Can the name of the MODE function be changed? (Statistics)
10-29-2017, 09:02 PM (This post was last modified: 10-29-2017 09:16 PM by StephenG1CMZ.)
I was trying to look up some way of finding the .mode of a list: Statistically, the most common item(s) in the list.
I found 16 pages of threads about Home mode, CAS mode, Exam mode, and many Interesting threads that I might re-read, but not a single thread about MODE.
Perhaps the HP Prime cannot calculate MODE - or perhaps the absence of any threads about it means everyone else uses it without problems, despite not being in ToolboxMath/Lists.
It would help if the function could be called something's else in the documentation ("statistical-mode" perhaps), to simplify searching.
Similarly, pdf usually refers to document files, not density functions. And while I am complaining, most computer languages use INT to refer to integers, not integration.
(If you are wondering why I don't search the pdf - on Android the phone dims after a couple of pages, and when I restart it, the phone has forgotten that it was searching, which gets VERY tedious).
Stephen Lewkowicz (G1CMZ)
10-29-2017, 11:41 PM
RE: Can the name of the MODE function be changed? (Statistics)
If this question is about the Prime, suggest you request a mod move it to the Prime sub-Forum, you'll get more (and better informed) opinions there.
10-30-2017, 07:36 AM
Making MODE easier to search for in documentation by calling it statistical--mode applies everywhere.
As for not finding it on the Prime, I have now written my own.
10-30-2017, 10:30 PM (This post was last modified: 10-30-2017 11:41 PM by Didier Lachieze.)
Here is how I would do a statistical mode function, I don't know how different from yours it is :
EXPORT ModeList(L)
 LOCAL l1,l2;
 l1:=UNION(L);
 l2:=MAKELIST(SIZE(INTERSECT(L,l1(I))),I,1,SIZE(l1));
 DIFFERENCE(l1*(l2==MAX(l2)),0);
EDITED for a few simplifications.
10-31-2017, 11:39 PM (This post was last modified: 11-01-2017 05:18 PM by StephenG1CMZ.)
Wow.
It's amazing what a couple of lines can accomplish when you are familiar with HP Prime built-in functions.
However, I think there is a bug:
{1,2} yields {1,2,0} rather than the expected {1,2}.
Your version doesn't handle {"red","green","red} - but then it is likely much faster as well as more concise.
My own version is mainly written in the style of a C or Pascal program trawling through the lists, with very limited use of built-in functions such as union (thanks for your #21 solution). As such it is likely slower, but perhaps more portable.
It is included in my new list processing API
http://www.hpmuseum.org/forum/thread-9411.html
But I could extract the relevant procedures here if you like.
11-01-2017, 07:09 AM
(10-31-2017 11:39 PM)StephenG1CMZ Wrote:  However, I think there is a bug:
Ah, I've been too aggressive in the simplifications. Here is an updated version that should work better including for non numeric lists, but it's less concise...
EXPORT ModeList(L)
 LOCAL l1,l2;
 l1:=UNION(L);
 l2:=(l2==MAX(l2))*MAKELIST(I,I,1,SIZE(l1));
 l2:=remove(0,l2);
 MAKELIST(l1(l2(I)),I,1,SIZE(l2));
11-01-2017, 11:11 AM
As I expected, your implementation is much faster than mine.
About half to two-thirds of my runtime given a list with no duplicates (RANDOM reals), and much faster with duplicates (RANDINT integers).
