HP 12C Speed Test
12-29-2022, 06:01 AM
RE: HP 12C Speed Test
(12-27-2022 02:14 PM)ctrclckws Wrote: A better test is the calculation of Pi program at this page. My 12CP finished the test (12c code) in 45 minutes, there only is 0.00 as result on the screen. So it must be one of the "slow" 12CP? The calculator has been made by Kinpo factory in the Philippines in (I believe) 2021. HP-12C Gold / HP-12C Platinum |
12-29-2022, 10:24 AM
There is a note in the 12CP program area about how to see the results of the 12CP version.
If you were using the 12C code, you have to RCL the memory registers. RCL 0 through RCL 9, and RCL .0 or something similar. |
12-29-2022, 03:52 PM
(12-29-2022 10:24 AM)ctrclckws Wrote: There is a note in the 12CP program area about how to see the results of the 12CP version. OK thanks, I will try the RCL function. HP-12C Gold / HP-12C Platinum |
12-30-2022, 01:03 AM
Indeed, after the test finished all the 20 registers R0-R9 and R.0-R.9 are filled with numbers, not sure what they mean though.
12-30-2022, 12:52 PM
Register 0 should have 3
Register 1 should have 1415926 Register 2 should have 5358979 And so on. These are the digits of pi, in order. |
12-31-2022, 05:11 AM
(12-30-2022 12:52 PM)ctrclckws Wrote: Register 0 should have 3 Thanks. HP-12C Gold / HP-12C Platinum |
01-08-2023, 04:36 PM
(08-22-2017 08:26 AM)Gamo Wrote: I'm wondering how much the computation speed difference between HP 12C App for Android with Samsung S7 and Physical HP 12C+ by using this simple loop program. HP-12C Platinum (4mhz cpu) : 2449 per second. HP-12C Gold / HP-12C Platinum |
01-08-2023, 06:57 PM
I tried the speed test described in this page :
https://www.hpmuseum.org/speed.htm My result is 118, so 118 / 679 x 100 = 17.38% the HP 9100 speed. HP-12C Gold / HP-12C Platinum |
