Import txt files to hp50g
01-22-2017, 05:30 PM
Is there a way to import text written on PC into the calculator? I tried typing in the emu48 Calculator but it was a bit cumbersome , especially with characters that are not in the english language like æ,ø and å..
01-22-2017, 07:02 PM
RE: Import txt files to hp50g
A plain text file written on Notepad fro example can be easily transferred to the 50G using the SD card or Connectivity Kit. Are you asking about transferring to a real
50G or the emulator? On the emulator, you can use the edit menu to paste a text
file from the PC clipboard. Just copy the text from your editor on your PC to the
clipboard and then using Edit>Paste on the emulator to place the text on the stack as a string object.
01-22-2017, 08:43 PM
(01-22-2017 07:02 PM)John Colvin Wrote:  A plain text file written on Notepad fro example can be easily transferred to the 50G using the SD card or Connectivity Kit. Are you asking about transferring to a real
Awesome! I use Usolve and store many equations in themed folders, this makes it a lot easier to create good help files with explanations for these eq's.
01-24-2017, 12:45 PM
You might also want to use utility to make it easier to view (& edit) text files on the 50g:
http://www.hpcalc.org/hp49/apps/editors/
01-25-2017, 01:14 AM
HPUserEdit
Program to edit HP 48/49 objects in ASCII format.
http://www.hpcalc.org/details.php?id=6600
01-25-2017, 01:22 PM
(01-25-2017 01:14 AM)RPL Calcs Wrote:  HPUserEdit
Aha, the excellent HPUserEdit! A great tool to develop and test 50g programmes on a computer (it comes with a 50g emulator), which you can then export and copy to the real calculator.
Indeed a good place to write text files as well, for export to the real calculator.
01-25-2017, 05:32 PM
any text editor -> myfile.txt -> SD card -> HP 50g
Ascii Import/Export for SD card and Emulator
https://groups.google.com/forum/#!msg/co...zxPAvZfk4J
ASCII to Binary Converter
http://www.hpcalc.org/details/3648
page by page viewer
https://groups.google.com/forum/#!msg/co...fLsnaOK1kJ
other discussions:
http://www.hpmuseum.org/forum/thread-4635.html
http://www.hpmuseum.org/forum/thread-6932.html
