Help with a formula
01-20-2015, 11:02 PM
Help with a formula
Trying to solve the following for "t" - but hitting bumps.
G(t)
...and WolframAlpha ignores me...
solve for t
Any hints or pointers?
01-20-2015, 11:10 PM
RE: Help with a formula
(01-20-2015 11:02 PM)Geir Isene Wrote:  Any hints or pointers?
I don't see any algebraic solution (sum of exponentials, logs with added constants... I don't think you can solve this one).
My suggestion is to give up.
(use a numeric method to find roots for 't' if you need to solve for a specific value).
Claudio
01-21-2015, 02:27 PM
(01-20-2015 11:02 PM)Geir Isene Wrote:  Trying to solve the following for "t" - but hitting bumps.
G(t)
solve for t
Very interesting! Try to represent ln(e^###) in some other form. Even AFX-2.0 tells "syntax error", not HP-50G.
HP-50g, HP-48gii, TI-83 plus, FX-2.0, CFX-9850GB plus
01-21-2015, 08:09 PM
Could you please explain further your problem ?
Solving t of G(t): what does it refer to ?
Dominique
01-21-2015, 08:13 PM (This post was last modified: 01-21-2015 08:15 PM by Geir Isene.)
(01-21-2015 08:09 PM)Dominique Wrote:  Hi,
Solving t of G(t): what does it refer to?
Here: http://isene.me/2015/01/10/hidden-risk-o...urcing-it/ (bottom equation)
I specifically want to know what "t" is when G(t)=0
01-22-2015, 04:37 AM
(01-21-2015 08:13 PM)Geir Isene Wrote:  I specifically want to know what "t" is when G(t)=0
\(0 = \frac{T}{9}(\ln(e^\frac{8t}{T}+e^4)-4)(1+D) - Dt\)
\(Dt = \frac{T}{9}\ln(e^{\frac{8t}{T}-4}+1)(1+D)\)
\(t = \frac{T(1+D)}{9D}\ln(1+e^{\frac{8t}{T}-4})\)
This fixed point equation can be solved iteratively. With T=24 and D=0.5 I got t=0.1527. That's probably not what you want. However there's another fixed point at t~18.71 but unfortunately it's not attractive.
In these situations we can use \(f^{-1}(t)=t\) instead:
\(\frac{9D}{T(1+D)}t=\ln(1+e^{\frac{8t}{T}-4})\)
\(e^{\frac{9D}{T(1+D)}t}-1=e^{\frac{8t}{T}-4}\)
\(\ln(e^{\frac{9D}{T(1+D)}t}-1)=\frac{8t}{T}-4\)
\(\frac{T}{8}(\ln(e^{\frac{9D}{T(1+D)}t}-1)+4)=t\)
After a few iterations we get t=18.713393.
You can use this program for the HP-42S:
00 { 20 Byte Prgm }
01 9
02 *
03 RCL* 01
04 RCL/ 00
05 E^X-1
06 LN
07 4
08 +
09 RCL* 00
10 8
11 /
12 END
You just have to store \(T\) in register 00 and \(\frac{D}{1+D}\) in register 01, enter a guess and hit the [R/S] button a couple of times.
01-22-2015, 08:15 AM
00 { 20 Byte Prgm }
01 9
02 *
03 RCL* 01
04 RCL/ 00
05 E^X-1
06 LN
07 4
08 +
09 RCL* 00
10 8
11 /
12 END
Neat. Thanks Thomas.
01-24-2015, 05:00 PM
Adopted to the HP-41 and with a better user interface. Start the program, enter the values for D and T and the program spits out "t" to the number of decimal places you have set with FIX:
001*LBL "↑="
002 RCL 01
003 "D="
004 ARCL X
005 PROMPT
006 STO 01
007 RCL 02
008 "T="
009 ARCL X
010 PROMPT
011 STO 02
012 10
013*LBL 00
014 STO 03
015 9
016 *
017 RCL 01
018 *
019 RCL 01
020 1
021 +
022 /
023 RCL 02
024 /
025 E^X-1
026 LN
027 4
028 +
029 RCL 02
030 *
031 8
032 /
033 RCL 03
034 X<>Y
035 RND
036 X!=Y?
037 GTO 00
038 "↑="
039 ARCL X
040 AVIEW
041 END
02-22-2015, 08:31 PM
An idea for a rough estimation - may not works for all D and T: With little algebra you can get: exp(m×t+b)+1=exp(a×t), where m=8/T, b=-4 and a=9×D÷((1+D)×T)
For a rough estimation of t you can "forget" the +1 on the left side and the approximately solution for t is: t=b÷(a-m) = (-4)÷(1÷8-1÷3) = 19.2
02-22-2015, 08:57 PM
