PIL-Box to Virtual HP-IL bridge software - SEVEN
12-03-2016, 06:48 PM (This post was last modified: 12-03-2016 06:49 PM by aurelio.)
I cannot run ILPilbox v1.62 on this PC running SEVEN, cause of a syde-by.syde problem.
I'm using so ILProgsIPv4 without any problem but I would like to understand what is wrong. Here below what is installed:
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219
Microsoft Visual C++ 2005 Redistributable (x64) 8.0.61000
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
Microsoft Visual Studio 2005 Tools for Office Runtime 8.0.60940.0
Microsoft Visual C++ 2005 Redistributable (x64) 8.0.59192
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
Smile
12-03-2016, 07:09 PM
RE: PIL-Box to Virtual HP-IL bridge software - SEVEN
Hi Aurelio,
I got the same issue with IlPer since version 2.22.
Christoph provides the required runtime there.
Cheers Jean-Christophe.
12-03-2016, 07:20 PM (This post was last modified: 12-03-2016 07:23 PM by aurelio.)
Jean-Christophe, thank -you for your quick answer and your help, I completely missed the thread and your previous post Smile
the PC I daily use, now away for service, maybe contains already the package, because pilbox works without any problem and any further installation
thank-you very much
