PIL BOX with IL connector
11-23-2023, 11:24 AM
I know this has been done before using a recycled connector (https://www.hpmuseum.org/forum/thread-14287.html), but my go at this uses the IL connector from a 2225B printer. Makes a neat job I think.
Unfortunately I have now used the 2 of these connectors I had, the other one I used on my IL mass storage emulator.
Cheers,
Attached File(s) Thumbnail(s)
11-23-2023, 05:50 PM
RE: PIL BOX with IL connector
Consider extending the LED up through a hole in the top cover. Makes an easy way to monitor HP-IL activity. You could also use a light pipe.
11-24-2023, 05:44 AM
(11-23-2023 05:50 PM)Dave Frederickson Wrote:  Consider extending the LED up through a hole in the top cover. Makes an easy way to monitor HP-IL activity. You could also use a light pipe.
yeah I really wanted to do that with the Mass storage emulator :-)
Cheers,
