Interesting little Pioneer keyboard repair
10-08-2017, 02:15 AM (This post was last modified: 10-08-2017 02:15 AM by mfleming.)
Greetings,
I thought some might be interested in a repair I did recently on an HP Pioneer calculator keyboard. It's unlikely anyone will need to do the same, but I'll add it to the MoHPC knowledge base all the same.
I recently acquired an HP-27S calculator and manual for about a quarter of the going price on TAS. Although the seller stated the calculator no longer worked, I thought maybe it had the usual keyboard contact failure, which can be repaired without too much trouble. I was also most interested in the manual since I didn't have one for my working 27S. Seemed like a good gamble so I bought it.
Unfortunately as you can see from the photo collage below, the Power On key had been permanently damaged. You can see in the upper left hand picture the pry marks made by a knife or screwdriver blade. I didn't notice the marking in the photos - my fault for not examining them with more care. But, like I said, I was happy to get the manual.
[Image: uc?export=view&id=0Bwt5Q_LizRq6YlNJNElOb2h4LWc]
After opening the case and trying to fix the usual ribbon contact fault without success I decided to trace the two power button contacts to a convenient point and solder in some wires to close the power button remotely. You can see the wires in the lower left photo, with tape used for strain relief. I reassembled the CPU board, closed the case and verified the calculator would power up when the wires were touched together.
The lower right hand photo of the calculator display confirms that I was on the right track. Now that I knew the calculator worked, how was I to put it back into service? I looked at forum posts on how to disassemble and repair the keyboard. After reading the various descriptions and considering that approach, I thought "Only with a gun to my head." An alternative was to transplant the CPU board to an HP-17Bii donor and transfer the faceplate, but there would be four mismatching keys. Not a bad approach, but it would be labor intensive and look like a noticeable hack.
I finally settled on the solution you see in the last, upper right hand photo. I drilled and then squared off a hole for a small pushbutton switch, soldered the wires to it and closed everything up. Voila, another HP calculator returned to active duty.
Now some may find an algebraic calculator, even an HP one, to be somewhat objectionable. Consider what the 27S provides though. Pretty much the full 17Bii capability including HP Solver, TVM, 1 & 2 variable statistics, probability and a real time clock & calendar with appointments. Add in a pretty decent set of scientific functions including hyperbolics, base arithmetic and conversions and you have a pretty nice pocket companion. It can even print. What's not to like?
It is a little weird having the On button in the diagonally opposite corner, but you get used to it!
~Mark
BTW, I understand the 27S and 42S use the same PCB. Any chance adding a second SRAM trick will work for the 27S?
Attached File(s) Thumbnail(s)
10-08-2017, 04:17 AM
RE: Interesting little Pioneer keyboard repair
(10-08-2017 02:15 AM)mfleming Wrote:  Now some may find an algebraic calculator, even an HP one, to be somewhat objectionable. Consider what the 27S provides though. Pretty much the full 17Bii capability including HP Solver, TVM, 1 & 2 variable statistics, probability and a real time clock & calendar with appointments. Add in a pretty decent set of scientific functions including hyperbolics, base arithmetic and conversions and you have a pretty nice pocket companion. It can even print. What's not to like?
Nice recovery, with a unique twist Mark!
I agree, the 27S is a great machine despite its Algebraic limitations. It has the best overall cross-section of built-in features of any of the Pioneers, possibly of all. Plus, my wife can use it too... (though she won't. I gave her a 12C Platinum (in Alg. mode - she refuses to consider RPN) some time ago, and she won't give it up for better machines. I told her I get it.)
There were rumors for some time (ages ago) of a 27SII, which would have added RPN, like the 17BII, 19BII, etc. but it seems it was only a passing thought, as no samples have ever been seen.
10-08-2017, 07:05 AM
The 27S is the only true pocket calculator with the RPL equation editor and Trigs, worth to save a sample like yours. Well done.
10-08-2017, 08:22 PM
Very nice. I carry a 27S around with me daily. It's got a great feature set, and what it's lacking can often be added via the solver.
10-09-2017, 01:40 AM
(10-08-2017 04:17 AM)rprosperi Wrote:  There were rumors for some time (ages ago) of a 27SII, which would have added RPN, like the 17BII, 19BII, etc. but it seems it was only a passing thought, as no samples have ever been seen.
I certainly do wish such an updated model were available. More memory perhaps and the Cash Flow functions of the HP17Bii would have been very handy. Seems like adding RPL would have been natural given it already has a four level "answer history."
(10-08-2017 08:22 PM)Dave Britten Wrote:  Very nice. I carry a 27S around with me daily. It's got a great feature set, and what it's lacking can often be added via the solver.
Having recently left the rat race, I spend more time calculating returns on investment than inverting complex matrices! With the manual at hand in physical rather than PDF form, plus Martin Hepperle's excellent article on the Solver, I'm trying to reproduce some of the missing features I use on the 17Bii. Maybe throw in a few logical function to complement Base arithmetic too.
The 27S is a really great scratchpad calculator!
~Mark
10-09-2017, 02:12 AM
(10-09-2017 01:40 AM)mfleming Wrote:  Having recently left the rat race, I spend more time calculating returns on investment than inverting complex matrices! With the manual at hand in physical rather than PDF form, plus Martin Hepperle's excellent article on the Solver, I'm trying to reproduce some of the missing features I use on the 17Bii. Maybe throw in a few logical function to complement Base arithmetic too.
~Mark
Got the logical functions covered here: http://www.hpmuseum.org/forum/thread-8492.html
It’s pretty easy to implement depreciation formulas and the business percentage calculations, and personally I’ve never needed (and probably never will need) the bond calculations, so it doesn’t take much effort to get it on par with a 17BII for finance, at least as far as I’m concerned. Plus you get so much more scientific capability to go along with it.
