HP 50g: PUT Bug?
03-09-2014, 06:35 PM
HP 50g: PUT Bug?
the following code is not changing the contect of a Variable as espected.
How to: in ALG mode: [0,0]STO XX PUT(XX,1,5) RCL XX shows still [0 0]. Is that a Bug ? Can somenone reproduce it? |
03-10-2014, 03:51 AM
RE: HP 50g: PUT Bug?
(03-09-2014 06:35 PM)Alvaro Wrote: How to:I'm afraid nobody here, unless they switch their machines to ALG mode. I wouldn't do it. Here is a hint for you - turn your HP50 into RPN mode like everyone else around here, than you will speak the same language. |
03-14-2014, 04:08 PM
(03-09-2014 06:35 PM)Alvaro Wrote: the following code is not changing the contect of a Variable as espected. Hi, It is not a bug. After you do the PUT command the stack will show [5 0]. You have to store this new vector into the old one with STO XX. Hope this helps. Jim |
03-14-2014, 07:21 PM
(03-14-2014 04:08 PM)JimS Wrote: Hi, Thank you Jim, It was very important for me your advise. I already had stopped all programing tries because of that PUT. Yes, the STO command must be issued too. There is the Algebraic Mode but it is still a "Stack" oriented Calc. I had tried that STO too, I still had it stored as a Program for the testing. I can not believe that I did not see it. Maybe I had switched to the stack mode before I used the program. Thanks again. Regards |
User(s) browsing this thread:
