Factorial equation
10-20-2023, 08:39 PM
Factorial equation
Playing about with the Prime
(n+2)! = 4*n! +4*(n+1)!
Simple to solve by hand
My attempts at getting the Prime to solve it fail.
TI nSpire CAS solves it correctly
Geo-Gebra fails
Any help is welcome.
10-21-2023, 01:07 AM
RE: Factorial equation
I just copied your equation and pasted it into the Solve app on my Prime emulator. Click the Num key and then the Solve soft key. It spit out 3 as the answer. Same result on my iOS version.
10-21-2023, 03:12 PM (This post was last modified: 10-21-2023 03:19 PM by C.Ret.)
Hi, you are welcome.
That's right, directly typing SOLVE((n+2)!=4n!+4(n+1)!,n) results in an error message (see first line in the following screenshot).
(10-20-2023 08:39 PM)Quadratica Wrote:  Simple to solve by hand
This is the detail of great importance that lead you to one the turnaround (see second line in screenshot).
But, there is a lot of other way to get the answer without any effort (see last entry in the screenshot).
[Image: attachment.php?aid=12697]
I hope this help a bit.
10-21-2023, 08:31 PM
Both suggestions work. It's annoying that it requires a little workaround which would not be the case on other types of equations. I didn't know that the option to specify a range for the solution existed and it's good to know.
Thank you
