HP 41CX new trick (at least to me)
05-27-2014, 02:52 PM
(This post was last modified: 05-27-2014 02:53 PM by Visu.)
Just by pure coincidence, I found a quick sequence key that turned the clock on on my 41CX.
shift / ON Undocumented to my knowledge but I may have not RTFM properly 3 decades ago... |
05-27-2014, 05:07 PM
RE: HP 41CX new trick (at least to me)
(05-27-2014 02:52 PM)Visu Wrote: Just by pure coincidence, I found a quick sequence key that turned the clock on on my 41CX. It's on page 238 "Turning the Clock On" However, having plugged in the "NoV-64" this doesn't work. What gives? Günter |
05-27-2014, 05:09 PM
(05-27-2014 02:52 PM)Visu Wrote: Just by pure coincidence, I found a quick sequence key that turned the clock on on my 41CX. In the August 1983 edition of the 41CX Manual Volume 1 (Basic Operation), Section 6 ("The Time Functions"), page 61: Under "The Clock": Subheading is "Displaying the Clock ([shift] ON, [CLOCK])" |
05-28-2014, 11:46 AM
Definitely a lack of RTFM issue
Now, being honest, who owns a 41CX and did NOT know the trick ? |
05-28-2014, 12:03 PM
(05-28-2014 11:46 AM)Visu Wrote: Definitely a lack of RTFM issueI don't own a HP-41CX, however I do have a Time Module. On page 16 of the Time Module Owner's Manual (a rather impressive 89 page document), it states: Displaying the Clock: SHIFT [ON] |
05-29-2014, 12:42 AM
Hey I didn't know. But now I have to figure out how to set the correct time.
I have 2 97's, 2 41cx's, 2 32s's, 1 11c, 1 35s, 1 35 on it's way and another 32s on its way. Sold a 28c and a 48 with a bad screen. Calcaholic What? Wiz |
05-29-2014, 01:24 AM
(05-27-2014 05:07 PM)Guenter Schink Wrote: It's on page 238 "Turning the Clock On" Hi, I've got the NoV-64 plugged in a CX and the SHIFT+ON shows the clock as it should. Are there any detais on your NoV-64 configuration that may conflict with the TIMER funtions? Diego. "Do not suppose, check it twice." |
05-29-2014, 09:36 AM
(05-29-2014 01:24 AM)Diego Diaz Wrote:(05-27-2014 05:07 PM)Guenter Schink Wrote: It's on page 238 "Turning the Clock On" Tnanks Diego, Good to know it does work. I'll investigate further. But will need some time due to other activities. Günter |
05-29-2014, 10:51 AM
(05-29-2014 12:42 AM)Wiz Wrote: Hey I didn't know. But now I have to figure out how to set the correct time. ow, I can help you on that : SETIME SETDATE MDY DMY |
05-29-2014, 11:18 AM
(05-29-2014 10:51 AM)Visu Wrote: ow, I can help you on that : And for best results, ASN SETIME to a key, turn on USER mode, and use that to set the time on the precise instant. Then clear the assignment, before you forget, and use CORRECT thereafter to set the accuracy factor. --- Les [http://www.lesbell.com.au] |
05-31-2014, 01:04 PM
(05-29-2014 11:18 AM)Les Bell Wrote: And for best results, ASN SETIME to a key, turn on USER mode, and use that to set the time on the precise instant. Then clear the assignment, before you forget, and use CORRECT thereafter to set the accuracy factor. Now 'that' is what I call a useful trick! Thanks Les! Jeff K |
06-02-2014, 05:39 AM
(05-28-2014 11:46 AM)Visu Wrote: Now, being honest, who owns a 41CX and did NOT know the trick ? I knew it, but forgot it. Regards, Howard |
