Is it possible to rename a backup object?
06-02-2014, 02:47 PM
Is is possible to rename a backup object on the 50g? The filer seems to be refusing to cooperate.
It ain't OVER 'till it's 2 PICK
06-03-2014, 02:07 AM
RE: Is it possible to rename a backup object?
(06-02-2014 02:47 PM)HP67 Wrote:  Is is possible to rename a backup object on the 50g? The filer seems to be refusing to cooperate.
Not in one step, no. But you can do it in two easy steps: use the Filer to Copy it to the same port, using the "REN" (rename) option, and then delete the original one.
X<> c
-Joe-
06-03-2014, 09:01 AM
Thanks. I didn't understand why the filer doesn't support renaming backup objects since it seems to be able to rename everything else I tried.
I was thinking about versioning backups but I would probably end up with a huge bunch of files that I had no way of knowing what they contained.
Time to write some source control for the 50g...
06-03-2014, 09:40 AM
Check this out for a 49G version that I made a long time ago:
http://software49g.gmxhome.de/EnglishSeite01.htm#Archiv
Direct download link:
http://software49g.gmxhome.de/DeutschSeite01/Archiv.zip
It is not adjusted for the larger screen of the 50g but it does exactly what you are looking for.
HTH,
Andreas
http://www.software49g.gmxhome.de
06-03-2014, 10:01 AM
Thanks, Andreas.
