HP16C behavior on overflow when entering numbers?
07-29-2023, 02:01 AM
I have a question about numeric entry on an HP16C, for an enhancement to my 16C simulator (https://jrpn.jovial.com/). Could someone with an actual 16C try out these examples for me, please? The enhancement is described at https://github.com/zathras/jrpn/issues/53 My guess is that behavior in 8 bit decimal signed 2's complement mode when pressing digits without pressing enter would be: 255777777 gives -1 254777777 gives -2 256777777 gives 25 256477777 gives -2 (the 6 is ignored, but the 4 isn't) and in 10 bit decimal signed 2's complement mode: 5127777777 gives -512 1023777777 gives gives -1 1024777777 gives 102 1024177777 gives -3 Right now, my simulator isn't stopping before overflow, so e.g. pressing the 7 key continues to change the display - not altogether unreasonable, but it seems that's not what the real 16C does. My simulator is cleanroom, and I don't own a 16C, so the example on page 37 of the owner's handbook was all the specification I had. It doesn't say what happens if you overflow, rather than just having bits propagate into the sign bit. So: Now my theory is that, during digit entry, it's OK if bits propagate to the sign bit, but keystrokes that result in actual overflow are ignored. I think my four examples above are sufficient to tell me if this is right! Cheers, Bill |
07-29-2023, 02:37 AM
(This post was last modified: 07-29-2023 02:39 AM by mfleming.)
RE: HP16C behavior on overflow when entering numbers?
Confirmed on my 16C (2251A) though the keys can sometimes not register. g-Clx between entries.
Edit: no overflow flag. Remember kids, "In a democracy, you get the government you deserve." |
07-29-2023, 04:43 AM
RE: HP16C behavior on overflow when entering numbers? | |||
07-30-2023, 02:19 AM
(This post was last modified: 07-30-2023 02:19 AM by billf.)
(07-29-2023 02:37 AM)mfleming Wrote: Confirmed on my 16C Hi again, Another question, if you don't mind. How does BSP behave in these cases? I think two tests would be sufficient here... In 8 bit 2's complement signed integer mode: CLX 2 5 5 (display reads -1) BSP (what happens?) CLX 1 2 0 7 (display reads 127) BSP (I'm guessing 12?) I can think of two reasonable outcomes for 255: a) Display reads "1" (as if you had pressed 1 CHS), or b) display reads 0, that is, BSP becomes like CLX when the displayed value is modified from the keystrokes. Right now, my simulator does a), but I have a sneaking suspicion that b) might be what the real calculator does. b) requires a flag indicating an unsigned->signed conversion, but that flag is needed anyway to get the other observed behaviors. |
07-30-2023, 03:36 AM
HP-16C S/N: 2332A05061
(07-30-2023 02:19 AM)billf Wrote: In 8 bit 2's complement signed integer mode: Code: DEC (07-30-2023 02:19 AM)billf Wrote: CLX 2 5 5 (display reads -1) BSP (what happens?) Code: CLX // 0 d (07-30-2023 02:19 AM)billf Wrote: CLX 1 2 0 7 (display reads 127) BSP (I'm guessing 12?) Code: CLX // 0 d |
07-30-2023, 07:37 AM
Interesting, thanks! Not what I was guessing at all, but I think I see what it's doing.
One more test, if someone would be so kind. I messed up the "1207" example. Here's what I meant to check: 8 bit unsigned decimal mode, and press CLX 258 (display reads 25, I think) 4 (I'm expecting 254) BSP (I'm expecting 25) BSP (expecting 2). That is to say, the 8 keypress is completely ignored. My theory on signed entry: It's got the flag for "converted from unsigned", and on BSP, if the flag is set, it converts *back* to unsigned and takes off the least significant digit. |
07-30-2023, 07:58 AM
Yes, can confirm that.
HP16C (serial 2641A) Code: DEC Cheers, Thomas [35/45/55/65/67/97/80 21/25/29C 31E/32E/33E|C/34C/38E 41C|CV|CX 71B 10C/11C/12C/15C|CE/16C 32S|SII/42S 28C|S 48GX/49G/50G 35S 41X] |
User(s) browsing this thread:
