Integral on HP 42S
04-26-2018, 08:10 PM
Integral on HP 42S
Just received an HP 42S. What a beautiful calculator!
If I want to integrate a function such as 5th root of x from -2 to 0, is there a way to do so? On the HP 35S, the x root y command is available for this. Is there a work around on the HP 42S? (Of course, there is no problem with x>0!)
04-26-2018, 08:58 PM (This post was last modified: 04-26-2018 08:59 PM by Dieter.)
RE: Integral on HP 42S
(04-26-2018 08:10 PM)lrdheat Wrote:  If I want to integrate a function such as 5th root of x from -2 to 0, is there a way to do so? On the HP 35S, the x root y command is available for this. Is there a work around on the HP 42S? (Of course, there is no problem with x>0!)
What about this way:
LBL"FX"
MVAR"X"
RCL"X"
SIGN
LastX
ABS
0,2
y^x
x
RTN
The true result is –5/6 · 26/5.
Dieter
04-26-2018, 11:28 PM
Outstanding! Tried it on a mixed case that covers negative and positive results on 1/(5 root(x-1)) from 0 to 33. With accuracy of .001, it takes a while, but comes up with 18.73 on fix 2, close to actual value of 18.75
Works faster dividing into 2 integrals, one from 0 to 1, then from 1 to 33.
Thanks!
