Learning TeX
12-14-2013, 10:31 AM (This post was last modified: 12-14-2013 10:35 AM by Joe Horn.)
Learning TeX
My first attempt at TeX:\begin{equation}
\varphi = 1 + \cfrac{1}{1
+ \cfrac{1}{1
+ \cfrac{1}{1
+ \cfrac{1}{1 + \ddots
\end{equation}Dang, this is easy! Smile
X<> c
-Joe-
06-10-2014, 08:26 PM
RE: Learning TeX
Trying it here too: \begin{equation}x_1=x_0+vt+\frac{1}{2}at^2\end{equation}
And more text.
06-10-2014, 08:28 PM
RE: Learning TeX
and how about (a^2+b_2) Does that work?
06-15-2014, 01:48 PM
RE: Learning TeX
Oscar Had A Hunk Of...
\[\\sin =\frac{o=Oscar}{h=Had}\\ \\cos =\frac{a=A}{h=Hunk}\\ \\tan =\frac{o=Of}{a=?}\\\]
Apple
Thanks for the TeX Lesson
http://www.codecogs.com/latex/eqneditor.php
Thanks
~~~~8< Art >8~~~~
PS: Please post more 50G stuff :)
05-06-2015, 02:31 PM
RE: Learning TeX
How do I enter equations using TeX? Shouldn't it be as simple as
[tex]
a=1
[/tex]
Thanks
05-06-2015, 02:50 PM
RE: Learning TeX
(05-06-2015 02:31 PM)Marcio Wrote:  Hello,
[tex]
a=1
[/tex]
Thanks
+1 I don't know how to properly copy or insert Latex into forum posts.
Perhaps this could be described and added as a sticky to the top of this test forum?
05-06-2015, 04:29 PM
RE: Learning TeX
Inline \(\LaTeX\)
\( your equation here \)
Displayed \(\LaTeX\)
\[ your equation here \]
05-06-2015, 04:49 PM
RE: Learning TeX
\( a=1 \)
Ha. Thanks
05-17-2015, 04:33 AM
RE: Learning TeX
Hint: If you see a posting with nifty TeX in it, and want to see how they did it, just click the Quote button, take a peek at the TeX code, then press Back on your browser. Sorta like learning programming by reading other people's programs, which I'll bet we've all done.
X<> c
-Joe-
05-22-2015, 06:43 AM (This post was last modified: 05-22-2015 06:44 AM by Brian D.)
RE: Learning TeX
To view someone else's TeX code, you can also right-click on the math and choose to show the math as TeX commands.
\(\LaTeX\) in general can be worth learning if you have reason to produce complicated documents with lots of cross-references, bibliography citations, index entries, figures, etc.
05-22-2015, 09:21 AM
RE: Learning TeX
You may also use Daum which is both available online and as a Chrome add on.
08-21-2015, 04:20 PM
RE: Learning TeX
\(E^2-p^2c^2=m^2c^4\)
\[E^2-p^2c^2=m^2c^4\]
\[f(x)=\begin{cases}
0,\quad -1\le x<-0,5,\\
1,\quad -0,5<x<0,5,\\
0,\quad 0,5<x\le 1.
\end{cases}\]
Marcelo
11-27-2015, 12:17 AM (This post was last modified: 11-27-2015 12:25 AM by Vtile.)
RE: Learning TeX
(05-06-2015 04:29 PM)Alberto Candel Wrote:  Inline \(\LaTeX\)
\( test^{latex} \)
Interesting this works here, but not some other places on the forum... Edit.. Ah, it did go haywire after editing again. Confused
\( test^{latex} \)
... Edit2 : Solved it relates to Quick Edit vs Full Edit functionality.
11-27-2015, 12:22 AM
RE: Learning TeX
\( test^{latex} \)
\( test^{latex} \)
Maybe you put the TeX code as 'formatted code'?
11-27-2015, 12:26 AM (This post was last modified: 11-27-2015 12:27 AM by Vtile.)
RE: Learning TeX
(11-27-2015 12:22 AM)Marcio Wrote:
(11-27-2015 12:17 AM)Vtile Wrote:  \( test^{latex} \)
\( test^{latex} \)
It is the quickedit vs full edit thing. I assume it is only a refressing "error" as I do not see it correctly at first, but I assume that others do see it correctly since they just loaded the page.
