(34S) Patrice Torchet's WP-34S Optimized N-Queens Benchmark
10-15-2014, 06:48 PM (This post was last modified: 06-15-2017 01:30 PM by Gene.)
This WP-34S benchmark code is courtesy of Patrice Torchet:
Performance statistics using WP34S Firmware version 3.3 on HP-30B Hardware for the "Traditional" WP-34S NQueens Benchmark (See Xerxes Article)
WP-34S "Traditional" mode: [f] H.d (DECM):------------------------>68 Ticks
WP-34S "Traditional" mode: BASE 10 : -----------------------------> 61 Ticks
Performance statistics using WP34S Firmware version 3.3 on HP-30B Hardware for the code below are as follows:
Torchet WP-34S N-Queens Optimized:-------------------------------------------->21 Ticks
There are approximately 10 Ticks per second
140    [f] LBL C
141    TICKS
142    STO K
143    [f] BASE 16
144    WSIZE 32
145    [h] CLx
146    STO C    //loop counter
147    STO I    //Stack pointer
148    1
149    0
150    1
151    0
152    1
153    0
154    1
155    STO A    //0x1010101
156    8
157    STO B    //remaining Q
158    [h] MASKR 08
159    [h] SL 01
160    STO 00    //0x1FE
161    [f] LBL 02    //x=bitmap y=Q position
162    INC C
163    [h] BS?->Y    //test Q position
164    [h] GTO 05    //Q OK, next line
165    [f] LBL 03    //x=bitmap y=Q position
166    [h] DSZ Y    //SHIFT QUEEN
167    [h] GTO 02    //RETRY
168    INC B    //ootherwise backtrack
169    RCL->I    //pop a Q
170    DEC I    //pop a Q
171    RCL->I    //pop a Q
172    DEC I    //pop a Q
173    [h] GTO 03
174    [f] LBL 05    //x=bitmap y=Q position
175    INC I
176    STO->I    //Save bitmap
177    X<>Y
178    INC I
179    STO->I    //save Q
180    X<>Y
181    DSZ B    //Finish if 0
182    [h] GTO 01
183    [h] GTO 04
184    LBL 01
185    RCL A    //get Q mask
186    [h] RL->Z    //shift
187    [h] OR    //merge with bitmap
188    RCL 00
189    [h] NOT
190    [h] AND    //clear combination
191    [h] RR 09
192    [h] RRC 08    //shift diagonal
193    RL 16
194    [h] RLC 08    //shift diagonal
195    [h] RR 07
196    ENTER
197    ENTER
198    [h] RL 08
199    [h] OR    //ORing L V R
200    ENTER
201    [h] RL 16
202    [h] OR    //ORing L V R
203    RCL 00
204    [h] AND    //mask Combination
205    RCL L
206    [h] XOR    //negate Combination
207    [f] X=0?    //if 0
208    [h] GTO 06    //deadend
209    [h] OR    //merge Combination to bitmap
210    8
211    X<>Y
212    [h] GTO 02
213    [f] LBL 06    //Shortcut
214    8
215    STO+C
216    INC B
217    RCL->I
218    DEC I
219    RCL->I
220    DEC I
221    [h] GTO 03
222    [f] LBL 04
223    RCL C
224    BASE 10
225    TICKS
226    RCL K
227    -
228    STO K
229    R Dn
230    [g] RTN
bitmap principle
the bitmap contains 4 parts of 8 bits
L    Left diagonal locks
V    Vertical locks
R    Right diagonal locks
C    Combination    = L or V or R    This is the part tested (BS?)
LLLLLLLVVVVVVVVRRRRRRRRCCCCCCCCL
register A
00000001000000010000000100000001
bitmap is rotated to have combination on bits 1 to 8
register A is rotated too to match bitmap
