Algebraic to RPN
02-24-2017, 09:27 PM (This post was last modified: 02-25-2017 03:10 PM by Han.)
Algebraic to RPN
The code below takes an algebraic expression and converts it to an RPN string. The program itself is not all that useful (in my opinion) but it hopefully provides to those interested in programming expressions a bit of insight into how expressions are built.
For example, in the CAS view, type:
CRPN(x^2-4*x)
to obtain "x 2 ^ 4 x * - +"
EDIT: Joe Horn pointed out to me that the "+" appeared extraneous -- which was also my initial reaction. As it turns out, the CAS treats subtraction as a sequence of negation followed by addition. So the "-" operator is actually the negation operator, which can be verified by typing f:=neg(x) in the CAS view, and extracting the operation using f[1]. I never really gave this much thought, but it is neat to see how expressions are handled on a lower level.
#cas
CRPN(f):=
begin
  local rpn, op, par, n, j, g;
  rpn:="";
  op:="";
  par:="";
  if (type(f) <> DOM_SYMBOLIC) then
    rpn:=string(f);
    return(rpn);
  end;
  op:=string(f[1]);
  n:=size(op);
  op:=MID(op,2,n-2);
  n:=dim(f) + 1;
  for j from 2 to n do
    g:=f[j];
    if (type(g) <> DOM_SYMBOLIC) then
      par:=string(g);
    else
      par:=CRPN(g);
    end;
    if (j > 2) then rpn:=rpn + " "; end;
    rpn:=rpn + par;
    if ((j > 2) or (n == 2)) then
      rpn:=rpn + " " + op;
    end;
  end;
  return(rpn);
end;
#end
Graph 3D | QPI | SolveSys
02-25-2017, 12:19 PM
RE: Algebraic to RPN
Hello Han,
I appriciate many your program. I have the same from Wiiliam C WICKES from
HP 48 INSIGHTS (part II page 534) from 1992.
I was failure to translate to HP PRIME and you give me !
Thank again.
Gérard.
02-25-2017, 02:05 PM
extract parts and operators with [] acts as the PART command, please create a second version with PART cmd
PHP Code:
(x^2-4*x)[1→ '+'
(x^2-4*x)[2→ x^2
(x^2-4*x)[3→ -4*x
part
(x^2-4*x→ 2
part
(x^2-4*x,1→ x^2
part
(x^2-4*x,2→ -4*x
part
(x^2-4*x,0→ "+"
02-25-2017, 03:15 PM
(02-25-2017 02:05 PM)compsystems Wrote:  extract parts and operators with [] acts as the PART command, please create a second version with PART cmd
PHP Code:
(x^2-4*x)[1→ '+'
(x^2-4*x)[2→ x^2
(x^2-4*x)[3→ -4*x
part
(x^2-4*x→ 2
part
(x^2-4*x,1→ x^2
part
(x^2-4*x,2→ -4*x
part
(x^2-4*x,0→ "+"
I am not sure why you would want a version using the part command, but here:
#cas
CRPN(f):=
begin
  rpn:="";
  op:="";
  par:="";
    rpn:=string(f);
    return(rpn);
  end;
  op:=string(part(f,0));
  n:=size(op);
  op:=MID(op,2,n-2);
  n:=part(f);
  for j from 1 to n do
    g:=part(f,j);
      par:=string(g);
    else
      par:=CRPN(g);
    end;
    if (j > 1) then rpn:=rpn + " "; end;
    rpn:=rpn + par;
    if ((j > 1) or (n == 1)) then
    end;
  end;
  return(rpn);
end;
#end
02-26-2017, 02:59 PM (This post was last modified: 03-02-2018 01:38 PM by compsystems.)
userrpl
PHP Code:
« 0 0 { } -> EXPRESSION XPART NPARTS OPERATOR OBJECTS
  « EXPRESSION
    IFERR OBJ
THEN ->STR 'OPERATOR' STO 0 'NPARTS' STO OPERATOR 1 ->LIST 'OBJECTS' STO
ELSE ->STR 'OPERATOR' STO 'NPARTS' STO NPARTS ->LIST 'OBJECTS' STO NPARTS OPERATOR OBJECTS 3 ->LIST DROP
    END
IF XPART NPARTS <= XPART ->= AND NOT
      THEN
"EXPRESSION " EXPRESSION " CONTAINS ONLY " NPARTS " PARTS" +
      ELSE
        IF
XPART 0 ==
THEN OPERATOR
ELSE
          IF
XPART -==
THEN NPARTS
ELSE OBJECTS XPART GET
          END
        END
      END
'PART' STO
Hi. The code with PART CMD, is simplified to the following, also rename some variables to auto-document the code.
PHP Code:
#cas
convToRPN(expr1):=
begin
      local rpnStr
operpartnpartspartJexpr2;
rpnStr:="";
oper:="";
partn:="";
      if (
type(expr1) <> DOM_SYMBOLICthen
        rpnStr
:=string(expr1);
        return(
rpnStr);
end;
expr1:=(x^2-4*x);
oper:=string(expr1[1]);
parts:=size(oper);
oper:=MID(oper,2,parts-2);
parts:=dim(expr1) + 1;
      for
partJ from 2 to parts do
expr2:=expr1[partJ];
        if (
type(expr2) <> DOM_SYMBOLICthen
          partn
:=string(expr2);
        else
partn:=convToRPN(expr2);
end;
        if (
partJ 2then
          rpnStr
:=rpnStr " "
end;
rpnStr:=rpnStr partn;
        if ((
partJ 2) or (parts == 2)) then
          rpnStr
:=rpnStr " " oper;
end;
end;
      return(
rpnStr);
end;
#end
//(x^2-4*x)[1] -> '+'
//(x^2-4*x)[2] -> x^2
//(x^2-4*x)[3] -> -4*x
#cas
convToRPN2(expr1):=
begin
      local rpnStr
rpnStr:="";
oper:="";
partn:="";
      if (
        rpnStr
:=string(expr1);
        return(
rpnStr);
end;
oper:=part(expr1,0);
parts:=part(expr1);
      for
partJ from 1 to parts do
expr2:=part(expr1,partJ);
        if (
          partn
:=string(expr2);
        else
partn:=convToRPN2(expr2);
end;
        if (
partJ 1then
          rpnStr
:=rpnStr " "
end;
        if ((
partJ 1) or (parts == 1)) then
          rpnStr
:=rpnStr " " oper;
end;
end;
      return(
rpnStr);
end;
#end
convToRPN2(x^3); returns "x 3 ^"
Running step by step convToRPN2(x^3);, for those who want to see the conversion of x^3 to RPN
more info on RPN
https://en.wikipedia.org/wiki/Reverse_Polish_notation
PHP Code:
expr1:=x^3;
rpnStr:="";
oper:="";
partn:="";
oper:=part(expr1,0); //returns "^"
parts:=part(expr1); //returns 2
partJ:=1;
expr2:=part(expr1,partJ); //returns x
partn:=string(expr2); //returns "x"
rpnStr:=rpnStr partn// returns "x"
partJ:=2;
expr2:=part(expr1,partJ); //returns 3
partn:=string(expr2); //returns "3"
rpnStr:=rpnStr " "//returns "x "
rpnStr:=rpnStr partn//returns "x 3"
rpnStr:=rpnStr " " oper//returns "x 3 ^"
Or in a list of steps, without comments to copy and paste them in the history view
PHP Code:
expr1:=x^3rpnStr:=""oper:=""partn:=""oper:=part(expr1,0); parts:=part(expr1); partJ:=1expr2:=part(expr1,partJ); partn:=string(expr2); rpnStr:=rpnStr partnpartJ:=2expr2:=part(expr1,partJ); partn:=string(expr2); rpnStr:=rpnStr " ";rpnStr:=rpnStr partnrpnStr:=rpnStr " " oper
returns
PHP Code:
x^3,"","","","^",2,1,x,"x","x",2,3,"3","x ","x 3","x 3 ^"
[Image: hp_prime_convertToRPN_image00.png]
