01-17-2017, 08:49 PM (This post was last modified: 10-26-2018 07:12 AM by Spybot.)
New threat has been created.
01-18-2017, 01:50 AM (This post was last modified: 10-23-2018 03:12 AM by compsystems.)
RE: New HP Prime Skin! for FW 11226
v 5.0 => https://www.hpcalc.org/details/7750
The files was created with the editor of ERWIN?
For HP-Team> How do I install this skins on Android-OS version?
01-18-2017, 02:42 AM (This post was last modified: 01-20-2017 05:40 AM by Spybot.)
RE: New HP Prime Skins! for FW 11226
Hi, compsystems!
No, it wasn't created with Erwin's, the *.primeskin file was mapped and edited manually using the notepad from windows, and the actual image file was made in Inkscape (100% vectors), then saved as *.png.
Spybot.
01-18-2017, 07:23 AM
How does one implement your new skins?
ter
01-30-2017, 03:51 AM
RE: HP Prime Skins (Version 2) for FW 11226.
Nice skins! I was able to easily import them into my mac version and they worked flawlessly. One thing I did notice was the approximate symbol on the enter key was missing. However, it still worked when using the blue shift key. Thanks
01-30-2017, 04:05 AM
Looks nice, but I would recommend making the orange much brighter for better contrast. Perhaps either something closer to yellow would make it more legible on darker backgrounds (e.g. black keys)
Graph 3D | QPI | SolveSys
01-30-2017, 02:26 PM
johnet123 you're right, I totally missed the approximate symbol on the enter key! I apologize... I'll fix it right away...
Spybot.
01-30-2017, 02:31 PM
Han, I can make orange more brighter... Yellow .... could also work.
Spybot.
01-30-2017, 02:53 PM (This post was last modified: 01-30-2017 02:53 PM by jrozsas.)
Very good! I like new skin
Leo
02-01-2017, 01:47 AM (This post was last modified: 02-01-2017 04:06 PM by Spybot.)
RE: HP Prime Skins for FW 11226. (Version 3, with 3 different colors)
jrozsas I hope you like (version 3).
Spybot.
02-01-2017, 02:31 AM
Very nice!
02-01-2017, 07:23 PM (This post was last modified: 02-01-2017 07:26 PM by Tim Wessman.)
So I checked the code... I thought I had created a "Skins" folder in your <Documents>/HP Prime/ directory specfically for user skins. I discovered that the code was in there, but commented out (testing time was limited last nov/dec).
In the next version, all you will need to do is drop your skins/images into <Documents>/HP Prime/Skins and have no need to touch the system install directory. Of course you can put them them in the system skins directory instead, but some users might not be able to touch that directory due to lack of admin rights.
TW
02-01-2017, 10:50 PM
Hi Tim!
Yes you're right, without admin rights many people won't be able to use these or any other skin, it'll be easier to have a dedicated directory to put them there.
Thanks for letting us know it will be available on the next version.
Spybot.
07-06-2017, 06:19 AM
These skins are absolutely amazing! I wish I had your artistic skills.
Did you ever make a Medium Vertical skin? That would be awesome.
Jim
07-06-2017, 01:19 PM
Hello Jim!
I'm Glad you like them, I din't do a Medium Vertical skin because I'm waiting for the next FW update to make new skins.
Spybot.
07-07-2017, 07:08 AM
Please let me know when you make a Medium Vertical skin. I think that would be perfect (at least for me). I did try to take your Small Vertical skin, open it up in Photoshop (which I'm not very good with) and enlarge it but it's just not that simple :-)
I have a bit of trouble seeing due to old age (62). A while back, I made some skins for my Prime but all I did was try to enhance the ones that came with the emulator. They're not very good.
Yours are amazingly clear. I have no idea how you did that.
Thanks again,
Jim
07-08-2017, 02:34 AM
Actually I made them because I'm also visually impaired, that's why I made them so clear.
Yes of course I'll let you know when I make the medium size skin.
Spybot.
02-04-2018, 01:40 AM
(07-06-2017 01:19 PM)Spybot Wrote:  Hello Jim!
The next FW update is now available ... hint hint hint :-)
Your skins are the only ones I use any more, thanks so much for your efforts!
02-04-2018, 04:58 AM
Current skins will work fine. The only new thing is you can now have a "pressed" image if you want. If there is one, it will pull from that for pressed keys on key press.
TW
