4-level stack manipulation on 12c
03-02-2015, 03:18 AM
If my 4-level stack on my 12c contains:
t - don't care
z - don't care
y - 17
x - 5
and I want it to contain:
t - 17
z - 5
y - 17
x - 5
is there an elegant way to achieve that using only ENTER, roll down, and x<->y?
03-02-2015, 03:40 AM (This post was last modified: 03-02-2015 03:40 AM by Mark Hardman.)
RE: 4-level stack manipulation on 12c
(03-02-2015 03:18 AM)Don Shepherd Wrote:  If my 4-level stack on my 12c contains:
t - don't care
z - don't care
y - 17
x - 5
t - 17
z - 5
y - 17
x - 5
If you also allow Rup it can be done in six steps:
Enter, Enter, Rup, Enter, Rdn, x<>y
t   0    0   17    5    5   17   17
z   0   17    5    5    5    5    5
y  17    5    5    5   17    5   17
x   5    5    5   17   17   17    5
The Rup can be replaced with three Rdn for a total of eight steps:
Enter, Enter, Rdn, Rdn, Rdn, Enter, Rdn, x<>y
t   0    0   17    5    5    5    5   17   17
z   0   17    5   17    5    5    5    5    5
y  17    5    5    5   17    5   17    5   17
x   5    5    5    5    5   17   17   17    5
I'm sure someone can do better.
Ceci n'est pas une signature.
I'm sure someone will find an 'elegant' way in fewer steps, but:
17
5 Enter ^
17
5
5 Enter ^
17
5
5
5 R v
5
17
5
5 R v
5
5
17
5 R v
5
5
5
17 Enter ^
5
5
17
17 R v
17
5
5
17 x <> y
17
5
17
5 Task complete
Total 8 operations.
Yep, somebody will definitely find a shorter one. But at least this is straightforward. ;-)
Dale
03-02-2015, 03:50 AM
Mark,
I guess us old HP-25 users think similarly... and simultaneously! It may chew up 8 steps, but at least it's easy to remember. Repeat after me:
"Enter - Enter - Down Down Down - Enter - Down - Exchange"
03-02-2015, 03:57 AM (This post was last modified: 03-02-2015 04:02 AM by PANAMATIK.)
t - don't care
z - don't care
y - 17
x - 5
t - 17
z - 5
y - 17
x - 5
 t z x x y x z z x y y
 z y z z x y x x x x x
 y x y x z x y x y x y
 x x x y x z x y y y x
Perhaps not the fastest approach, but it was asked to be elegant!
Bernhard
03-02-2015, 03:59 AM (This post was last modified: 03-02-2015 04:05 AM by Mark Hardman.)
(03-02-2015 03:50 AM)Dale Reed Wrote:  Mark,
I would say that great minds think alike.
03-02-2015, 08:14 AM
In fewer keystrokes but not sticking to the operations available:
Assuming that: 17 ENTER 5 has already occurred.
Then:
        1 7 ENTER 5
Pauli
03-02-2015, 08:19 AM
t - don't care
z - don't care
y - 17
x - 5
t - 17
z - 5
y - 17
x - 5
Sigma+
RCL 2
RCL 4
RCL 2
But it does not count (...too many preconditions).
03-02-2015, 10:48 AM
(03-02-2015 08:19 AM)Csaba Tizedes Wrote:  But it does not count (...too many preconditions).
If preconditions are allowed:
RCL 0 (R0 contains 17)
RCL 1 (R1 contains 5)
Shortest key sequence with preconditions allowed:
R/S Smile
03-02-2015, 11:40 AM
R/S Smile
Stretching the preconditions a bith further and assuming 17 and 5 are on the stack:
2dup
... hp71b in forth mode.
Best regards -Ray
03-02-2015, 12:28 PM
6 steps:
ENTER
ENTER
RDN
X<>Y
LASTX
Cheers, Werner
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE
03-02-2015, 12:31 PM
(03-02-2015 03:18 AM)Don Shepherd Wrote:  is there an elegant way to achieve that using only ENTER, roll down, and x<->y?
The attached file contains all the possible stack manipulation.
From the french book "Programmer HP-41"
Attached File(s) Thumbnail(s)
03-02-2015, 12:45 PM
(03-02-2015 12:28 PM)Werner Wrote:  6 steps:
ENTER
ENTER
RDN
X<>Y
LASTX
Cheers, Werner
Yes, this is REALLY elegant! Grat!
03-02-2015, 01:49 PM
ENTER
ENTER
RDN
X<>Y
LASTX
Cheers, Werner
Well, I have to agree with Csaba. Elegant!
I hadn't thought about LastX, I admit, but you sure made good use of that function in this case.
Thanks to all. Lots of great minds out there.
Don
03-02-2015, 03:30 PM (This post was last modified: 03-02-2015 03:33 PM by Gene.)
Tony Hutchins gave this 7-step solution without using LASTX.
ENTER
ENTER
CLx
Roll Down
X<>Y
Roll Down
But more importantly, the PDF where this and a large number of such ideas is found here:
Stack Rearrangements
You can find this solution by searching for ABAB, which represents XYXY as the contents of the four level RPN stack.
03-02-2015, 03:53 PM (This post was last modified: 03-02-2015 05:41 PM by Don Shepherd.)
Thanks Gene. A fascinating book.
I just realized I have the book upon which Tony's book is based, "Algorithms for RPN Calculators," in my bookcase!
But I wouldn't have known about Werner's 6-step solution from that book, I suppose.
Don
03-03-2015, 10:54 PM (This post was last modified: 03-03-2015 10:57 PM by Marcus von Cube.)
(03-02-2015 03:30 PM)Gene Wrote:  Stack Rearrangements
That's why we have included the shuffle command ⇄ in the 34S. It allows to shuffle the lower four stack levels in an arbitrary fashion with a single command. The main purpose of this command is readability in a program but it works interactively as well. To accomplish the requested task the command would be:
⇄ XYXY
Self explanatory, isn't it?
A solution that works for all calculators which can directly recall the stack:
RCL Y
RCL Y
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
03-03-2015, 11:25 PM
When I saw the discussion of management of operational scale I remembered a paper from Tony Hutching where the author presents a series of tables to relocate data (see attached). Perhaps it would be useful to analyze this issue
I take this opportunity to ask for a brief management explanation of Tony job and if it is useful today for programming the HP 35s calculator. Thank you very much for your attention, Pedro
Attached File(s)
.pdf  xyzt - Tony Huttchiins Tables.pdf (Size: 301.28 KB / Downloads: 90)
03-04-2015, 06:52 AM
(03-03-2015 11:25 PM)PedroLeiva Wrote:  When I saw the discussion of management of operational scale I remembered a paper from Tony Hutching where the author presents a series of tables to relocate data (see attached). Perhaps it would be useful to analyze this issue
Same as Gene's.
Greetings,
    Massimo
03-04-2015, 09:50 AM
Same as Gene's.
Smile
My apologies. I read over what Gene had written, and did not open the file. Sorry. But I still wonder if Tony tables are useful today, and what is the reason of saving so much programming steps. Pedro
