HP-IL Traces (part #1)
07-14-2023, 07:23 PM (This post was last modified: 07-16-2023 08:52 PM by Sylvain Cote.)
HP-IL Traces (part #1) [2023-07-14]
I am currently commenting HP-IL traces for another project, but it was suggested to made them public, so here they are ...
Setup:
  • HP-41CX halfnut
  • 82160A HP-IL module
    • PIL-Box
      • pyILPER
        • Virtual Scope (incoming frames: 41__to__TAPE)
        • Virtual Mass Storage (82161A Cassette Drive)
        • Virtual Scope (outgoing frames: TAPE__to__41)
Listings:
  • HP-41 / HP-IL / WAKEUP (power on) [2023-07-14]
  • HP-41 / HP-IL / NEWM (new medium → NEWM 040) [2023-07-14]
  • HP-41 / HP-IL / DIR (directory, empty cassette) [2023-07-14]
  • HP-41 / HP-IL / CREATE (create data file, DA → "ABC" 100 CREATE) [2023-07-14]
Listing is easier to read with "View a Printable Version" (link at the bottom)
Sylvain
edit: post too big, renaming this one part #1 and creating part #2
41__to__TAPE | TAPE__to__41 | Description
IDY 23 (623) | idy 23 (623) | wake up frame, some peripheral will not be able
             |              |   to get it, because they are in wake up mode
IFC    (490) | ifc    (490) | command: interface clear
RFC    (500) | rfc    (500) | devices are ready for another command
IDY 00 (600) | idy 00 (600) | loop continuity test and service request detection
AAU    (49A) | aau    (49a) | auto address unconfigure,
             |              |   all devices must set his loop address to 31
AAD  1 (581) | aad  2 (582) | adressing the loop, only 1 device in the loop
TAD 01 (441) | tad 01 (441) | first device is now the loop talker
SAI    (563) |              | ctrl is asking the talker to send his accessory id
             | dab 10 (010) | aid = 10h (mass storage class)
DAB 10 (010) |              |
             | eto    (540) | end of transmission ok
UNT    (45F) | unt    (45f) | first device is no longer a talker (untalk)
SAI    (563) |              | talker accessory id request
DAB 10 (010) |              |
SST    (561) |              | talker interface status request
             | dab 00 (000) | status = 0h (no error)
DAB 00 (000) |              |
LAD 01 (421) | lad 01 (421) | first device is now one of the loop listeners
             |              |   and no longer the loop talker
DDL 05 (4A5) | ddl 05 (4a5) | tape format request
             |              |   0xFF is written on the tape
             |              |   128KB = 2 tracks x 256 records @ 256 bytes/record
DAB 00 (000) |              |
DDL 04 (4A4) | ddl 04 (4a4) | tape seek request
             |              |   parameters are in the next two DAB frames
DAB 00 (000) | dab 00 (000) | track  0
DAB 00 (000) | dab 00 (000) | record 0
DAB 00 (000) |              |
DDL 03 (4A3) | ddl 03 (4a3) | set byte pointer in buffer request
DAB 00 (000) | dab 00 (000) | pointer 0
DDL 02 (4A2) | ddl 02 (4a2) | activate continous write
DDL 00 (4A0) | ddl 00 (4a0) | write to buffer 0
DAB 00 (000) | dab 00 (000) | data for track 0 record 0 : byte 0
DAB 00 (000) | dab 00 (000) | data for track 0 record 0 : byte 255
             |              |   end of buffer is reached,
             |              |   data is flushed to tape,
             |              |   automatic tape seek next record
DAB 00 (000) | dab 00 (000) | data for track 0 record 1 : byte 0
DAB 00 (000) | dab 00 (000) | data for track 0 record 1 : byte 255
DAB 00 (000) |              |
DAB 00 (000) |              |
             |              | data for track 0 record 0 : TAPE LIF HEADER
             |              | LIF identifier = 0x8000 (2 bytes)
DAB 80 (080) | dab 80 (080) |
             |              | Volume Label (6 bytes)
             |              |   82160A weird tape label name
DAB 02 (002) | dab 02 (002) |
DAB 10 (010) | dab 10 (010) |
             |              | Directory start block = 0x00000002 (4 bytes)
             |              | LIF identifer = 0x1000 ( 2 bytes)
             |              | Filler, must be zero
             |              | Length of directory in blocks = 0x00000006 (4 bytes)
             |              |   82160A is reserving more directory space than needed
             |              |   for 040 files, it should only reserve 5 blocks
             |              |   40 files x 32 bytes (dir entry per file) = 1280
             |              |   1280 bytes / 256 (bytes per record) = 5 blocks
END 06 (206) | end 06 (206) |
             |              | end byte received
             |              | 82160A is not a good LIF citizen
             |              |   it does not fills the other LIF header fields
             |              |   those values are hard coded in the module
DAB 00 (000) |              |
DAB 02 (002) | dab 02 (002) | record 2
DAB 00 (000) |              |
DDT 02 (4C2) | ddt 02 (4c2) | tape read request
             |              |   track 0 record 2 is copied into buffer 0
             |              |   tape is now set to track 0 record 3
             |              |   wow, for once, 82160A already know the talker state
DAB 00 (000) |              |
DDT 03 (4C3) | ddt 03 (4c3) | tape position request
SDA    (560) |              | ctrl is asking the talker for his data
DAB 00 (000) | dab 03 (003) |   record 3
DAB 03 (003) | dab 00 (000) |   byte 0
DAB 00 (000) |              |
DDL 09 (4A9) | ddl 09 (4a9) | copy buffer 0 to buffer 1
             |              |   reset buffer pointer to 0
             |              |   buffer 1 hold a copy of the first directory record
DAB FA (0FA) | dab fa (0fa) |   to FAh or 250d
DDL 01 (4A1) | ddl 01 (4a1) | activate buffer 1
DAB FA (0FA) | dab fa (0fa) | write FAh at position FAh in buffer 1
             |              |   hein! why? I need to investigate this
DAB 00 (000) | dab 00 (000) | pointer set to 0
UNL    (43F) | unl    (43f) | unlisten
DAB 10 (010) |              |
SST    (561) |              | ctrl is asking for talker interface status
DAB 00 (000) |              |
SAI    (563) | dab 10 (010) | ctrl is asking the talker to send his accessory id
             |              |   and the device is sending 10h or 16d
             |              |   which is the id for a mass storage device class
DAB 10 (010) | eto    (540) | device is sending an end of transmission ok
DAB 00 (000) |              |
DDL 04 (4A4) | ddl 04 (4a4) | ctrl is sending a tape seek request
DAB 00 (000) |              |
DDT 02 (4C2) | ddt 02 (4c2) | ctrl is sending a read tape record request
             |              |   the drive read record into drive buffer 0
             |              |   and set the current record to 3
DAB 00 (000) |              |
DAB 00 (000) |              |
DDT 00 (4C0) | ddt 00 (4c0) | ctrl is asking the talker to send his
             |              |   buffer 0 content on the loop
             | dab ff (0ff) | LIF record 32 bytes
DAB FF (0FF) | dab ff (0ff) | LIF description web pages
DAB FF (0FF) | dab ff (0ff) |   http://www.finseth.com/hpdata/lif.php
DAB FF (0FF) | dab ff (0ff) |   https://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/articles.cgi?read=24
DAB FF (0FF) | dab ff (0ff) |   https://www.hp9845.net/9845/projects/hpdir/
DAB FF (0FF) | dab ff (0ff) | empty directory entry record = last entry in directory
NRD    (542) | nrd    (542) | ctrl is telling the drive to stop sending data
DAB FF (0FF) |              |
41 _to_ TAPE | TAPE _to_ 41 | Description
             |              | LOOP CONFIGURATION - 1st time
DAB 10 (010) |              |
DAB 00 (000) |              |
             |              | LOOP CONFIGURATION - 2nd time, again !
DAB 10 (010) |              |
             |              | LOOP CONFIGURATION - 3rd time, the 82160A is so inneficient
DAB 10 (010) |              |
             |              | FINALLY - we are out this configuration retry loop
             |              | GET FIRST DIRECTORY ENTRY
DAB 00 (000) |              |
DAB 00 (000) |              |
DAB 00 (000) |              |
             |              | again !
DAB 00 (000) |              |
DAB FF (0FF) | dab ff (0ff) |   empty = last directory entry
DAB FF (0FF) |              |
             |              | FIRST DIRECTORY ENTRY IS EMPTY !!!
             |              | IS THE TAPE FORMATTED ?
DAB 00 (000) | DAB 00 (000) | record 0
             |              | track 0 sector 0 contains the LIF Volume data
DAB 00 (000) |              |
             |              |   track 0 record 0 is copied into buffer 0
             |              |   tape is now set to track 0 record 1
DAB 00 (000) |              |
             |              | LIF Volume
             | dab 80 (080) |   LIF identifier = 0x8000 (2 bytes)
DAB 80 (080) | dab 00 (000) |
DAB 00 (000) |              |
             | dab 20 (020) |   Volume Label (6 bytes)
DAB 20 (020) | dab 20 (020) |
DAB 20 (020) |              |
             | dab 00 (000) |   Directory start block = 0x00000002 (4 bytes)
DAB 00 (000) | dab 02 (002) |
DAB 02 (002) |              |
             | dab 10 (010) |   LIF identifer = 0x1000 ( 2 bytes)
DAB 10 (010) | dab 00 (000) |
DAB 00 (000) |              |
             | dab 00 (000) |   Filler, must be zero (2 bytes)
DAB 00 (000) |              |
             | dab 00 (000) |   Length of directory in blocks = 0x00000006 (4 bytes)
DAB 00 (000) | dab 06 (006) |
DAB 06 (006) |              |
             | dab 00 (000) |   LIF version number, must be 1 (2 bytes)
DAB 00 (000) | dab 01 (001) |
DAB 01 (001) |              |
DAB 00 (000) |              |
             | dab 00 (000) |   Number of tracks per surface = 0x0000002 (4 bytes)
DAB 02 (002) |              |
             | dab 00 (000) |   Number of surfaces = 0x00000001 (4 bytes)
DAB 01 (001) | eto    (540) | end of transmission ok
             |              | LIF info not transmitted:
             |              |   number of blocks per track (4 bytes)
             |              |     cassette drive -> 256 blocks per track is assume here
             |              |   date and time that the volume was initialized (6 bytes)
             |              | YES, THE TAPE FORMATTED
             |              | THEN GET FIRST DIRECTORY ENTRY (again)
             |              | track 0 sector 2 contains the directory first record
DAB 00 (000) |              |
DAB 00 (000) |              |
DAB 00 (000) |              |
DAB FF (0FF) |              |
             |              | WRITE FILE DIRECTORY ENTRY TO TAPE
DAB 03 (003) | dab 20 (020) |   byte 32
DAB 20 (020) |              |
DAB 00 (000) |              |
             |              | Update first directory entry with new file info (32 bytes)
DAB 41 (041) | dab 41 (041) |   filename = "ABC       " (10 bytes)
DAB 42 (042) | dab 42 (042) |
DAB 43 (043) | dab 43 (043) |
DAB E0 (0E0) | dab e0 (0e0) |   filetype = 0xE0D0 (SDATA, 2 bytes)
DAB D0 (0D0) | dab d0 (0d0) |
DAB 00 (000) | dab 00 (000) |   start block = 0x00000008 (4 bytes)
DAB 08 (008) | dab 08 (008) |
DAB 00 (000) | dab 00 (000) |   allocated blocks = 0x00000004 (file length, 4 bytes))
DAB 04 (004) | dab 04 (004) |
DAB 00 (000) | dab 00 (000) |   date+time (6 bytes)
DAB 80 (080) | dab 80 (080) |   miscellaneous data (6 bytes)
DAB 01 (001) | dab 01 (001) |     tbd = 0x80 0x01 0x00 0x64 0x00 0x20
DAB 64 (064) | dab 64 (064) |
END 20 (220) | end 20 (220) |   end byte received, data is flushed to tape
             |              | VALIDATE FILE DIRECTORY ENTRY
DAB 00 (000) |              |
DAB 20 (020) |              |
             |              | INIT TAPE FILE DATA SPACE WITH 0x00
DDL 03 (4A3) | ddl 03 (4a3) | buffer byte pointer = 0xFA (250)
DDL 03 (4A3) | ddl 03 (4a3) | buffer pointer = 0x20 (32)
DAB 08 (008) | dab 08 (008) | record 8
             |              | track 0 sector 8 is the start of the file data
DDL 03 (4A3) | ddl 03 (4a3) | buffer pointer = 0x00 (0)
DDL 02 (4A2) | ddl 02 (4a2) | activate continous write with buffer 0
DAB 00 (000) | dab 00 (000) | data for track 0 record 8 : 256 bytes begin
...          | ...          |   data block 1
DAB 00 (000) | dab 00 (000) | data for track 0 record 8 : 256 bytes end
DAB 00 (000) | dab 00 (000) | data for track 0 record 9 : 256 bytes begin
...          | ...          |   data block 2
DAB 00 (000) | dab 00 (000) | data for track 0 record 9 : 256 bytes end
DAB 00 (000) | dab 00 (000) | data for track 0 record 10 : 256 bytes begin
...          | ...          |   data block 3
DAB 00 (000) | dab 00 (000) | data for track 0 record 10 : 256 bytes end
DAB 00 (000) | dab 00 (000) | data for track 0 record 11 : 256 bytes begin
...          | ...          |   data block 4
DAB 00 (000) | dab 00 (000) | data for track 0 record 11 : 256 bytes end
