Accessibility: Fingerspelling program
05-14-2016, 11:12 PM
This program demonstrates the ability to fingerspell text and is also useful for the visually impaired.
Fingerspelling is useful by the deaf, and this program illustrates both how a translation can be done, and how program can be modified for accessibility.
The demonstration uses low-resolution text in lieu of the fingerspelling graphics, which can easily be replaced.
Stephen Lewkowicz (G1CMZ)
List API V1.1: http://www.hpmuseum.org/forum/thread-9411.html
05-14-2016, 11:16 PM
RE: Accessibility: Fingerspelling program
Version 0.1 (compiled on Android)
 LOCAL CRID:="FINGERSPELLER © 2016 StephenG1CMZ"+CHAR(10);
 LOCAL TRANSLATED:="";
 LOCAL WORLD:="Hello World © 2016";
 //CUSTOMISE
 LOCAL SECS:=1; //0=KEY WAIT
 LOCAL CHEAT_MODE:=1; //0 , 1
 //USE: G7
 LOCAL Y0:=20;//HEADER HEIGHT
 //FULL VALUES:
 //LOCAL FWIN:={0,Y0,320,200,0,220,320,220};//200-220 FOR CHEAT LINE
 LOCAL FWIN:={320/2,Y0,320,200,0,200,320,220};
 //USER VALUES MAY BE SMALLER TO SHARE SCREEN
 LOCAL SZX:=320;
 LOCAL SZY:=220-Y0;
 LOCAL II,JJ,OKC;
 LOCAL ROWS:=5;
 LOCAL COLS:=6;
 //LOCAL MYPX;
 LOCAL FS:={};
 LOCAL FSTMP:="TempFingerspell";
 LOCAL CHARSET:="ABCDEFGHIJKLMNOPQRSTUVWXYZ";
 LOCAL STRNG:="";
 LOCAL FILESPEC:="";
 SCR_PUT()
  AFiles(FSTMP):=G0;//SAVE
 SCR_GET()
   G0:=AFiles(FSTMP);
   DelAFiles(FSTMP);//Garbage Gone
 BSL(ACT)
  RECT_P();
  CASE
   IF ACT=="D"  THEN
    //USE DEL FOR CLEAN BUILD
    //CANCEL MAY MIX OLD AND NEWFILES
    TEXTOUT_P(AFiles(),0,20);WAIT(1);
    OKC:=MSGBOX("Delete OLD BSL?",1);
   IF ACT=="B"  THEN
    //BUILD FILES REPLACING THOSE EXISING
    OKC:=MSGBOX("Build BSL?",1);
    IF OKC THEN
     RECT_P();
     //TEXTOUT_P("Building BSL",0,SZY/2);
     //SIZE OF DIMGROB MUST BE BIG ENOUGH FOR PNG DATA
     //(IF 320 ASSUMED YOUR TEST TEXT CAN BE SMALL)
     DIMGROB_P(G7,22+2,28+20);
     //MSGBOX("XY"+GROBW_P(G7));//SYSCHECK:GROBW≤320:
   IF ACT=="S"  THEN  END;
   DEFAULT
  FOR II FROM 1 TO 26 DO
   FS(II):="BSL_"+CHAR(ASC("A")+II-1);
  //MSGBOX(FS);
  CASE
   IF ACT=="D" AND OKC THEN
      DelAFiles(FS(II));
     DelAFiles("BSL");
   IF ACT=="B" AND OKC THEN //BUILD
     RECT_P(G7);
     //TEXTOUT_P(CHAR(ASC("A")+II-1),G7,SZX/2,SZY/2,7);
     TEXTOUT_P(CHAR(ASC("A")+II-1),G7,2,20,7);
     BLIT_P(G0,G7);  //MAYBE SLOW ENOUGH TO SEE PROGRESS
     AFiles(FS(II)):=G7; //CAN BE SLOW IF SAVING FULLSCREEN
     //WAIT(1);
    AFiles("BSL"):=CHARSET;//DOCUMENT THE INSTALLATION
   IF ACT=="S" AND OKC THEN //SHOW
    RECT_P();
      //IF AFiles(FS) THEN //IF IT EXISTS-
      //RTE IF IT DOESNT
     G0:=AFiles(FS(II));//TOO FAST TO SEE
     //WAIT(SECS);
    DEFAULT
 SHOWAZ ()
  LOCAL XX:=IP(SZX/COLS);
  LOCAL YY:=IP(SZY/ROWS);
  //LOCAL LIN;
  LOCAL CN,XXX,YYY;
  RECT_P(0,20,320,240);
  FOR II FROM 0  TO ROWS-1 DO
   FOR JJ FROM 0 TO COLS-1 DO
    CN:=COLS*II+JJ+1;//6
    //MSGBOX(CN);
    IF CN≤26 THEN
     FS(CN):="BSL_"+CHAR(ASC("A")+CN-1);//MUST MATCH BUILD
     XXX:={JJ*XX,(JJ+1)*XX};
     YYY:={II*YY+Y0,(II+1)*YY+Y0};
     //MSGBOX(CN);
     G7:=AFiles(FS(CN));
     //BLIT_P(G0,XXX(1),YYY(1),XXX(2),YYY(2),G7,MIDX-2,MIDY-0,MIDX+20,MIDY+28);
     BLIT_P(G0,XXX(1),YYY(1),XXX(2),YYY(2),G7,0,20,GROBW_P(G7),GROBH_P(G7));
     RECT_P(XXX(1),YYY(1),XXX(2),YYY(2),0,{#FFFFFFh,0});
     //WAIT;
  DRAWMENU("BSL");
  TEXTOUT_P("BSL"+"- IMAGINE FINGERSPELL DATA HERE",0,0);
 DISPLAY_ONE (ST)
  LOCAL CH:=MID(ST,1,1);
  RECT_P(G7,0,20,320,200);//PROB NOT NEEDED:DEFINED BY FILE
  G7:=AFiles("BSL_"+CH);
  BLIT_P(G0,FWIN(1),FWIN(2),FWIN(3),FWIN(4),G7,0,20,GROBW_P(G7),GROBH_P(G7));​
  WAIT(SECS);
 DO_FSPELL(ST,TOPCALL)
 //AVOID SCREENSAVING HERE
 //IDEALLY: EARLY COMPLETION TBD
   LOCAL CH;
   IF TOPCALL THEN
    //REPLACE & WITH fspelldo("AND",0) ETC TBD
    //(DONT REPLACE STRING)
   //ESCAPE IF GETKEY4 AND SECS≠0?TBD
   FOR II FROM 1  TO DIM(ST) DO
    CH:=UPPER(MID(ST,II,1));
    IF INSTRING(CHARSET,CH) THEN
     IF TOPCALL THEN
      RECT_P(FWIN(1),FWIN(2),FWIN(3),FWIN(4));
      RECT_P(FWIN(5),FWIN(6),FWIN(7),FWIN(8));
      IF CHEAT_MODE THEN //SHOW STRING PROGRESS IN USER STRING
       //IMPROVES READABILITY BUT WILL WANT TO CUSTOMISE OUT IN TESTS
       TEXTOUT_P(MID(ST,1,II),FWIN(5)+2,FWIN(6));
       DRAWMENU(II,DIM(ST));
      ELSE
       DRAWMENU("");
       //(OTHERWISE USER MENU IS SEEN BUT NOT RESPONDED TO )
     DISPLAY_ONE(CH);
    ELSE
     //IGNORE UNKNOWN CHARS
 EXPORT FINGERSPELL(STRNG)
 //STRINGS(OR FILES)
  LOCAL ST:=STRNG;
  IF DIM(ST) THEN
   //DO DISPLAY
   SCR_PUT();
   DO_FSPELL(ST,1);
   SCR_GET();
 EXPORT FINGERSPELL_s(SECONDS)
 //WAIT
  SECS:=SECONDS;
 FINGERSPELL_BUILDER_TEST()
  OKC:=MSGBOX(CRID+"Instal Test Data (May Delete Old Signs)?",1);
  IF OKC THEN
   BSL("D");//DEL OLDFILES?
   BSL("B");//BUILD NEW FILES?
   MSGBOX(AFiles);
 FINGERSPELL_IN ()
  LOCAL TTL:=CRID;
  LOCAL LBL:={"String","File"};
  LOCAL HLP:={"Enter String to Fingerspell","Enter File to Fingerspell"};
  LOCAL ST:={};
  OKC:=INPUT({{STRNG,[2]},{FILESPEC,[2]}},TTL,LBL,HLP,{"",""},{STRNG,FILESPEC});
  IF OKC THEN
   IF DIM(FILESPEC) THEN
    STRNG:=STRNG+EXPR(FILESPEC);
   FINGERSPELL(STRNG);
  RETURN STRNG;
 EXPORT TranslateDeFinger()
  MSGBOX("TBD");
 EXPORT TranslateToFinger()
  TRANSLATED:=FINGERSPELL_IN();
  RETURN TRANSLATED;
 EXPORT FINGERSPELL_SetWin(WINLIST)
 //1-4: WINDOW FOR GRAPHIC
 //5-8: WINDOW FOR CHEATLINE
 //OVERLAP: CHEATLINE OBSCURED
 //INTENDED FOR USE BY USER PROGRAMS FOR SCREEN SHARING
  FWIN:=WINLIST;
 EXAMPLE_HELLO_WORLD()
  //AN EXAMPLE:HELLO WORLD
  //FIRST SET UP AN EXAMPLE PROGRAM SCREEN AS BACKGROUND
  //TO DEMONSTRATE WITH
  RECT_P(0,20,320,220);
  TEXTOUT_P("EXAMPLE PROGRAM SCREEN...ACCESSIBLE",0,240/2);
  TEXTOUT_P(WORLD,0,240/4);
  DRAWMENU("Original");
  WAIT(2);
  //NOW DEMONSTRATE ACCESSIBLE USE
    //OPTIONAL:BEST SET BY USER
    FINGERSPELL_s(SECS);
    //OPTIONAL:BEST SET BY USER PROGRAM
    FINGERSPELL_SetWin({320/2,Y0,320,200,0,200,320,220});
    //FINGERSPELL_SetWin({320/2,Y0,320,100,0,20,20,22});
    //END OPTIONAL
    FINGERSPELL(WORLD);
  //END ACCESSIBLE
  //EXAMPLE USER SCREEN RESTORED
 EXPORT FINGERSPELLER()
  //INSTAL GRAPHICS (ONCE IN EACH APP NEEDED)
  FINGERSPELL_BUILDER_TEST();
  //SHOW THE GRAPHICS
  BSL("S");//SHOW CURRENT DATA 1 BY 1
  SHOWAZ();//SHOW ALPHABET PAGE
  WAIT(SECS);WAIT(2);
  EXAMPLE_HELLO_WORLD();
  FREEZE;
05-15-2016, 07:05 PM
Error in
Dont work in calculator build 10077
Leo
05-15-2016, 08:41 PM (This post was last modified: 05-15-2016 09:04 PM by StephenG1CMZ.)
Thanks for that report. The purpose of that BLIT is simply to copy the graphic in G7 to a window on G0. I am not attempting any transparency (maybe later), just a simple copy.
I don't have 10077 here. Are you seeing a compiler error, or something wrong with the graphic?
05-23-2016, 10:45 PM (This post was last modified: 05-23-2016 10:49 PM by StephenG1CMZ.)
Version 0.2 has an improved API demonstrating support for multiple languages.
Note that you should run the Hello World example - otherwise other routines may not be initialised.
FINGERSPELLER.HLP:
Fingerspeller V0.2 Help ©2016 StephenG1CMZ
FINGERSPELLER implements an accessibilty resource for the deaf and visually impaired, using AFiles. Fingerspelling graphics must be provided by the user (One per character).
On systems without access to host files, such as my Android, the visually impaired HUGE characters remain usable.
Multiple languages are supported in an improved API.
Version 0.2 implements a simple A-Z/a-z character set  with no digits.
IMPORTANT: In this version it is essential to 1st run HELLO WORLD (or otherwise INSTALL, Set Language etc.) - Until this is done other routines are not ready for use...
NO LIABILITY ACCEPTED.
Can anyone suggest either a source of graphics in HP ICON format, or a way of accessing the host filestore on Android?
StephenG1CMZ can provide software and systems testing to your requirements in several languages.
 LOCAL VERNUM:=0.2;
 //SHOWS CURRENT LANGUAGE. USERS USE FingersLang() FUNCTION
 EXPORT FingersLang;
 LOCAL WORLD:="Hello World 2016";
 //CUSTOMISE
 LOCAL SECS:=1; //0=KEY WAIT - A SIMPLE WAIT
 LOCAL SHOW_REPLACED_TEXT:=1;//0, 1-ALSO REQUIRES CHEAT MODE
 LOCAL MYHELP:="FINGERSPELLER.HLP";
 LOCAL DIAGNOSTIC:=0;
 LOCAL Y0:=20;//HEADER HEIGHT 20, OR 0 TO USE TOP LINE
 LOCAL DEFAULT_INSTALL:={"A_TEST","HUGE"};
 //FULL VALUES:
 //INPUT DATA RESOLUTION. USER ACCESS BY CharImgSize FUNCTION
 LOCAL CHARIMGSIZE:={22,28};//SUITS TEST DATA. SIGNS PROBABLY LARGER
 //ALTERNATIVELY EXPORT THESE MESSAGES
 //EXPORT ICE_URGENT_MESSAGE;
 LOCAL ICE_URGENT_MESSAGE:={
  "SOS",
  "EVACUATE",
  "EMERGENCY"};
 // END CUSTOM
 LOCAL FINGERLANGS:={};
 LOCAL SZX:=320;
 LOCAL SZY:=220-Y0;
 LOCAL II,JJ,OKC;
 LOCAL ROWS:=5;
 LOCAL COLS:=6;
 //LOCAL MYPX;
 LOCAL FS:={};
 LOCAL FSTMP:="AY_Temp";
 LOCAL STRNG:="";
 LOCAL FILESPEC:="";
 LOCAL CHS,LANGN;
 LOCAL LANG:="A_TEST";
 //HP COMMON
 LOCAL IMP_LIMIT_PRINT:=2000;
 LOCAL ZTypeNUMERIC:=0;
 LOCAL ZTypeSTRING:=2;
 LOCAL ZTypeLIST:=6;
 //END HP COMMON
 JUNKA(FS)
  IF SIZE(FS) THEN //PRECAUTION
   DelAFiles(FS);//Garbage Gone
 SCR_PUT()
  AFiles(FSTMP+"G0"):=G0;//SAVE
  AFiles(FSTMP+"G7"):=G7;
 SCR_GET()
   G0:=AFiles(FSTMP+"G0");
   G7:=AFiles(FSTMP+"G7");
   JUNKA(FSTMP+"G0");
   JUNKA(FSTMP+"G7");
 SHOWAZ (LANG)
  //LOCAL LIN;
  LOCAL CN,XXX,YYY;
    CN:=COLS*II+JJ+1;
    IF CN≤26 THEN
     FS(CN):=LANG+"_"+CHAR(ASC("A")+CN-1);//MUST MATCH BUILD
     G7:=AFiles(FS(CN));
  DRAWMENU(LANG);
  TEXTOUT_P(LANG+"- IMAGINE FINGERSPELL DATA HERE",0,0);
 DISPLAY_ONE (ST)
  LOCAL LANG:=FingersLang;
  //DONT INSIST ON ST==1CH HERE:EG ALLOW "GOOD" OR "E_ACUTE" FILENAMES
  //MSGBOX(LANG);
  G7:=AFiles(LANG+"_"+ST);//SIZE DEFINED BY FILE
  IF DIAGNOSTIC THEN
   PRINT();//IT HAS BEEN REPORTED THAT BLIT FAILS IN 10077 IN V0.1. WONDER WHAT SIZE IT IS?
   PRINT("G7:"+GROBW_P(G7)+","+GROBH_P(G7));
  WAIT(SECS);
   LOCAL CH;
   LOCAL II;
    IF TOPCALL THEN
     //DEMONSTRATE REPLACEMENT:USE A TABLE LATER
     IF CH=="©" THEN
       DO_FSPELL("COPYRIGHT",SHOW_REPLACED_TEXT);
     IF TOPCALL THEN
       TEXTOUT_P(MID(ST,1,II),FWIN(5)+2,FWIN(6));//!!LONG TEXT WILL EXCEED WINDOW!!
      ELSE
       DRAWMENU("");
     DISPLAY_ONE(CH);
    ELSE
 Fingerspell_ST(STRNG)
 //FINGERSPELL THE STRING-INTERNAL USE
  LOCAL ST:=STRNG;
  IF DIM(ST) THEN
   //DO DISPLAY
   SCR_PUT();
   DO_FSPELL(ST,1);
   SCR_GET();
 FINGERSPELL_IN ()
  LOCAL TTL:=CRID;
  LOCAL HLP:={"Enter String to Fingerspell","Enter File to Fingerspell EG: Notes(string) "};
  LOCAL ST:={};
  IF OKC THEN
   Fingerspell_ST(STRNG);
  RETURN STRNG;
 FINGERSPELL_TAP (LANG)
  RECT_P();
  SHOWAZ(LANG);
  TEXTOUT_P("BUTTONS NOT IMPLEMENTED",109,180);
  TEXTOUT_P("KEY ESC TO CONTINUE",109,200);
  WAIT;
  RETURN "TBD";//TBD
 // USER INTERFACE API
 // AY=ACCESSIBILITY
 EXPORT Fingers_s(SECONDS)
 //WAIT SECONDS EACH FINGERSPELLED CHAR
  SECS:=SECONDS;
 EXPORT AY_Windows(WINLIST)
 //SET WINDOW DISPLAY RECTANGLES
 //1-4: WINDOW FOR FINGERSPELL GRAPHIC
 //5-8: WINDOW FOR TEXTLINE
 //OVERLAP: TEXTLINE OBSCURED
  IF SIZE(WINLIST)==8 THEN
   FWIN:=WINLIST;
  RETURN FWIN;
 EXPORT FingersLanguage(LangSTR)
 //SELECT FINGERSPELL LANGUAGE STRING
 //"?" OR WRONG STRING RETURNS CURRENT LANG
 //IDEALLY TEST THAT FILES ARE INSTALLED:NOT IMPLEMENTED HP
 //SELECT "" TO DISABLE FINGERSPELL TBD
  LOCAL ST:=LangSTR;
  LOCAL PP:=POS(FINGERLANGS,ST);
  IF PP THEN //LANGUAGE KNOWN
  FingersLang:=FINGERLANGS(PP);
  RETURN FingersLang;
  //RETURN LANGUAGE:UNCHANGED IF UNKNOWN
  //RETURN TEST IF NOT INSTALLED:TBD
 EXPORT ICE_URGENT_MESSAGES()
 // SELECT 1 OF UP TO 2047 MESSAGES
 //NB WHEN THE PROGRAM IS RE-RUN STRINGS ARE RESET!
  //LOCAL INSTRS:={"To edit list:","ICE_URGENT_MESSAGE:={strings}"};//ONLY WHEN EXPORT
  OKC:=CHOOSE(CHS,"Select Message to Fingerspell",ICE_URGENT_MESSAGE);
  IF OKC THEN
   IF CHS>0 THEN
    PRINT();
    PRINT(ICE_URGENT_MESSAGE(CHS));
    Fingerspell_ST(ICE_URGENT_MESSAGE(CHS));
 EXPORT TranslateDeFingers()
  TRANSLATED:=FINGERSPELL_TAP(LANG);
  RETURN TRANSLATED;
 EXPORT TranslateToFingers()
  RETURN TRANSLATED;
 HELP()
  LOCAL ST:=Notes(MYHELP);
  DEBUG;
  OKC:=CHOOSE(CHS,"",{"As Text","Fingerspell"});
  IF OKC THEN
   PRINT();
   PRINT(MID(ST,1,IMP_LIMIT_PRINT));
   IF CHS==2 THEN
    Fingerspell_ST(Notes(MYHELP));
 ABOUT()
  RECT_P();
  TEXTOUT_P(CRID,0,20);
  TEXTOUT_P(VERNUM,0,40);
  WAIT(1);
  //DEBUG;
  Fingerspell_ST(CRID);
  WAIT;
 EXPORT ABOUT_HELP ()
  OKC:=CHOOSE(CHS,"",{"ABOUT","HELP "+MYHELP});
  IF OKC THEN
   CASE
    IF CHS==1 THEN ABOUT() END;
    IF CHS==2 THEN HELP()  END;
    DEFAULT
 EXPORT Fingerspell(STRNG)
 //FINGERSPELL STRING-EXTERNAL CALL
 EXPORT CharImgSize(XY_LIST)
 //SIZE OF YOUR IMAGE DATA ie LARGEST CHARACTER IN LANGUAGE
 //A SINGLE VALUE IS USED BUT IT COULD VARY...
 //IF SOME IMAGES ARE LARGER THE OTHERS WILL BE SMALL:
 //VARYING THE VALUES WOULD HELP
  IF SIZE(XY_LIST)==2 THEN
   CHARIMGSIZE:=XY_LIST
  END;//OTHERWISE A QUERY
  RETURN CHARIMGSIZE;
 //BUILD DEMO GRAPHICS
 DO_INSTAL(ALANG)
   IF POS(FINGERLANGS,"A_TEST") OR POS(FINGERLANGS,"HUGE") THEN
   //PREPARE FILEPECS
    FS(II):=LANG+"_"+CHAR(ASC("A")+II-1);
   //DEL OLDFILES?
   OKC:=1;
   //DEL OLDFILES
   IF LANG=="A_TEST" THEN
      DelAFiles(FS(II));
     DelAFiles(LANG);
    //BUILD NEW FILES
    DIMGROB_P(G7,CHARIMGSIZE(1)+2,CHARIMGSIZE(2)+20);//OFFSETS AID READABILITY=AVOIDS TEXT AT EDGE
     RECT_P(G7);
     //BLIT_P(G0,G7);  //MAYBE SLOW ENOUGH TO SEE PROGRESS
     //WAIT(0.1);
    END;//FOR
    AFiles(LANG):=CHARSET;//DOCUMENT THE INSTALLATION
  END;  //IF
 EXPORT INSTALL(MYLANGS)
  LOCAL II;
  CASE
   IF TYPE(MYLANGS)==ZTypeNUMERIC THEN //NUM
    IF MYLANGS==0 THEN //DEFAULT I
     INSTALL(DEFAULT_INSTALL);//
   IF  TYPE(MYLANGS)==ZTypeSTRING THEN //ST
    IF DIM(MYLANGS) THEN
     IF MYLANGS=="?" THEN
     ELSE
       INSTALL({MYLANGS});
   IF TYPE(MYLANGS)==ZTypeLIST THEN //LST
     SCR_PUT();
     RECT_P();
     TEXTOUT_P(CRID,0,0);
     FOR II FROM 1 TO SIZE(MYLANGS)  DO
      IF POS(FINGERLANGS,MYLANGS(II)) THEN
       //LANG ALREADY LISTED INSTALLED
      ELSE
       FINGERLANGS:=CONCAT(FINGERLANGS,MYLANGS(II));
      TEXTOUT_P("Install       "+MYLANGS(II),0,20*POS(FINGERLANGS,MYLANGS(II)));
      DO_INSTAL(MYLANGS(II));
    //TEXTOUT_P("Installed: "+MYLANGS(II),0,20*POS(FINGERLANGS,MYLANGS(II)));
      TEXTOUT_P("Installed: ",0,20*POS(FINGERLANGS,MYLANGS(II)));
      //IF INSTALSLOW SHOWAZ("HUGE"); ETC
     END;//FOR
     //WAIT(1);//ALLOW LAST INSTAL TO BE SEEN
     SCR_GET();
    END;//IF
    DEFAULT
  // RETURN LIST OF INSTALLED LANGS
  // NB IT DOES NOT YET VERIFY FILES EXIST
  RETURN FINGERLANGS;
 //EXAMPLE DEMO
 EXAMPLE_DEMO()
  LOCAL STR,TEMPLIST;
    //ENSURE LANGUAGE INSTALLED:ONCE PER APP (CAN BE SLOW)
    // = NOT EVERY RUN
    //DUPLICATES NOT ADDED AGAIN. YOU CAN ADD YOUR OWN LANG
    //EXCEPT FOR HUGE AND A_TEST USER SUPPLIES GRAPHICS
    //INSTALL("MY_OWN_LANG");
    OKC:=FingersLanguage("A_TEST");//THE LANG MUST HAVE BEEN INSTALLED
    Fingers_s(SECS);
    //SHOW THE GRAPHICS ALPHABET FOR INFO
    STR:=TranslateDeFingers();
    TEMPLIST:=AY_Windows({320/2,Y0,320,200,0,200,320,220});
    //AY_SetWin({320/2,Y0,320,100,0,20,20,22});
    //END OPTIONAL
   Fingerspell(WORLD);
  //END ACCESSIBLE
 EXPORT FINGERSPELLER_0_2()
  OKC:=MSGBOX(CRID+"OK to Hello World
NB DO THIS 1st",1);
 //OMITING THE SETUP WITHIN THE DEMO
 //LEAVES SOME VITAL STUFF NOT INITIALISED
 //FIX TBD
 IF OKC OR 1 THEN
   EXAMPLE_DEMO();
  FREEZE;
05-31-2016, 09:09 PM (This post was last modified: 05-31-2016 09:23 PM by StephenG1CMZ.)
Version 0.3 now implements a substitution list - so if you see 0 you can say "zero".
The need to run Hello World has been fixed.
 READY();//FORWARD
 LOCAL VERNUM:=0.3;
 EXPORT FingersReady:=0;
 EXPORT FingersLang;
 //CUSTOMISE
 LOCAL ICEFS:="ICE_URGENT_MESSAGES";
 LOCAL SLFS:="FINGERSPELLERSL"; //SUBSTITUTION LIST
 //FULL VALUES:
 //ALTERNATIVELY READFILE FOR CUSTOMISED TEXT
 LOCAL ICE_URGENT_MESSAGE_LST:={
  "SOS",
  "EVACUATE",
  "EMERGENCY"};
 // END CUSTOM
 LOCAL SZX:=320;
 LOCAL SZY:=220-Y0;
 LOCAL II,JJ,OKC;
 LOCAL ROWS:=5;
 LOCAL COLS:=6;
 //LOCAL MYPX;
 LOCAL FS:={};
 LOCAL STRNG:="";
 LOCAL FILESPEC:="";
 LOCAL CHS,LANGN;
 LOCAL SUBSTL:={};
 //HP COMMON
 LOCAL ZTypeLIST:=6;
 //END HP COMMON
 EXISTS(FS)
 BEGIN //NOT IMPLEMENTED
  RETURN 1;
 JUNKA(FS)
 SCR_PUT()
  //MSGBOX("PUT:"+FSTMP);
 SCR_GET()
   //MSGBOX("GET:"+FSTMP);
   //DEBUG;
   JUNKA(FSTMP+"G0");
   JUNKA(FSTMP+"G7");
 SHOWAZ (LANG)
  //LOCAL LIN;
  LOCAL CN,XXX,YYY;
    CN:=COLS*II+JJ+1;
    IF CN≤26 THEN
     G7:=AFiles(FS(CN));
  DRAWMENU(LANG);
 DISPLAY_ONE (ST)
  //MSGBOX(LANG);
  IF DIAGNOSTIC THEN
  WAIT(SECS);
 LOAD_SL()
 //LOAD SUBSTITUTION LIST FOR THAT LANG
  SUBSTL:=EXPR(Notes(SLFS));
 ZSUBST(CH)
 //! SHOULD WE TEST ASCII NUMBERS OR CHARS
  LOCAL II;
  LOCAL ITEM,ITEMIN,ITEMCODE;
  LOCAL SUBTEXT:="";
  FOR II FROM 1 TO SIZE(SUBSTL) DO
   ITEM:=SUBSTL(II);
   ITEMIN:=ITEM(1);
   //IF ITEM A CH MAKE IT A CODE:WILL FAIL IF ITEM IS STRIG
   IF TYPE(ITEMIN)==ZTypeSTRING THEN
    ITEMCODE:=ASC(ITEMIN);
   ELSE
    ITEMCODE:=ITEMIN;
   //DEBUG;
   CASE
    IF TYPE(ITEMCODE)==ZTypeNUMERIC THEN //ASCII NUM
     IF CH==CHAR(ITEMCODE) THEN
      SUBTEXT:=ITEM(2);
    IF TYPE(ITEMCODE)==ZTypeLIST THEN //UNICODE
     IF CHAR(ITEMCODE)==CH THEN
      //MSGBOX(ITEMCODE);
      SUBTEXT:=ITEM(2);
   DEFAULT
  IF CH=="©" THEN
   SUBTEXT:="COPYRIGHT";
  RETURN SUBTEXT;
   LOCAL CH;
   LOCAL II;
   LOCAL SUBTEXT:="";
    IF TOPCALL THEN
     //DEMO
     SUBTEXT:=ZSUBST(CH);
     IF SUBTEXT=="" THEN
     ELSE
       DO_FSPELL(SUBTEXT,SHOW_REPLACED_TEXT);
     IF TOPCALL THEN
      ELSE
       DRAWMENU("");
     DISPLAY_ONE(CH);
    ELSE
  LOCAL ST:=STRNG;
  IF DIM(ST) THEN
   //DO DISPLAY
   READY();//DO BEFORE PUT (OR OPTIMISE PUTGET PUTGET)
   SCR_PUT();
   DO_FSPELL(ST,1);
   SCR_GET();
 FINGERSPELL_IN ()
  LOCAL TTL:=CRID;
  LOCAL HLP:={"Enter String to Fingerspell (Quotes Not needed)","Enter File to Fingerspell EG: Notes(string) "};
  LOCAL ST:={};
  OKC:=INPUT({{STRNG,[ZTypeSTRING]},{FILESPEC,[2]}},TTL,LBL,HLP,{"",""},{STRNG,FILESPEC});
  IF OKC THEN
  RETURN STRNG;
  RECT_P();
  SHOWAZ(LANG);
  WAIT;
  RETURN "TBD";//TBD
 HELP()
  IF OKC THEN
   PRINT();
   IF CHS==2 THEN
 ABOUT()
  LOCAL KK;
  RECT_P();
  TEXTOUT_P("Esc To Exit",0,80);
  TEXTOUT_P("Enter To Fingerspell",0,100);
  KK:=WAIT;
  //HAVE TO WAIT CUZ  BAD SUBST LIST CAN KILL SPELLER
  IF KK≠4 THEN
  WAIT;
 // AY=ACCESSIBILITY
  IF OKC THEN
   CASE
    DEFAULT
  SECS:=SECONDS;
   FWIN:=WINLIST;
  RETURN FWIN;
  LOCAL ST:=LangSTR;
  LOAD_SL();
  RETURN FingersLang;
  //MSGBOX()
  ICE_URGENT_MESSAGE_LST:=EXPR(Notes(ICEFS));
  OKC:=CHOOSE(CHS,"Select Message to Fingerspell",ICE_URGENT_MESSAGE_LST);
  IF OKC THEN
   IF CHS>0 THEN
    PRINT();
    PRINT(ICE_URGENT_MESSAGE_LST(CHS));
    Fingerspell_ST(ICE_URGENT_MESSAGE_LST(CHS));
  RETURN TRANSLATED;
  RETURN TRANSLATED;
 EXPORT TranslateFingers()
  LOCAL STR;
  OKC:=CHOOSE(CHS,"","Translate De Fingers","Translate To Fingers");
  IF OKC THEN
   IF CHS==1 THEN
   ELSE
    STR:=TranslateToFingers();
  RETURN CHARIMGSIZE;
 DO_INSTAL(ALANG)
   //PREPARE FILESPECS
   //DEL OLDFILES?
   OKC:=1;
   //DEL OLDFILES
      DelAFiles(FS(II));
     DelAFiles(LANG);
    //BUILD NEW FILES
     RECT_P(G7);
     //WAIT(0.1);
    END;//FOR
  END;  //IF
  LOCAL II;
  CASE
     ELSE
       INSTALL({MYLANGS});
     SCR_PUT();
     RECT_P();
      ELSE
     END;//FOR
     SCR_GET();
    END;//IF
    DEFAULT
  RETURN FINGERLANGS;
 EXPORT RESET()
 //RESETS TO USEFUL DEFAULTS
  LOCAL STR,TEMPLIST;
  Fingers_s(SECS);
  FingersReady:=1;
 READY()
  IF FingersReady==0 THEN
   RESET();
 //EXAMPLE DEMO
 EXAMPLE_DEMO()
  LOCAL STR,TEMPLIST;
    // = NOT EVERY RUN
    Fingers_s(SECS);
    //END OPTIONAL
   Fingerspell(WORLD);
  //END ACCESSIBLE
 EXPORT FINGERSPELLER_0_3()
  //INSTALL(DEFAULT_INSTALL);
  RESET();
Esc to use",1);
 IF OKC THEN
   EXAMPLE_DEMO();
  FREEZE;
FINGERSPELLER.HLP:
Fingerspeller V0.3 Help ©2016 StephenG1CMZ
NO LIABILITY IS ACCEPTED.
ONLY THE 1st 2KB OF THIS HELPFILE IS VISIBLE FROM HELP. USE Notes.
Version 0.3 implements a simple A-Z/a-z character set.
A valid PPL LIST format Substitution list must exist. Characters to be substituted can be listed as ascii code (not unicode), or 1-character string (either ascii or unicode).
Eg: Render "(" as bracket, as open bracket, or ignore it?
COMMANDS
Fingerspeller_s: n
  WAIT per character rendered
AY_Windows: {8 coordinates}
  Always use two rectangles (graphic,text)
FingersLanguage: ""
  Select an installed language
ICE_URGENT_MESSAGES:
  Customise up to 2047 prepared messages
TranslateDeFingers
  NOT IMPLEMENTED:Graphics to text
TranslateToFingers:
 Translates (renders) input strings and files
TranslateFingers:
 Translates (renders) in either direction
 (see above)
Fingerspell: ""
 Translate string parameter
CharImgSize: {x,y}
  Size of your graphics images
INSTALL: string or {strings}
  Installs languages ready for        FingersLanguage. This can take a few seconds if building graphics.
  A_TEST and HUGE graphics are used for this demo. For ASL and BSL:
  USERS MUST PROVIDE OWN GRAPHICS!
RESET:
 Resets these commands
FILES: AFiles or Notes
AY_TempG*: Temporary
FINGERSPELLERSL: Substitution list
FINGERSPELLER.HLP: This Text
ICE_URGENT_MESSAGES: List
<FingerLanguage>_A to _Z: Graphics
FAQs
Are MY graphics saved?
Yes, normal fingerspelling saves and restores for you=fingerspell,INSTALL.
But not Help or interaction=Translate...
Unicode?
Unicode can be recognised in the substitution list string. It cannot yet be rendered.
Troubleshooting
1 Input files exist.
2 If ABOUT will not fingerspell,
check the syntax of FINGERSPELLERSL.
Similarly check ICE_URGENT_MESSAGES.
Both are lists.
3 If instead of rendering Notes(name), you type in name- Program(name) will run!
BE CAREFUL NOT TO DELETE  ALL.
HELP THE AUTHOR
Example FINGERSPELLERSL:
  {   6,"ACK"},
  {   7,"BEL"},
  {   8,"BS"},
  { 21,"NAK"},
 { 33,"SHRIEK"},
 {34,"QUOTES"},
 { 35,"HASH"},
 { 36,"DOLLAR"},
 { 37,"PERCENT"},
 { 38,"AMPERSAND"},
 { 39,"QUOTE"},
 { 40,"BRACKETS"},
 { 41,"BRACKETS"},
 { 42,"ASTERISK"},
 { 43,"PLUS"},
 { 44,"COMMA"},
 { 45,"MINUS"},
 { 46,"PERIOD"},
 { 47,"SLASH"},
 { 58,"COLON"},
 { 59,"SEMICOLON"},
 { 60,"LESS THAN"},
 { 61,"EQUALS"},
 { 62,"GREATER THAN"},
 { 63,"QUERY"},
 { 64,"AT"},
 { 91,"SQUARE BRACKET"},
 { 92,"BACKSLASH"},
 { 93,"SQUARE BRACKET"},
 { 94,"HAT"},
 { 95,"HYPHEN"},
 { 123,"BRACE"},
 { 124,"BAR"},
 { 125,"BRACE"},
 { 126,"APPROXIMATELY"},
 {"0","ZERO"},
 {"1","ONE"},
 {"2","TWO"},
 {"3","THREE"},
 {"4","FOUR"},
 {"5","FIVE"},
 {"6","SIX"},
 {"7","SEVEN"},
 {"8","EIGHT"},
 {"9","NINE"},
  { 127,"DEL"}
Example ICE URGENT MESSAGES:
{"SOS",
"EVACUATION"}
Hope this proves useful.
