Is backup of go49g+ possible?
09-02-2014, 11:20 PM
I really like this Android emulator, but can't seem to find a way to back it up - go49g+.
The problem is that it doesn't support port 3, the SD card.
If, for example, I create a backup object with the command:
The result is a "DIR" in port 2 ... -NOT- a backup object that can be exported from stack level 1.
Without a way to create and export a backup object, how do you create a remote backup for this emulator?
