Connect HP41 to Apple
12-14-2023, 06:37 PM
Hi, I am using my HP41CY in the office every day. its powered neatly by the USB Powersupply from Diego.
I would like to have an easy way to move different roms from the computer into the RAMBOX of the CY. Exchanging progam code would be a nice plus but are of secondary interest. What is the most elegant set-up possible today for me to do so - from a modern Apple computer. Any tips will be much appreciated (even though they might be detrimental to my work productivity at times...) Cheers, PeterP Cheers, PeterP |
12-15-2023, 05:09 AM
(This post was last modified: 12-15-2023 04:18 PM by Sylvain Cote.)
RE: Connect HP41 to Apple
Hello Peter,
To transfer files between the HP-41 and my MacBook Pro intel, I use the following:
Create a LIF volume file of 128KB that can hold a maximum of 64 files Code: lifinit -z -m cass tape01.dat 64 Set LIF volume name to TAPE01 Code: liflabel tape01.dat TAPE01 Show lif volume catalog Code: lifdir tape01.dat Code: Volume : TAPE01 , formatted : 14/12/23 23:00:00 In pyILPER,
Transfer HP-41 program(s) from the computer to the HP-41 Computer side Write your program in a text file Ex.: cat hello.txt Code: LBL "HELLO" Compile the HP-41 program from a text file to a raw file Code: comp41 <hello.txt >hello.raw Add a lif header with a name Code: raw41lif HELLO <hello.raw >hello.lif Add lif file to the lif volume Code: lifput tape01.dat hello.lif Show lif volume catalog Code: lifdir tape01.dat Code: Volume : TAPE01 , formatted : 14/12/23 23:00:00 HP-41 side Read HELLO program from tape to main memory Code: "HELLO" Transfer HP-41 program(s) from the HP-41 to the computer HP-41 side save WORLD program from main memory to tape Code: "WORLD" Computer side Catalog lif volume Code: lifdir tape01.dat Code: Volume : TAPE01 , formatted : 14/12/23 23:00:00 Save WORLD program to a raw file Code: lifget -r tape01.dat WORLD world.raw Decompile the HP-41 program from a raw file to a text file Code: decomp41 <world.raw >world.txt cat world.txt Code: LBL "WORLD" Transfer HP-41 ROM from the computer to the HP-41 Computer side Show ROM content Code: rom41cat <math.rom Code: XROM 01,00 Entry = 0068 (Mcode) -MATH_1D Convert ROM file to ERAMCO Code: rom41er MATH1D <math.rom >math.lif Add ROM lif file to the lif volume Code: lifput tape01.dat math.lif Catalog lif volume Code: lifdir tape01.dat Code: Volume : TAPE01 , formatted : 14/12/23 23:00:00 HP-41 side load MATH1D ROM from tape to rambox page Code: "MATH1D" // ROM filename Transfer HP-41 ROM from the HP-41 to the computer HP-41 side Save a ROM page from rambox page to the tape Code: "MYROM" // ROM filename Computer side Catalog lif volume Code: lifdir tape01.dat Code: Volume : TAPE01 , formatted : 14/12/23 23:00:00 Get MYROM ROM from lif volume to a ROM file in ERAMCO format Code: lifget -r tape01.dat MYROM myrom.er Convert the ERAMCO file to a ROM file format Code: er41rom <myrom.er >myrom.rom Show ROM content Code: rom41cat <myrom.rom Code: ... edit: add more information for pyILPER Sylvain Côté |
12-15-2023, 02:31 PM
Sylvain, wow, this is perfect and something I can implement given I have all the pieces. Thank you so much!
And even more so for the wonderful detail and structure in how you have laid this out for me. Thank you for taking the time! Now I just have to come up with a good answer to "so what is this old black box connected to that smaller grey box connected to that kind old looking calculator doing on your desk? Cheers Peter Cheers, PeterP |
12-16-2023, 12:52 AM
Awesome instructions!
Thank you so much! (12-15-2023 05:09 AM)Sylvain Cote Wrote: Hello Peter, |
12-16-2023, 12:57 AM
(12-15-2023 02:31 PM)PeterP Wrote: Sylvain, wow, this is perfect and something I can implement given I have all the pieces. Thank you so much! (12-16-2023 12:52 AM)Bill Duncan Wrote: Awesome instructions! Thank you so much!Glad I could help (12-15-2023 02:31 PM)PeterP Wrote: Now I just have to come up with a good answer to "so what is this old black box connected to that smaller grey box connected to that kind old looking calculator doing on your desk?Well, this is out of my reach. Sylvain Côté |
01-20-2024, 12:29 PM
LS,
I wrote a lot of programs for my old HP41CV (which is dead since yesterday, 44 years old…, but I have a second one) and had some experience to copy these programs, making use of an HP-IL HP41 interface and a so-called Pil-box. For that purpose, I made use of a file transfer program Ilper.exe. The transfer was not very stable, because sometimes it did not recognize COM 5 (my USB, I believe) and also gave an error at the end sometimes. However, some years ago I was successful in transferring programs in that way and used a file conversion program named HP41UC. I made notices of it and made the use of option /l to /t, i.e. *.lif to *.txt. For some reasons that does not work anymore, but I still had the *.dat file from the original file transfer and a *.txt file from the conversion result. In the meantime I looked at the *.dat file and copied it to a *.BIN file and a *.RAW file. In that case the transfer to the *.TXT file worked, but with some typical headers. Question to you is: What is the original file format resulting from the HP41 to HPIL transfer and what kind of headers are connected to the raw and bin format? Do you have an idea why the transfer is not very stable? Do you think there is a mismatch in serial? Settings or so? Now, I am using an older Windows computer. The *.exe work under a DOS environment. I tried a parallel desktop with windows 11 on my Mac Studio, but then the *.exe do not work. Has someone an idea how to solve these problems? Sorry for the long intro… Hope you have time to answer… Kind regards, Henk Schellen |
01-22-2024, 06:57 PM
Dear Sylvain,
This is a beautiful overview for people like me who do not have a lot of experience with the exchange of files between different systems. I was able to exchange files between my HP41 and windows and now with your help I am able to transfer files between my HP41 and my Mac, making use of 82160A - HP-41/IL interface PIL-Box - HP-IL/USB interface pyILPER - virtual HP-IL peripherals lifutils - LIF/41/71/75 files utilities I wonder if you have an analog overview for transferring files/programs between my HP71B and my Mac. Thanks on forehand. Kind regards, Henk Schellen |
01-23-2024, 01:24 PM
Hello Henk,
I do not have any free time right now, I will post an answer to your last two messages in a couple of days. Sylvain Côté |
01-23-2024, 05:45 PM
Dear Sylvain,
Thank you. I look forward to it. Kind regards, Henk |
01-24-2024, 01:59 AM
(This post was last modified: 01-24-2024 02:05 AM by Sylvain Cote.)
Hello Henk,
(01-20-2024 12:29 PM)hesc Wrote: What is the original file format resulting from the HP41 to HPIL transfer and what kind of headers are connected to the raw and bin format? HP-41 compiled program file formats Code: .RAW → [compiled code] + [1-byte checksum] + [trailer] HP-IL formats Code: .LIF → LIF file - a file with a 32-byte lif header Code: .LIF → [32-byte header] + [file data] More information can be found here:
(01-20-2024 12:29 PM)hesc Wrote: Do you have an idea why the transfer is not very stable?I have never used HP41UC so I cannot help you here. Sylvain Côté |
01-24-2024, 10:33 AM
(01-22-2024 06:57 PM)hesc Wrote: I wonder if you have an analog overview for transferring files/programs between my HP71B and my Mac.A mac is expensive. A ligther version is possible ;-) https://www.hpmuseum.org/forum/thread-19...#pid181142 HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
01-24-2024, 02:55 PM
Dear Sylvain,
Thank you for the overview. In the meantime I solved my connection problems between HP71 and Mac. Yesterday, I published a new tread on it. If you have time, would you please have a look at it foor possible corrections? Thanks, Henk |
