Possible bug: chisquaret
02-03-2018, 08:44 PM
With any of the examples from the Help screen, chisquaret causes a warm start on the physical calculator but works (seemingly) OK on the virtual calc (Windows 7). Identical CAS settings on both.
02-03-2018, 08:51 PM
RE: Possible bug: chisquaret
(02-03-2018 08:44 PM)John Keith Wrote:  With any of the examples from the Help screen, chisquaret causes a warm start on the physical calculator but works (seemingly) OK on the virtual calc (Windows 7). Identical CAS settings on both.
I can confirm. But some examples run well in Home; in CAS they restart the calculator.
Ok with the iOS version, both in Home and CAS.
Salvo
∫aL√0mic (IT9CLU), HP Prime 50g 41CX 71b 42s 12C 15C - DM42 WP34s :: Prime Soft. Lib
02-03-2018, 08:57 PM
I tried example 7, that results in an error: "Not enough degree of freedom..." 2 others, 3 and 8, crash.
Arno
