DIMGROB() Restrictions
05-17-2015, 04:30 PM (This post was last modified: 05-17-2015 06:12 PM by alexgt.)
Hey I am new here and mostly active at CodeWalr.us but I need help on trying to solve an issue I have with the DIMGROB() command. Before the latest firmware update MinePrime, my current project, worked fine but now when I use:
DIMGROB_P(G1,1600,800);
It doesn't work Sad.
Here is the original post http://codewalr.us/index.php?topic=404.new#new
05-17-2015, 10:23 PM
RE: DIMGROB() Restrictions
Yeah I was wondering about that too and I am worried, because this means that many older HP PPL programs (mostly games) no longer run on the new firmware. Not that I have an issue with limiting GROB sizes since we can use workarounds but in some cases that can make things much more complicated to code.
Plus this also means that mViewer will be severely limited now.
-Dream of Omnimaga
https://djomnimaga.music-2000.com
05-18-2015, 05:58 AM
I just checked the code and I do not see any restriction on dimgrob. I have not tested on the real calculator, just on the emulator, but it works there. Are you sure that you are getting an error?
Cyrille
05-18-2015, 05:01 PM
After a while I tested it again and it worked so maybe you have to wait a bit after you update the firmware.
Thanks for the help.
