DIY 41C Feet Replacement - Help
05-01-2023, 01:38 AM
Have a 41 in need of feet, it has none.
The material does not need to have adhesive, I have double stick adhesive. Material with adhesive backing is good too.
Hoping for a DIY solution to the missing feet.
05-01-2023, 01:51 AM
RE: DIY 41C Feet Replacement - Help
Someone was selling replacement rubber feet for it on eBay, which I bought.  I don't have the information anymore, but if he's still there selling them, a little searching should find them.
05-01-2023, 02:52 AM
(05-01-2023 01:51 AM)Garth Wilson Wrote:  Someone was selling replacement rubber feet for it on eBay, which I bought.  I don't have the information anymore, but if he's still there selling them, a little searching should find them.
Found ebay sellers many months ago, there are often 2 to 3 of sellers offering replacement feet.
Hoping for DIY option. Like "hobby lobby sells..." that works great.
05-01-2023, 04:49 AM
There is a seller in Spain that have them in store as well as other repair kits for the 41:
TheCalculatorStore
Cheers,
[35/45/55/65/67/97/80 21/25/29C 31E/32E/33E|C/34C/38E 41C|CV|CX 71B 10C/11C/12C/15C|CE/16C 32S|SII/42S 28C|S 48GX/49G/50G 35S 41X]
05-01-2023, 11:51 AM
I bought a sheet of rubber off the 'Bay. Its been a while but IIRC it was by Ruby's Rubber's (wife raised an eyebrow when that package came in the mail). The sheet was the right thickness and quality tube material. Guy sells the remnants.
Cut to size and add some quality double sided tape.
-Bill
05-02-2023, 01:16 AM
DIY method: Use an old bike innertube, one of the thicker grade 'thornless' ones is best. Cut to shape, slightly trim the corners to rounded, apply your d/s tape, all done.
DA
05-02-2023, 03:55 AM
I've always just cut some sheet rubber to size and used rubber cement to attach the feet.
And used a circular x-acto knife to make the circular rubber feet for the TI machines.
-J
[35/45/55/80/70/65/67/67T/97/97S/91/92/21/22/27/25C/29C/19C/10/
31E/32E/33C/34C/37E/38C/41CX/71B/28S/19BII/12C/15C/33S/35S/32SII/
48GX/50G/Prime/DM42]
05-02-2023, 07:39 PM (This post was last modified: 05-02-2023 07:40 PM by David Hayden.)
I bought a sheet with adhesive backing from rubber supply warehouse (I think that was the name) several years ago. If you don't mind cutting your own feet and are in the US, I'd be happy to send you a section at no charge. Just drop me a PM with your address.
