(48) - Determine Circle From Three Given Points
07-14-2018, 02:30 AM (This post was last modified: 07-14-2018 02:55 AM by gerry_in_polo.)
Enter three points as follows: X1 Y1 X2 Y2 X3 Y3 on the stack and run the program. The Circle's Center (Xc,Yc) and Radius will be given. Example: Enter 1 2 5 9 7 -3 on the stack and run the program. The result is (Xc,Yc) = (7.0645,3.1774) and Radius=6.1778.
Attached File(s)
.pdf  Determine Circle From Three Points (HP-48, Gerardo V Lozada, 2018-07-13).pdf (Size: 45.24 KB / Downloads: 11)
