copier dans éditeur de programme
10-05-2017, 05:55 PM
Bonjour
Je voudrais signaler une anomalie dans l'éditeur de programme :
si l'on selectionne la touche 'copy' par erreur ou que l'on change d'avis
il n'est pas possible de quitter ce menu et de revenir au programme la touche 'Esc'
nous renvoie au catalogue des programmes, contrairement à ce qui se passe
avec la touche 'paste' .
Hello
I would like to point out an anomaly in the program editor:
if you select the 'copy' key by mistake or change your mind
it is not possible to leave this menu and to return to the program the key 'Esc'
refers to the catalog of programs, contrary to what happens
with the 'paste' key.
Sorry for my english
10-05-2017, 06:13 PM
RE: copier dans éditeur de programme
Pressing ON will close the menu.
However, you are right that the ESC doesn't behave consistently. This is probably because there is some custom "ESC" key handling to prompt in the program editor that is not checking for a custom menu first. I will correct that.
Thank you!
TW
10-06-2017, 03:38 AM
(10-05-2017 06:13 PM)Tim Wessman Wrote:  Pressing ON will close the menu.
Thank you!
Thank you!
