Most common calculators in the forum? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Most common calculators in the forum? (/thread-9594.html) |
RE: Most common calculators in the forum? - cortopar - 05-21-2018 04:10 PM 35 25 x 2 27 97 34c 41cv x 2 75c 71b x 2 11c 12c x 5 15c 42s 17bII x 4 28s 48sx 48gx 50g x 3 35s x 2 15c LE x 2 30b 30b->34s x 2 Prime RE: Most common calculators in the forum? - brickviking - 05-22-2018 03:12 AM (05-21-2018 05:40 AM)grsbanks Wrote:(03-03-2018 09:20 PM)brickviking Wrote: I know HP used the 85MS as a model for their HP-10S and 10S+. Ah, okay. The 10s and s+ have several keys swapped around from the FX-82/85MS layout; arrow keys match the 48-family more closely; the x^3, a/b/c, square root and some other keys moved around, so there must have been some work done on the keyboard matrix at least for HP. The only other difference I can see for the 10s+ is a slightly different colour scheme. Under certain lights, I suspect that'll be harder to read the llight blue. My only experience with the HP-10s was a bad model, as several lines of dots from the top line disappeared, otherwise I would have kept it, and it would have cost me more money to send back to the retailer for a refund. The laugh is, I'd been prompted to buy the calculator because the listing showed 128kb of memory. Clearly most of that memory wasn't accessible for programming, and indeed the calculator isn't programmable. I have my doubts about whether the 128kb of memory figure was correct, even considering that some memory would have been set aside for statistics variables and regression calculations. (Post 228) RE: Most common calculators in the forum? - grsbanks - 05-22-2018 07:36 AM (05-22-2018 03:12 AM)brickviking Wrote: Ah, okay. The 10s and s+ have several keys swapped around from the FX-82/85MS layout; arrow keys match the 48-family more closely; the x^3, a/b/c, square root and some other keys moved around, so there must have been some work done on the keyboard matrix at least for HP. They will have got Casio to make a few alterations to the ROM. But here's one change they didn't get Casio to make (very likely an oversight): https://www.youtube.com/watch?v=4F873-zbyM8 RE: Most common calculators in the forum? - brickviking - 05-22-2018 09:18 AM (05-22-2018 07:36 AM)grsbanks Wrote:(05-22-2018 03:12 AM)brickviking Wrote: Ah, okay. The 10s and s+ have several keys swapped around from the FX-82/85MS layout; arrow keys match the 48-family more closely; the x^3, a/b/c, square root and some other keys moved around, so there must have been some work done on the keyboard matrix at least for HP. Here's a weird thing. Multiple people indicate that they have that contrast setting on their calculator; either it's hidden (but is working), or it shows up and is working. My FX-82MS doesn't show that contrast setting, nor does hitting the "2" key at the right place trigger a setting for contrast. I'm not sure if they customise them by country. I couldn't exactly say what date I bought it either, just that it was several years after I'd got my 82-TL. The date code on my circuit board says 02094, the main board identifier reads GY313-1, so I'm guessing it's the first revision. Another identifier on the board: HA210314A-2. Hardware hacking the calculator? Hm. There's four places to put more capacitors, but no capacitors in those positions nor (mostly) lands to solder them to. At least this post should probably have been in "Not Remotely HP", due to its drift from the original subject of "most common calculator". Let's get it somewhat back on track. Currently in NZ, the most common calculator in a kid's home will either be some variant of FX-82 such as the ES Plus, AU Plus or descendants thereof, or if they're in the last years of their schooling, it would be the 9750gII. After they finish school, you can often find their calculators on Trademe (a NZ-based auction site) for much less than the new calculator was originally bought for. I picked up my gII in just this way, as I really really didn't want to pay the new price of $154.95 (NZ dollars). (Post 230) RE: Most common calculators in the forum? - gcmrtin1 - 05-24-2018 08:41 PM I've owned many since the 1970s, but here's my current collection: HP Prime HP 50G HP 48GX (purchased 1992) HP 39G HP 30b HP 20b HP 19BII x2 with backdoor (purchased one in 2000) HP 18C HP 17bII+ HP 17BII HP 17B HP 10b HP 10bII+ HP 14B 50th HP 12C (purchased 1985) HP 12C 30th HP 12C 25th HP 45 (father purchased 1974) TI Nspire CAS CX Palmtops with Calculator Emulators HP OmniGo 100 with 12C HP 200LX with 19BII enhanced functionality 82240B Thermal IR Printer RE: Most common calculators in the forum? - wyatt8740 - 05-28-2018 04:15 AM 28S x 1 48SX x 1 That is all. I feel like a big fat phony 'enthusiast,' but as a student I can't really afford to start buying up all of the more expensive models. The 28S and 48SX appear to be some of the cheapest old HP calcs around, and I really like the 28S form factor in particular. I especially can't afford to buy more calculators after my car (a Volvo 240) got crunched and I had to foot the bill to fix it (hit and run). (I also have a TI-89 titanium and some old four-function casio from the 80s that I can't remember the model number of) RE: Most common calculators in the forum? - marcel_911 - 05-31-2018 05:56 AM HP12C x 3 (Original 1982 + 2 x Singapore) HP12C Platinum HP16C HP50g HP30b TI30 Galaxy RE: Most common calculators in the forum? - edryer - 09-03-2018 08:55 PM Not many, but use daily as tools. HP-16C (1985 manufactured) and a DM-16CC as a backup, actually ordered a DM-16L from a used store but they sent me the CC (Credit card version) and as it was only 30 Euros used I kept it, but quite hard to use daily, so sticking with the 16C. RE: Most common calculators in the forum? - pinkman - 09-03-2018 09:50 PM HP : 12C 15C 17BII+ 35S 49G+ Prime TI : 89 RE: Most common calculators in the forum? - Robert VM - 09-05-2018 07:57 PM (03-03-2018 05:23 AM)Gerson W. Barbosa Wrote: Reminds me of a book I read in the original Portuguese when I was 14. Quoting from The Man Who Counted: Thanks for mentioning, looks like a great book! RE: Most common calculators in the forum? - cdmackay - 11-16-2018 02:36 PM as per my sig; thanks. RE: Most common calculators in the forum? - Jlouis - 11-17-2018 02:58 AM (05-28-2018 04:15 AM)wyatt8740 Wrote: 28S x 1 I agree with you, the 28c/s have a very elegant and usefull form factor. I really enjoy them. When I use them in a public place, many people look at them and some start a conversation about them. As for the TI 89 titaneum, you are correct in not counting it in your collection. I have one that is very useful as a paper weight or a door stop. Cheers JL RE: Most common calculators in the forum? - ijabbott - 11-17-2018 10:29 AM (11-17-2018 02:58 AM)Jlouis Wrote:(05-28-2018 04:15 AM)wyatt8740 Wrote: (I also have a TI-89 titanium and some old four-function casio from the 80s that I can't remember the model number of) Wouldn't a calculator with more of a wedge shape be better as a door stop? Say, a HP-41C? RE: Most common calculators in the forum? - grsbanks - 11-17-2018 11:06 AM (11-17-2018 10:29 AM)ijabbott Wrote: Wouldn't a calculator with more of a wedge shape be better as a door stop? Say, a HP-41C? Heresy!!! RE: Most common calculators in the forum? - ijabbott - 11-17-2018 11:56 AM (11-17-2018 11:06 AM)grsbanks Wrote:(11-17-2018 10:29 AM)ijabbott Wrote: Wouldn't a calculator with more of a wedge shape be better as a door stop? Say, a HP-41C? OK then, a TI-30. And a TI Voyage 200 makes a decent paperweight (and a decent calculator at the same time!). RE: Most common calculators in the forum? - Maximilian Hohmann - 11-17-2018 12:09 PM (11-17-2018 11:56 AM)ijabbott Wrote: And a TI Voyage 200 makes a decent paperweight (and a decent calculator at the same time!). Exactly! A true multi-purpose machine :-) And, I hardly dare say that on this forum, if I had to go back to university now I personally would take a Ti89 or Voyage200 rather than any calculator made by HP after 1980. And to complete this survey (and contribute to the statistics...) since I last answered this thread I have accumulated, among others, the following calculators: HP-27 HP27s Elorg 51 HP-41CV (yet another one) Ti59 (yet another one) Cateck Magic Keyboard and Calculator (very stylish and hard to find bluetooth keypad with large 12-digit display - but four functions only.) Canon F-61 Canon F-71 HP-25C (yet another one) 2xTamaya/Riefler Planix 7P (a digital planimeter, but it can be used as a standalone printing calculator and therefore counts as one in my eyes. This, by the way, would be the ideal paperweight/doorstopper!) Commodore N60 (my second one) Regards Max RE: Most common calculators in the forum? - JMBaillard - 11-17-2018 12:40 PM Hi ! HP41CX HP48GX HP50G WP34S Free42 Have a great weekend. RE: Most common calculators in the forum? - Roland57 - 11-18-2018 10:17 AM Hi ! My collection: Hp35 2.Gen Hp35 3.Gen Hp35 4. Gen Hp80 Hp45 Hp55 2x hp65 Hp70 hp67 (with sin-1(o.000003) error) Hp67 without sin-1 error Hp91 Hp92 hp97 old PCB and with sin-1 error Hp97 new PCB prepared for S-version, without sin-1 error Hp21, 22, 25C, 27, 29C Hp19C 2x Hp10C, Hp11C, Hp12C, Hp12C Platinum 25th Anniv. Edition Hp12C 30th Anniv. Edition Hp15C, Hp15C Limited Edition Hp16C Hp14B 50th Anniv. Edition Hp32S 50th Anniv. Edition Hp32SII Hp18C Hp19BII 2x hp28S Hp48SX 2x hp48GX Hp50 HpPrime (1.Gen) 2x hp71 (1BBBB) 2x hp85A Hp9100B Roland RE: Most common calculators in the forum? - John Keith - 11-18-2018 09:26 PM Welcome to the Forum, Roland- very impressive collection! RE: Most common calculators in the forum? - morex - 12-05-2018 02:47 PM Hello. This is my collection: Hewlett-Packard 10C Hewlett-Packard 11C x 2 Hewlett-Packard 12C x 2 Hewlett-Packard 15C (bought new 1984) Hewlett-Packard 16C Hewlett-Packard 28C Hewlett-Packard 28S Hewlett-Packard 32S Hewlett-Packard 32SII (bought new 2000) Hewlett-Packard 33C Hewlett-Packard 41C Hewlett-Packard 41CV (bought new 1985, not working) Hewlett-Packard 41CX (bought new 1986) Hewlett-Packard 42S x 2 Hewlett-Packard 48G Hewlett-Packard 48SX (not working) Hewlett-Packard 97 Hewlett-Packard 100LX Casio 8E Casio FC-100 x 2 Casio fx-10 Casio fx-19 Casio fx-29 Casio fx-39 Casio fx-120 Casio fx-140 Casio FX-602P (bought new 1983) Casio FX-720P Casio Memory-10GT Casio Mini CM-602 Casio Mini CM-604 Casio PB-700 Casio personal-I Casio pocket-mini Intelect (Nixie Tubes) Microcifra 10 (RPN) x 2 Sanyo ICC-808D Texas Instruments TI-2550 Some other old 4 op. calculators |
