Round a decimal value to fraction using Farey series
12-11-2013, 08:44 PM (This post was last modified: 12-13-2013 06:10 AM by patrice.)
Round Vl to best fraction with denominator smaller than DMax
EXPORT FareyMax(Vl, DMax)
// Round a Vl to the best fraction with denominator < DMax
LOCAL VlE, Tmp;
LOCAL DbN,DbD, FnN,FnD, RsN,RsD,RsE;
VlE:= ABS(Vl);
DbN:= IP(VlE); DbD:=1; FnN:=DbN+1; FnD:=1;
RsN:= ROUND(VlE,0); RsD:= 1; RsE:= ABS(VlE-(RsN/RsD));
WHILE DbD+FnD <= DMax DO
  Tmp:= (DbN+FnN)/(DbD+FnD);
  IF RsE > ABS(VlE-Tmp) THEN RsN:= (DbN+FnN); RsD:= (DbD+FnD); RsE:= ABS(VlE-(RsN/RsD)); END;
  IF Tmp < VlE THEN DbN:= (DbN+FnN); DbD:= (DbD+FnD); ELSE FnN:= (DbN+FnN); FnD:= (DbD+FnD); END;
RETURN "'"+SIGN(Vl)*RsN+"/"+RsD+"'";
Round Vl to best fraction with Vl-Error < Fraction < Vl+Error
EXPORT FareyDelta(Vl, Error)
// round Vl to the smallest fraction with |Vl - fraction| < Error
LOCAL VlE, Tmp;
VlE:= ABS(Vl);
WHILE RsE > Error DO
Patrice
“Everything should be made as simple as possible, but no simpler.” Albert Einstein
12-13-2013, 04:18 AM
RE: Round a decimal value to fraction using Farey series
FYI: The INT (integer-part) function no longer exists in the current firmware. You must replace INT with IP for the above programs to work.
<0|ɸ|0>
-Joe-
12-13-2013, 06:13 AM (This post was last modified: 12-13-2013 06:24 AM by patrice.)
Ooops, forgot to recheck before posting.
Done. Note the simplified RETURN
Patrice
12-21-2013, 09:04 PM
Here is an update.
The program is made for Home but should work in CAS
It list all successives fractions in terminal as they get better
Exemple: FareyMax(π;10000)
LOCAL VlE, Tmp;
PRINT();
VlE:= ABS(Vl);
PRINT(SIGN(Vl)*RsN+"/"+RsD);
  IF RsE > ABS(VlE-Tmp) THEN RsN:= (DbN+FnN); RsD:= (DbD+FnD); RsE:= ABS(VlE-(RsN/RsD)); PRINT(SIGN(Vl)*RsN+"/"+RsD);END;
// RETURN EXPR("QUOTE("+SIGN(Vl)*RsN+"/"+RsD+")");
Patrice
06-07-2014, 02:21 AM (This post was last modified: 06-17-2014 12:44 AM by patrice.)
Update for Rev 6030
#pragma mode( separator(.,;) integer(h64) )
// rev 6030 update
EXPORT RoundFract(V, F)
RETURN ROUND(V*F,0)/F;
LOCAL VlE, Tmp;
PRINT();
VlE:= ABS(Vl);
PRINT(STRING(SIGN(Vl)*RsN,2,0)+"/"+STRING(RsD,2,0));
  IF RsE > ABS(VlE-Tmp) THEN RsN:= (DbN+FnN); RsD:= (DbD+FnD); RsE:= ABS(VlE-(RsN/RsD)); PRINT(STRING(SIGN(Vl)*RsN,2,0)+"/"+STRING(RsD,2,0));END;
// RETURN "'"+STRING(SIGN(Vl)*RsN,2,0)+"/"+STRING(RsD,2,0)+"'";
RETURN EXPR("QUOTE("+STRING(SIGN(Vl)*RsN,2,0)+"/"+STRING(RsD,2,0)+")");
LOCAL VlE, Tmp;
VlE:= ABS(Vl);
EXPORT FareyDisp(Vl,Rnd)
// round Vl to the smallest fraction that match the display
LOCAL VlE, Tmp;
VlE:= ABS(ROUND(Vl,Rnd));
RsN:= ROUND(VlE,0); RsD:= 1; RsE:= ABS(VlE-ROUND(RsN/RsD,Rnd));
WHILE RsE > 0 DO
  IF RsE > ABS(VlE-Tmp) THEN RsN:= (DbN+FnN); RsD:= (DbD+FnD); RsE:= ABS(VlE-ROUND(RsN/RsD,Rnd)); END;
Nota: if you want FareyMax to be a simple function, just remove all PRINT commands from source code.
Patrice
06-14-2014, 07:01 PM
This is great, Patrice!
06-17-2014, 12:45 AM
Corrected a typo in my last message (in function FareyDelta)
Patrice
