Rocker Navigation - Vars, Toolbox and Units
03-12-2014, 02:00 AM (This post was last modified: 03-12-2014 03:39 PM by CR Haeger.)
This may have been mentioned early after HP Prime launch.
It seems that the touchscreen must be used to change to a different menu category when Vars, Toolbox and/or shift-Units selected.
Please consider also allowing the user to move L or R between the six menu categories using the rocker switch** versus the screen. Perhaps allow the highlighter to go to the top (above #1) or to the bottom which would then enable the L or R movement.
For example, pressing Vars:
- Assume the last menu used was Vars/Home and you want to select Vars/App
- Pressing Vars brings up the Vars/Home/1 Real menu
- Press rocker up one. which highlights Vars/Home Vars
- Press rocker right twice which highlights Vars/App Vars
- Use rocker to select Vars/App Vars menu item desired
This feature may allow for faster more accurate menu selections and keep the screen cleaner.
Best,
Carl
** Temporarily reassigning Vars to Backspace row of keys as menus 1-6 might be an option as well.
