Battery for HP-IL Peripherals
09-21-2018, 02:45 PM
I found this battery on Amazon
AGM Ct 3-6/6 V 3Ah lead acid battery
And mounted it in 9114 and 3468.
Works really well.
Here the details on the Battery
Manufacturer CTM Berlin
System Lead non-woven battery (PB)
Model: CT 3 – 6
Rated voltage: 6 V
Nominal Capacity: 3 Ah (20hr)
Pole 4.8 mm
Length: 66 mm, width: 33 mm, height: 97 mm,
Total height: 103 mm
Weight: 590 g
09-21-2018, 04:27 PM
RE: Battery for HP-IL Peripherals
(09-21-2018 02:45 PM)KimH Wrote:  I found this battery on Amazon
Amazon reports:
"We found 0 results for "AGM Ct 3-6/6 V 3Ah lead acid battery""
Do you have a link or more concise search string?
09-21-2018, 04:49 PM
Amazon reports:
This fits the bill (as described in OP)
https://www.amazon.de/AGM-Blei-Akku-3-6-...B003UCKFSM
09-21-2018, 05:15 PM (This post was last modified: 09-21-2018 05:17 PM by Erwin.)
(09-21-2018 04:49 PM)Zaphod Wrote:
(09-21-2018 04:27 PM)rprosperi Wrote:  Amazon reports:
Hallo,
additional: https://www.akkuangebote.de/bleiakku-fue...ie/6-volt/
Others for the 3421A as an example: https://www.blei-akkus.com/AGM-wartungsfrei
and here: https://www.akku.net/Akku-Info/1.86.APC....h-12V.html
Regards Erwin
09-21-2018, 05:19 PM (This post was last modified: 09-21-2018 05:19 PM by Zaphod.)
(09-21-2018 05:15 PM)Erwin Wrote:
(09-21-2018 04:49 PM)Zaphod Wrote:  This fits the bill (as described in OP)
Hallo,
Regards Erwin
Some of those you’re suggesting are 12volt !
This one from your selection of links is the OP: (6V with 3AH)
https://www.akkuangebote.de/ctm-agm-batt...-3-ah.html
09-21-2018, 05:20 PM (This post was last modified: 09-21-2018 05:20 PM by Erwin.)
(09-21-2018 05:19 PM)Zaphod Wrote:
(09-21-2018 05:15 PM)Erwin Wrote:  Hallo,
Regards Erwin
Those are only my sources - you have to filter them for your needs :-)
09-21-2018, 05:37 PM (This post was last modified: 09-21-2018 05:37 PM by Zaphod.)
(09-21-2018 05:20 PM)Erwin Wrote:  Those are only my sources - you have to filter them for your needs :-)
Ah Smile
