    IF TYPE(LST(II))=TYPE(ITEM) AND EQ(LST(II),ITEM) THEN
      LSTPOSNS(0):=II;
      PRINT("Pos: "+II)
    END
  RETURN LSTPOSNS;
Viga C | TD | FB
11-03-2017, 04:19 PM
This is a little faster
EXPORT ListFIND2(LST,ITEM)
  LOCAL X,Y;
  LOCAL LSTPOSNS={};
  WHILE X:=POS(LST,ITEM) DO
    LSTPOSNS(0):=(Y:=X+Y);
    LST:=LST({X,SIZE(LST)}+1)
  RETURN LSTPOSNS;
Viga C | TD | FB
11-04-2017, 07:01 AM
There are 2 list libraries in the software libraries that you might find useful. The first is an extension to the list functions, and the second (which uses the first) is for associated lists (content addressable memory). Both are linked to from the Programming Documentation section of the wiki here...
http://www.wiki4hp.com/doku.php?id=prime:start
Here are the 2 links...
First is the Programmer's Expanded List Library...
http://www.hpmuseum.org/forum/thread-700...light=list
Then there is the Associative List Library...
http://www.hpmuseum.org/forum/thread-909...light=list
11-04-2017, 09:36 AM (This post was last modified: 11-04-2017 09:38 AM by StephenG1CMZ.)
(11-03-2017 04:19 PM)Carlos295pz Wrote:  This is a little faster
  LOCAL X,Y;
  LOCAL LSTPOSNS={};
  RETURN LSTPOSNS;
Yes...Actually, I see that as about 6 times faster, not just "a little".
I will include that version in my List API if I may.
11-04-2017, 09:42 AM
The +1 is a very nice trick !
