DROID-PSECINT PSEudoCode INTerpreter SPN/ENG/...
12-30-2016, 07:32 PM (This post was last modified: 01-02-2017 07:08 PM by compsystems.)
Pseudocode interpreter/(Interprete de seudocódigo), for now only in English and Spanish interpreter, first release version Dec 2016 (Free version)
More info
ENG: https://play.google.com/store/apps/detai...code&hl=en
SPN: https://play.google.com/store/apps/detai...code&hl=es
Please test it and comment, Ideas, improvements, etc. are welcome
Thanks
PD:
A friend is the author. If you want to collaborate with the project please translate these two files to a particular language. (French, Portuguese, German, etc.)
[Image: jgLEuIUviATyxS1h1zKB3OpbqhGOGbek8uuniRZy...pY=h900-rw]
[Image: YNoRY2TQo8zsyJttk06vSC-PsHmqMjNxOqU-kiG6...Nk=h900-rw]
KEYWORDS.TXT
PHP Code:
// ENGLISH                                                 // SPANISH
BOOL                    : (TRUE FALSE) ;             // : (VERDADERO | FALSO) ;
ALGORITHM               A L G O R I T H M ;          // : A L G O R I T M O;
ENDALGORITHM            E N D A L G O R I T H M ;    // : F I N A L G O R I T M O;
PROCESS                 P R O C E S S ;              // : P R O C E S O;
ENDPROCESS              E N D P R O C E S S ;        // : F I N P R O C E S O;
DEFINE                  D E F I N E ;                // : D E F I N I R;
AS                      : A S ;                        // : C O M O;
NUMBER                  N U M B E R ;                // : N U M E R O;
NUMERIC                 N U M E R I C ;              // : N U M E R I C O;
INTEGER                 I N T E G E R ;              // : E N T E R O;
CHARACTER               C H A R A C T E R ;          // : C A R A C T E R;
REAL                    R E A L ;                    // : R E A L;
BOOLEAN                 B O O L E A N ;              // : L O G I C O;
TEXT                    T E X T ;                    // : T E X T O;
STRING                  S T R I N G ;                // : C A D E N A;
READ                    R E A D ;                    // : L E E R;
WRITE                   W R I T E ;                  // : E S C R I B I R;
DIMENSION               D I M E N S I O N ;          // : D I M E N S I O N;
FOR                     : F O R ;                      // : P A R A;
TO                      T O ;                        // : H A S T A;
WITH                    W I T H ;                    // : C O N;
STEP                    S T E P ;                    // : P A S O;
DO                      : D O ;                        // : H A C E R;
ENDFOR                  : E N D F O R ;                // : F I N P A R A;
CLEAR                   C L E A R ;                  // : B O R R A R;
SCREEN                  S C R E E N ;                // : P A N T A L L A;
WAIT                    W A I T ;                    // : E S P E R A R;
KEY                     K E Y ;                      // : T E C L A;
SECONDS                 S E C O N D S ;              // : S E G U N D O S;
SECOND                  S E C O N D ;                // : S E G U N D O;
MILLISECONDS            M I L L I S E C O N D S ;    // : M I L I S E G U N D O S;
IF                      : I F ;                        // : S I;
THEN                    T H E N ;                    // : E N T O N C E S;
ELSE                    : E L S E ;                    // : S I N O;
ENDIF                   : E N D I F ;                  // : F I N S I;
SWITCH                  : S W I T C H ;                // : S E G U N;
CASE                    : C A S E ;                    // : C A S O;
OF                      O F ;                        // : D E;
ANOTHER                 A N O T H E R ;              // : O T R O;
MODE                    M O D E ;                    // : M O D O;
ENDSWITCH               : E N D S W I T C H ;          // : F I N S E G U N;
WHILE                   : W H I L E ;                  // : M I E N T R A S;
ENDWHILE                : E N D W H I L E ;            // : F I N M I E N T R A S;
REPEAT                  R E P E A T ;                // : R E P E T I R;
THAT                    T H A T ;                    // : Q U E;
SUBPROCESS              S U B P R O C E S S ;        // : S U B P R O C E S O;
ENDSUBPROCESS           E N D S U B P R O C E S S ;  // : F I N S U B P R O C E S O;
FUNCTION                : F U N C T I O N ;            // : F U N C I O N;
ENDFUNCTION             E N D F U N C T I O N ;      // : F I N F U N C I O N;
CLEAN                   C L E A N ;                  // : L I M P I A R;
MODULE                  M O D U L E ;                // : M O D;
NO                      N O ;                        // : N O;
TRUE                    T R U E ;                    // : V E R D A D E R O;
FALSE                   F A L S E ;                  // : F A L S O;
SQUAREROOT              S Q U A R E R O O T ;        // : R C;
RANDOM                  R A N D O M ;                // : A Z A R;
errors.txt
PHP Code:
    public static final String BOOLEAN_TRUE "true"// "verdadero"
public static final BOOLEAN_FALSE "false"// "falso"
public static final ERROR_INTEGER "integer"// "entero"
public static final ERROR_REAL "real"// "real"
public static final ERROR_LOGIC "logical"// "logico"
public static final ERROR_STRING "string"// "cadena"
public static final ERROR_INVALID_DATA_TYPE "type not found"// "tipo no encontrado"
public static final ERROR_INCOMPATIBLE_DATA_TYPE "incompatible data type. Was expected: "// "tipos de datos incompatibles. Se esperaba: "
public static final ERROR_WAS_FOUND =";​was found: "// ";​se encontró: "
public static final ERROR_INVALID_BOOLEAN "Incorrect Value for Boolean Variable"// "Valor incorrecto para la variable booleana"
public static final ERROR_INVALID_TYPE "invalid data type"// "tipo de dato inválido"
public static final ERROR_SYMBOL_NAME_1 "the symbol with name \""// "el simbolo con nombre \""
public static final ERROR_SYMBOL_NAME_2 "\" has already been declared "// "\" ya ha sido declarado"
public static final ERROR_INTEGER_OR_REAL "integer or real"// "entero o real"
public static final ERROR_ARITHMETIC_NEGATION "error in arithmetic negation"// "error en negación aritmética"
public static final ERROR_BOOLEAN_NEGATION "error in Boolean negation"// "error en negación booleana"
public static final ERROR_RETURN_VAR_CREATED "return variable was not created"// "la variable de retorno no fue creada"
public static final ERROR_RETURN_VAR_INITIALIZED "return variable not initialized"// "variable de retorno no fue inicializada"
public static final ERROR_EXECUTION_CANCELED "Execution canceled"// "Ejecución cancelada"
public static final ERROR_INVALID_PARAMETERS "Input parameters are missing"// "Faltan parámetros de entrada"
public static final ERROR_INVALID_VARIABLE "Unidentified variable"// "Variable no identificada"
public static final ERROR_ARRAY_VARIABLE_1 "the variable \""// "la variable \""
public static final ERROR_ARRAY_VARIABLE_2 "\" already initialized as not array"// "\" ya se inicializo como no arreglo"
public static final ERROR_ARRAY_VARIABLE_3 "can not declare that value in the array"// "no se puede declarar ese valor en el arreglo"
public static final ERROR_DIVISION_BY_ZERO "division between 0"// "division entre 0"
public static final ERROR_INVALID_OPERATOR "unknown operator"// "operador desconocido"
public static final ERROR_SEMANTIC "Semantic error"// "Error semántico"
public static final ERROR_RUNTIME "Runtime Error"// "Error en tiempo de ejecución"
public static final ERROR_FUNCTION_WITH_NAME_0 "the function \""// "la función \""
public static final ERROR_FUNCTION_WITH_NAME_1 "the function with name\""// "la función con nombre \""
public static final ERROR_FUNCTION_WITH_NAME_2 "\" has not been declared"// "\" no ha sido declarada"
public static final ERROR_FUNCTION_WITH_NAME_3 "\" returns a value that must go in an expression"// "\" retorna un valor que debe ir en una expresión"
public static final ERROR_FUNCTION_WITH_NAME_4 "\" is used in an expression but returns no value"// "\" es usada en una expresión pero no retorna ningún valor"
public static final ERROR_FUNCTION_WITH_NAME_5 "número incorrecto de parametros al llamar la función \""// "número incorrecto de parametros al llamar la función \""
public static final ERROR_VARIABLE_WITH_NAME_1 "the variable named \""// "la variable con nombre \""
public static final ERROR_VARIABLE_WITH_NAME_2 "\" has not been initialized"// "\" no ha sido inicializada"
public static final ERROR_INVALID_INDEX_1 "The index \""// "El índice \""
public static final ERROR_INVALID_INDEX_2 "\" in the array \""// "\" en el arreglo \""
public static final ERROR_INVALID_INDEX_3 "\" it's not valid"// "\" no es válido"
public static final ERROR_INVALID_INDEX_4 "an invalid position of the array was accessed:"// "se accedió a una posición no valida del arreglo: "
public static final ERROR_INVALID_SYMBOL_1 "the symbol with name \""// "el símbolo con nombre \""
public static final ERROR_INVALID_SYMBOL_2 "has already been declared \""// "ya ha sido declarado \""
public static final ERROR_INVALID_DATA "Incorrect data"// "Datos incorrectos"
Future release is to compete with the PC version (http://pseint.sourceforge.net/index.php?...cargas.php), which includes:
1: Step by Step Execution
2: Generate flowcharts
3: export pseudocode to n computer languages (c++/java/matlab, .... etc)
