Editor
10-20-2017, 12:15 PM
Editor
Hello everyone, everything good? I'm new to this subject of HP's I started to study engineering and would like to make my own app's, but I'm running into a problem. I can not find an editor for the holds, .hpappprgm and .hpapp. Could someone help me? Thanks in advance to all of you.
10-20-2017, 09:44 PM
RE: Editor
Read the quick start guide. I believe there is an example in there. You press shift-program to see your programs and select the program and you are in the editor then...
10-20-2017, 09:46 PM
RE: Editor
If you are talking about on the computer, then install the connectivity kit and you can edit things in there.
TW
