(49G 49g+ 50g 48gII) NMDUP
05-16-2018, 06:12 PM (This post was last modified: 08-11-2018 04:16 PM by DavidM.)
DUPN and NDUPN are very useful RPL commands that also happen to be very fast ways of replicating objects on the stack. DUPN makes a single copy of the number of objects specified:
1 2 3 3 DUPN => 1 2 3 1 2 3
...and NDUPN makes a single object with the specified number of copies, followed by the number of copies:
7 8 9 3 NDUPN => 7 8 9 9 9 3.
Another similar scenario that can be useful has no single command, though. Specifically, replicating a group of objects a set number of times. The following SysRPL program can be used to perform this function:
   ( stack on entry:
     n: anything
     2: group count [integer]
     1: repeat factor [integer]
   CK2NOLASTWD                         ( stack must contain at least 2 objects )
   CK&DISPATCH1
   BINT17 ( ..., real, real ) ::       ( SL1/2 must contain numbers )
      COERCE2                          ( convert to BINTs )
      OVER #3+                         ( check stack depth )
      DEPTH #> case SETSTACKERR        ( error if stack not deep enough )
      ( special cases )
      DUP#0=case :: DROP NDROP ;       ( repeat factor of 0 )
      DUP#1= casedrop DROP             ( repeat factor of 1 )
      OVER#0= casedrop DROP            ( group count of 0 )
      ( otherwise )
      SWAP 1LAMBIND                    ( save group count in NULLLAM )
      ONE_DO (DO)                      ( loop [repfactor - 1] times )
         1GETLAM NDUP                  ( NDUP the current group )
      LOOP
      ABND                             ( abandon NULLLAM )
Compile the above and give it a suitable name (I use NMDUP). To use it, place two numbers on the stack which represent the following:
2: N (the number of elements in the stack to replicate/group size)
1: M (the number copies of the elements to make)
Note that M represents the total quantity of duplicates, not the additional ones. So a quantity of 0 is the same as dropping N elements, a quantity of 1 does nothing, etc. Likewise, an N of 0 will have no affect on the rest of the stack, as there are no stack items identified for replication.
Examples:
1 2 3 3 0 NMDUP => <nothing>
1 2 3 3 1 NMDUP => 1 2 3
1 2 3 3 2 NMDUP => 1 2 3 1 2 3
1 2 3 2 5 NMDUP => 1 2 3 2 3 2 3 2 3 2 3
1 2 3 0 5 NMDUP => 1 2 3
08-11-2018, 04:11 PM
RE: (49G 49g+ 50g 48gII) NMDUP
Just noticed a typo, it should be DUPN, NOT NDUP for the built-in command.
08-11-2018, 04:22 PM
(08-11-2018 04:11 PM)John Keith Wrote:  Just noticed a typo, it should be DUPN, NOT NDUP for the built-in command.
Thanks for spotting that -- it's now fixed.
Note that NDUP is the SysRPL version, DUPN is the UserRPL one. That same pattern holds for several other commands as well. Sometimes my fingers don't switch modes as quickly as my brain tries to. Smile
