HP 95LX: Derive Maths Programme
03-09-2015, 08:22 AM
I have a Derive version 2.5 application card (also works on 100 & 200LX).
Does anyone know if there were any updated cards with a later version number?
03-09-2015, 09:50 AM (This post was last modified: 03-09-2015 10:16 AM by Gerson W. Barbosa.)
RE: HP 95LX: Derive Maths Programme
At the time of this review the latest version was 4.13.
P.S.: Not sure whether this was ever available as an application card for the HP-200LX though, so your question remains answered.
03-09-2015, 10:15 AM
(03-09-2015 09:50 AM)Gerson W. Barbosa Wrote:  At the time of this review the latest version was 4.13.
But is that version on an application card?
I think 4.13 is a miss-print for 3.13.
03-09-2015, 10:26 AM (This post was last modified: 03-09-2015 10:29 AM by Gerson W. Barbosa.)
Very unlikely to ever have been available as an HP-200LX application card, I fear.
Quoting from the review:
"Speedwise, the new version seems about the same as the 3.x versions."
This might imply that one was version 4.13 indeed.
03-09-2015, 10:33 AM
I tried, at the time, to keep up with developments in Derive & have a version 3.13 running on a 200LX, it won't work on the 95LX.
I guess versions later than 3.13 won't run on the 200LX - does anyone have a version 4.x loaded that functions correctly?
My original query was only concerning versions on application cards.
03-09-2015, 10:49 AM
(03-09-2015 10:33 AM)Gerald H Wrote:  I guess versions later than 3.13 won't run on the 200LX - does anyone have a version 4.x loaded that functions correctly?
It seems from this archive that Derive 4.11 can run on the 200LX: DERIVE with Acrospin for 200LX 4.11.
(03-09-2015 10:33 AM)Gerald H Wrote:  My original query was only concerning versions on application cards.
Do you have a picture of your Derive application card?
03-09-2015, 11:44 AM
Here a picture of card:
03-09-2015, 12:36 PM
Thanks Didier, yes 4.11 works OK on 100LX.
03-09-2015, 12:40 PM
Thanks for the picture :-)
03-09-2015, 02:23 PM
(03-09-2015 12:36 PM)Gerald H Wrote:  Thanks Didier, yes 4.11 works OK on 100LX.
Also, of course, on my 200LX. Merci beaucoup, Didier!
02-09-2017, 07:35 PM
Were there any special drivers that you needed to install (for the screen, perhaps) in order for derive to run? I remember trying to get an old version (was it 5, perhaps?) to run and could not. I assumed that as long as you had a DOS environment (which the LX does, sort of) that it would just be a matter getting the appropriate display drivers. However, I never got it to work (due to lack of drivers.)
Graph 3D | QPI | SolveSys
02-10-2017, 02:01 AM (This post was last modified: 02-10-2017 02:04 AM by Gerson W. Barbosa.)
I don't remember where I got it from, but this link says this Derive version is optimized for the HP-200's CGA monochrome display. Unfortunately the dark stain in the center of my 200LX grew to an extent that has made it unusable. I replaced the display once for the same reason.
http://vetusware.com/download/DERIVE%20w...1/?id=9186
Good luck!
Gerson.
02-10-2017, 02:06 AM
Thank you, Gerson! I'll give a whirl and see where it takes me :-)
09-18-2017, 05:43 PM
(03-09-2015 10:26 AM)Gerson W. Barbosa Wrote:
(03-09-2015 10:15 AM)Gerald H Wrote:  I think 4.13 is a miss-print for 3.13.
I am a bit slow to join, but I have already spent quite sime time get hold of version 4.13. All I found was version 4.11, which is also the latest version mentioned by the derive user group. So 4.13 was either indeed a typo or very rare.
BTW, derive for dos also runs quite well in a dos box on my android tablet. I prefer it over the current alternatives (e.g. xcas, geogebra).
09-19-2017, 02:17 PM (This post was last modified: 09-19-2017 02:18 PM by Martin Hepperle.)
Here is a Derive software timetable which I have composed:
Year   V   System
1979           muMath
1988   1       MS-DOS, implemented in MuLISP
       1.60    MS-DOS
       1.61    MS-DOS
1990   2       MS-DOS
       2.01    MS-DOS
1992   2.5x    MS-DOS
1994   3.00    MS-DOS
       3.1     MS-DOS
       3.11XM  expanded memory usage
       3.12    MS-DOS
       3.13    MS-DOS
       3.14    MS-DOS
1996   4       MS-DOS, Windows
       4.03    MS-DOS, Windows, not Windows XP
       4.04    MS-DOS, Windows
       4.11    MS-DOS, Windows
       4.13    MS-DOS, Windows, not Windows 2000
2000   5       Windows
       5.02    Windows, bug-fix update
2001   5.05    Windows
2002   5.06    Windows, bug-fix update
2003   6       Windows
2004   6.01    Windows 98, XP, 2000
       6.1     Windows 98, XP, 2000
2007   Texas Instruments stops development and distribution
1999 takeover of Soft Warehouse by Texas Instruments
2000 TI-92
This table may contain errors, feel free to correct.
Derive User Group (German/English)
http://www.austromath.at/dug/index.htm
also at
https://archive.org/search.php?query=Derive
Martin
