Connect iOS Prime via wifi (in Parallels)
10-07-2017, 10:11 AM (This post was last modified: 10-07-2017 10:37 AM by salvomic.)
hi,
please help with this problem.
Situation: Mac OS X 10.13 and Windows 10 inside Parallels 13; wi-fi network named "white"; iPhone (and or iPad) in the same network.
I can connect iOS via CK in Mac OS, setting "network" as "white", ok.
Not in Windows 10: it is connected via simulated ethernet (shared network in the customisation window) I thing named "Ethernet", no wi-fi (but it use those of the Mac). CK doesn't connect iOS at all.
Any help? something to write in the "Network" or "Wireless" field of CK to get the job?
thank you,
Salvo
∫aL√0mic (IT9CLU), HP Prime 50g 41CX 71b 42s 12C 15C - DM42 WP34s :: Prime Soft. Lib
10-08-2017, 12:41 AM
RE: Connect iOS Prime via wifi (in Parallels)
It is most likely being blocked because it is on a different subnet. Is your network in windows paralleles configured to "bridged", "shared" or something else?
TW
10-08-2017, 07:01 AM
(10-08-2017 12:41 AM)Tim Wessman Wrote:  It is most likely being blocked because it is on a different subnet. Is your network in windows paralleles configured to "bridged", "shared" or something else?
it's shared, as normal with Windows (or other virtual machines, Linux, BSD...) in Parallels.
10-08-2017, 03:39 PM
(10-08-2017 03:20 PM)moonbeam Wrote:  And there's your problem. "Shared" is the default network mode, but in this case you'll need one of the bridged modes (most likely "default adapter").
yes, thank you!
that was the problem.
I put "bridget" and "default adapter" and all runs ok!
Salvo
