hp 50g keyboard problem
10-02-2018, 01:56 PM
the F2 key. I use it to input "B" character. sometimes "A" or "C" or nothing comes out.
I test the keyboard using the ON&F5 function. It seems ok. The key responds slower than others. no mistake happens.
What's the problem? how to solve it?
10-06-2018, 10:21 AM (This post was last modified: 10-06-2018 10:22 AM by samo50g.)
RE: hp 50g keyboard problem
i am not an expert but long time ago i solved non-responsive key on my recently passed 28S. I used contact cleaner in spray. It is meant for cleaning contacts in electronic devices. It evaporates in several minutes. Just spray it into any opening around the button. However, do it on your own risk, please.
However, mu theory about bad contact is not supported by what you wrote. getting letter X instead of Y shows that button it works however in a wrong way.
Honestly, I think you cannot lose much if you use contact cleaner spray. wait 15 minutes or more after spraying the button.
10-09-2018, 12:01 AM
(10-06-2018 10:21 AM)samo50g Wrote:  i am not an expert but long time ago i solved non-responsive key on my recently passed 28S. I used contact cleaner in spray. It is meant for cleaning contacts in electronic devices. It evaporates in several minutes. Just spray it into any opening around the button. However, do it on your own risk, please.
Thank you very much!
