How to enter an equation
12-22-2020, 11:58 AM (This post was last modified: 12-22-2020 12:24 PM by Gene.)
Hi Forum,
please find a screendump of my Prime attached. Could someone tell me how to do it right? I want so solve for m2, then put figueres in for the variables and calculate.
Thanks a lot, Andreas
Attached File(s)
.pdf  Bildschirmfoto 2020-12-22 um 11.56.13.png.pdf (Size: 541.17 KB / Downloads: 40)
12-22-2020, 02:38 PM (This post was last modified: 12-22-2020 02:45 PM by victorvbc.)
RE: How to enter an equation
You have to be in the CAS environment for that.
12-22-2020, 05:37 PM
(12-22-2020 02:38 PM)victorvbc Wrote:  You have to be in the CAS environment for that.
Thanks a lot! The input and the solving for m2 worked perfect. This must have been easy. But, where did you get the yellow Shift "U" in the upper left corner, to obtain the ANS(....)?
Andreas
12-22-2020, 07:50 PM
(12-22-2020 05:37 PM)areisbeck Wrote:  But, where did you get the yellow Shift "U" in the upper left corner, to obtain the ANS(....)?
That indicates a locked User keyboard; press User ("Shift Help") twice. Pressing it once (1U) will activate the User keyboard for the next keypress. Pressing it twice (^U) will keep it activated.
But Ans is "Shift +".
Cambridge, UK
Casio, Rockwell 18R
12-23-2020, 02:59 PM
Solving the equation for m2 works now. Thank you very much! But how do I get the values into the list and a solution for them?
It does not work with "Shift Ans", bracket, Variable=.., .., Enter
It really great to get help here - Thanks a lot.
