New HP-35 simulator for iPhone
01-29-2015, 12:18 PM
It felt kind of missing, so I finally added the HP-35 to my stable of HP calculator simulators.
Designed for the iPhone, it almost feels like the real thing, especially on the iPhone 6.
  • RPN-35 SD - Complete, photo-realistic simulation of the HP-35 for iPhone
  • Switch between version 3 (original style) and version 4 (with key legends molded into keys)
  • Vintage mode mimics HP-35 very closely (arithmetic errors excepted)
  • "Enhanced Memory" mode provides non-volatile memory, Last X, and 9 registers with HP-45-like register arithmetic
  • Decimal points light up when battery runs low
For details, check out my homepage.
01-29-2015, 01:40 PM
RE: New HP-35 simulator for iPhone
(01-29-2015 12:18 PM)Willy R. Kunz Wrote:  It felt kind of missing, so I finally added the HP-35 to my stable of HP calculator simulators.
It looks excellent (like the prior models), and the choice of different versions is a real nice touch for collectors and HP heads like us.
Do you have any plans of learning to speak Android?
01-29-2015, 01:47 PM
Any chance you could add a red dot on the V3 skin when the emulator is turned on?
01-29-2015, 02:48 PM
(01-29-2015 01:47 PM)Gene Wrote:  Any chance you could add a red dot on the V3 skin when the emulator is turned on?
On a V3? That's nonsense.
Greetings,
    Massimo
01-29-2015, 03:36 PM
Will it work properly on an iPad ? I guess for only $1.99 it's worth a try.
01-30-2015, 09:50 AM
Well, CuVee Software is just a one-man-show. Supporting and improving 10 apps in the iTunes Store keeps me busy enough... Sorry.
01-30-2015, 09:55 AM
(01-29-2015 03:36 PM)Michael de Estrada Wrote:  Will it work properly on an iPad ? I guess for only $1.99 it's worth a try.
Yes, no problems on the iPad. Works great in 2x (full-screen) mode. However, since the iPad's aspect ratio is 4:3, the HP-35 looks a bit "fat", like on an iPhone 4. The iPhone 5 and 6 more closely follow the aspect ratio of the real HP-35.
01-30-2015, 10:04 AM
It's lovely! And I always wanted a Version 4. Thanks for creating this Willy!
Regards, Bob
01-30-2015, 09:21 PM (This post was last modified: 01-30-2015 09:23 PM by anetzer.)
Willy,
your emulators are most impressive. Next to the i41CX+ they are amongst the things I mainly enjoy on my iOS devices. Thank you very much indeed!
But now that you are addressing "missing" items: I would so very much welcome a versatile emulator of the much younger but equally classic HP-71B on that platform. It is a true pity that so far no one has taken up that task...
a.
01-30-2015, 10:41 PM
(01-30-2015 09:50 AM)Willy R. Kunz Wrote:  Well, CuVee Software is just a one-man-show. Supporting and improving 10 apps in the iTunes Store keeps me busy enough... Sorry.
Did you use original HP microcode emulation for your emulator?
I downloaded and enjoyed it very much.
Thanks Bernhard
01-31-2015, 09:56 AM
(01-30-2015 09:21 PM)anetzer Wrote:  I would so very much welcome a versatile emulator of the much younger but equally classic HP-71B on that platform. It is a true pity that so far no one has taken up that task...
I remember the HP-71B. I used to write programs for it in my working days. A simulation would be quite a job, probably requiring several people (user interface, graphics, BASIC interpreter.) It would also require a working HP-71 to verify proper operation of the simulator. Taken together, an RPN-71 is definitely not in my ballpark...
01-31-2015, 10:05 AM
(01-30-2015 10:41 PM)PANAMATIK Wrote:  Did you use original HP microcode emulation for your emulator?
Thanks Bernhard
No, all my calculators are built from scratch, based on physical models and manuals. That's why I call them simulators, rather than emulators. (Besides, I don't think microcode is available for the HP-70.)
The advantage of simulators is total freedom in expanding the capabilities of the calculator in any way you wish.
Since I don't own an HP-35 anymore, in order to verify RPN-35's proper operation, I relied on Maciej Bartosiak's emulator, which is microcode-based.
01-31-2015, 11:28 PM
Thanks Bernhard
Yes, simulation is faster and is open for any expansion but needs more work and never is exactly the original. I felt some limits of emulation in my ACT HP-25 emulator, i.e. I coudn't give a single program more than 49 program steps. However the hardware can be updated any time if somebody (me?) writes HP-25 simulator code from scratch, using C standard math.
If somebody needs the HP-70 microcode, I would be able to extract it, if he can give me an HP-70 and allows me to take it apart.
Just to mention this another time: Your simulators are great and I like the photorealistic skin. For my taste it would be even more perfect, if the info and setting symbols would be invisible.
Thanks
Bernhard
02-01-2015, 03:11 PM
(01-31-2015 11:28 PM)PANAMATIK Wrote:  For my taste it would be even more perfect, if the info and setting symbols would be invisible.
Thanks
Bernhard
I heard you. The next update will allow you make the buttons invisible but still working. You'll also get version 1 (with the red dot) and version 2 (the same as v3 since I don't show the front label anyway.) No simulation of the arithmetic problems of v1, though.
