Mulitple pages help from a program
10-16-2018, 09:05 AM (This post was last modified: 10-16-2018 09:11 AM by sasa.)
In a bit more complex test program, it should also be able to show multiple help pages on pressing button "Help" ...
However, it seems (at least in latest public beta) that terminal window which is activated after PRINT commands does not have full abilities inside a running program. The manual also do not show any related command to show fully capable terminal window with scroll abilities.
Using WAIT command between pages is not quite intuitive and making fully capable graphics window with keyboard and menus will take some time...
Is there any undocumented command in the Prime to show fully capable terminal window from a program?
Or perhaps another suitable way?
Making an application in Prime may be the way, however I'm limited with the latest public beta Virtual Calculator on Linux only.
Thanks in advance.
10-16-2018, 09:50 AM (This post was last modified: 10-16-2018 09:51 AM by StephenG1CMZ.)
RE: Mulitple pages help from a program
Would this terminal alternative help?
http://www.hpmuseum.org/forum/thread-266...t=terminal
Stephen Lewkowicz (G1CMZ)
10-19-2018, 10:58 AM (This post was last modified: 10-19-2018 11:09 AM by sasa.)
(10-16-2018 09:50 AM)StephenG1CMZ Wrote:  Would this terminal alternative help?
Thank you for pointing out.
Unfortunately, after a bit more testing, it seems it have several serious issues, including unexpected cropping. It also have no ability for long line braking, no page support, no menu...
I have manage to make my own initial solution I needed and I believe it would be useful as well to someone else:
http://www.hpmuseum.org/forum/thread-11611.html
