WP34s: inconsistent behavior for Zeta near zero
08-01-2017, 07:22 PM (This post was last modified: 08-01-2017 07:23 PM by Dieter.)
In the General Forum there is a discussion about the Riemann Zeta function and its implementation on various HP calculators. For this purpose the high accuracy 34s served me very well for reliable reference values. But now I realized that arguments very close to zero may be off. The following examples refer to 34s version 3.3 3840 with printer support.
Note: for x close to zero Zeta(x) is approximately –0,5–x. So Zeta(1E-10) is ~ –0,5000000001 and Zeta(1E-20) rounds to –0,5 in SP mode. So far so good.
But then:
Zeta(3 E-30) yields –0,5 (correct)
Zeta(3,3333 E-30) returns –0,5 (correct)
Zeta(3,33333 E-30) returns –0,5000045000450005 (completely off)
Zeta(–3,33333 E-30) returns –0,5000495049504950 (completely off)
Zeta(3,14159 E-30) returns –0,4999984084542908 (completely off)
Zeta(1E-40) throws a –∞ error
One reason for me posting this is ...I came across the same problem when I tried to calculate Zeta for arguments very close to zero by means of the reflection formula. Here Zeta(x) can be expressed in terms of Zeta(1–x) so that x<0 or even x<0,5 can be handled. Maybe this is also the reason for the mentioned strange results on the 34s. I suspect that 1–x here simply rounds to 1, and Zeta(1) is undefined, or ∞ if you prefer.
Dieter
08-01-2017, 11:54 PM (This post was last modified: 08-02-2017 12:33 AM by Paul Dale.)
RE: WP34s: inconsistent behavior for Zeta near zero
I think you are correct pointing at the reflection code as the cause here.
Pauli
08-03-2017, 12:39 AM
I've got a fix which I'll commit tonight.
Instead of reflecting at x=0.5, the change reflects for x<=0. The series converges for x>0 so values should still be good and the accuracy loss won't occur.
08-03-2017, 07:30 AM
The fix has been committed. We await the next rebuild for the firmware and emulators.
Pauli
08-03-2017, 09:45 PM
(08-03-2017 07:30 AM)Paul Dale Wrote:  The fix has been committed. We await the next rebuild for the firmware and emulators.
Great, thank you.
When the new version is available on sourceforge, github or whereever, could you please post a direct link to the directory with the .bin files resp. the new emulator files? I always get lost when I try to find these things.
Dieter
08-04-2017, 01:02 AM
I expect it will be Marcus making the new images.
Pauli
