04-July-2017 Virtual Keys - Virtual Keyboard v1.3b [Updated]
04-28-2017, 07:12 AM
(This post was last modified: 07-04-2017 05:21 AM by Freire.)
[Original Idea: primer On this Forum Thread.]
--------- Virtual Keys --------- Updated to v1.3b: 04/July/17 I would like to see this implemented by HP in a more powerful way. Made for Phisical calculator software 10637. It works fine in the emulator 11226. Download is at the end of the post. v 1.3b: 04/07/2017 -New display mode -More Keys -Possibly introduced some bugs, please report if any seen -Changed some keys on Symbolic -No more background graphic bugs v 1.3: 18/06/2017 -Faster Functions -Faster typing is possible (Investigating ways to improve interaction) -Changed lot's of internal calculations (things are prettier) -Changed cursor from arrow to simple line -No more ABC layout. v 1.2: 08/06/2017 -Added Symbolic Keys -Added Greek Keys -Keyboard reworked and smothed -Added more power to physical keys -Lots of code changed and added v 1.1a: 29/04/2017 -ALPHA key changes the keyboard CAPSLOCK -Tiny change to code -Solved possible issues with touch v 1.0: 28/04/2017 -Release Quick Guide: - The Physical Keys Only handle Normal and Shifted Presses. - [Shift]+[Help] - User Mode, 2 Times for permanent User Mode. - [ALPHA]+[Dot] - Opens Virtual Keys (Under User Mode) - Physical Keys: [Note: Left and Right arrows also have Original Behaviour] Features to come: -Configurable Quick Toolbar -Multiple Line Input -Configuration Screen Screenshots: Qwerty Layout Greek Layout Symbolic Layout Do you have any kind of Improvement/Suggestion? PM or reply I made this to help people use better the HP Prime. Tell me your feedback =D Updated Version: [04/Jul/2017] Virtual_Keys_v1_3b.hpprgm (Size: 56.91 KB / Downloads: 221) Virtual_Keys_Source_v1_3b.txt (Size: 21.04 KB / Downloads: 156) |
04-29-2017, 10:50 PM
(This post was last modified: 04-29-2017 10:51 PM by primer.)
RE: 28-Apr-2017 Virtual Keys - Virtual Keyboard
Thank you Freire, that's a nice update. I know that QWERTY layout was a requested feature. it's a good job. I'm sorry, I made a updated version of vkb several weeks ago, but I never had time to polish it to post it on the forum. The bad news is that you made your version on an outdated version of vkb. So, if one could find it helpfull, I post here the last version. Ok, it's not cleanly polished yet, (it have one dependance for the time : libmenu v3) but it works and fixes few things. vkb.hpprgm (Size: 15.86 KB / Downloads: 57) I won't go in detail about all changes in this post, but I added new keys (greek, math, indices...) primer |
04-30-2017, 08:39 AM
Hello, primer!
It's very nice to see an update of the vkb I hope the little I coded here can save you some work on next version! |
04-30-2017, 09:19 AM
(04-30-2017 08:39 AM)Freire Wrote: Hello, primer!Hi Freire, I don't know, I changed many things internally to have more flexibility, added a shift mode, and take profit of my lib menu. Our versions may be difficult to merge now, that's a shame I built that version about 2 month from now, I should have update it earlier. In a way, it's not that bad, as it gives more choices to users. Best Regards. primer |
07-04-2017, 05:21 AM
RE: 04-July-2017 Virtual Keys - Virtual Keyboard v1.3b [Updated]
Updated to version 1.3b
07-10-2017, 09:20 PM
RE: 04-July-2017 Virtual Keys - Virtual Keyboard v1.3b [Updated] | |||
07-12-2017, 02:48 AM
(This post was last modified: 07-12-2017 02:48 AM by Freire.)
I'll take a look into this, and will probably post an update for the dark theme! Thanks for the feedback.
07-12-2017, 01:48 PM
(07-12-2017 02:48 AM)Freire Wrote: I'll take a look into this, and will probably post an update for the dark theme! Thanks for the feedback. Thanks for your reply! Meanwhile I just changed the colors to be able to use in dark mode! If it prove useful to someone until you can update the keyboard... well than it's attached! Cheers |
07-31-2017, 11:30 PM
(07-12-2017 01:48 PM)vdmascarenhas Wrote:(07-12-2017 02:48 AM)Freire Wrote: I'll take a look into this, and will probably post an update for the dark theme! Thanks for the feedback. This is very helpful, thank you! I was just going to convert the colors for dark theme when I saw your post. |
09-29-2017, 08:32 PM
How do i run this program? Obviously I'm a newbie when it comes to these tings
10-01-2017, 11:04 PM
(09-29-2017 08:32 PM)tdh79 Wrote: How do i run this program? Obviously I'm a newbie when it comes to these tings 1. Install the program. 2. Select User ([Shift]+[Help] - twice for permanent User Mode). 3. Select = ([ALPHA]+[Dot] - this opens the virtual keys on your calculator). It's a very nice program! Jim |
12-13-2017, 12:51 PM
Thank you for this! Just bought an HP Prime and the keyboard was the only thing that took me 1 week to decide for it against the TI nspire
02-09-2018, 03:16 PM
(04-28-2017 07:12 AM)Freire Wrote: [Original Idea: primer On this Forum Thread.] The programm is usefull, but doesn´t work nicely with lastest firmware (13333). When you select (ALPHA + DOT) in User mode, nothing happens. |
02-09-2018, 10:24 PM
13333 has broken lots of programs. We can either code work arounds to all the broken programs, or await a firmware update which will fix them all.
See this thread. |
02-09-2018, 11:01 PM
(02-09-2018 10:24 PM)Mark Power Wrote: 13333 has broken lots of programs. We can either code work arounds to all the broken programs, or await a firmware update which will fix them all. Maybe to wait for an update is better, IMHO. I would like to believe that the HP team could release it asap (and thanks in advance!)... Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
02-10-2018, 08:53 PM
Same here, ALPHA+DOT doesn't respond after 1 use
11-04-2018, 12:40 PM
(This post was last modified: 11-04-2018 07:24 PM by nbenm.)
When I try to execute it, I have an exclamation mark. Nothing else. I use version: 2.1.14181 Any idea? |
03-25-2019, 05:28 AM
I know this thread is old, but I really wanted the virtual keyboard on the prime, so I edited Virtual Keyboard to work on the latest firmware. I'm just sharing this fixed version in case anyone else really wanted this feature like me.
04-09-2019, 02:59 AM
(03-25-2019 05:28 AM)mrh100000 Wrote: I know this thread is old, but I really wanted the virtual keyboard on the prime, so I edited Virtual Keyboard to work on the latest firmware. I'm just sharing this fixed version in case anyone else really wanted this feature like me. First of all, thanks for patching it. but mine doesn't work with it; I guess because of the firmware which it says 1.4.9 Do you think this is the issue that's why it is not loaded properly in my hp? |
04-09-2019, 03:01 AM
