41CL Self-Update - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 41CL Self-Update (/thread-9269.html) |
RE: 41CL Self-Update - Sylvain Cote - 10-29-2017 02:21 PM Hello Jurgen, (10-29-2017 11:43 AM)JurgenRo Wrote: As far as I did understand you, Sylvain, the Manual will do exactly that.That is the intent, now it may take several revisions before reaching that goal, but I will do my best to be near it on the first version. Just be clear, the manual will cover the complete solution, calculator & computer, but its focus will be on the computer side of the equation. Monte has created a great and detailed manual for the update ROM that cover the calculator side of the equation. (10-29-2017 11:43 AM)JurgenRo Wrote: But then again, Sylvain, I do not understand why you are writing a Manual at all if this is not necessary ... I must admit, I'm a litte bit lost on this hereThe rule of thumb is, if you publish a software without documentation, it does not exists because nobody but the writer is able to use it, so it is needed. The manual should have been available for HHC 2017, but I could not make this append and I am really sorry for that. In the meantime, all the information is there to do it, yes it may be cumbersome and time consuming, but at least its there. (10-29-2017 11:43 AM)JurgenRo Wrote: Sylvain, my last input was just to say "thank you".Thank you too for your interest in willing to update your 41CL. There is double translation happening here, French-to/from-English-to/from-German with open space for misunderstanding and we are both struggling with English. No offence was taken and it was not my intent to be offensive or rude, I was just trying to reset the expectations of what is or will be available. Kind regards, Sylvain RE: 41CL Self-Update - aurelio - 10-29-2017 03:45 PM (10-29-2017 11:43 AM)JurgenRo Wrote:My father when I was a child told me with admiration how the manuals for US army radiotransmitters were written so that anyone (not necessarily a technician or a radio operator) could use them in emergency situation: even the blacksmith or the pharmacist had to be in emergency able to use or even repair the equipment... That's what maybe we expect from a manual... that someone who had solved the problem for us should bring us by the hand...but it's not always possible and I know how it's hard(10-28-2017 11:45 PM)Sylvain Cote Wrote: Hello Jurgen, we must follow the main path and make "own" what us is given I've now indeed began my first upgrade and beeps remind me that work is in progress thank-you to Sylvain and Monte and expecially thanks to this last hint RE: 41CL Self-Update - aurelio - 10-29-2017 04:50 PM is up to your experience a new fresh alkaline pack sufficient for upgrading a couple of CL (procedure time 3h about each one) or it's better to plug a new fresh pack each time? RE: 41CL Self-Update - JurgenRo - 10-29-2017 06:10 PM (10-29-2017 01:17 AM)Geoff Quickfall Wrote: Firstly, Sulvain, you are a necromancer of the first order, I bow to you :-) Agreed, Geoff! An update service would absolutely great. Being located in Germany, a Support base somewhere in Europe (EU) would be wishful in terms of shipping time and costs ... RE: 41CL Self-Update - JurgenRo - 10-29-2017 06:22 PM (10-29-2017 02:21 PM)Sylvain Cote Wrote: Hello Jurgen, Hi Sylvain, thank you very much for clarifying this and, of course, for all your effort in the 41CL Project All the Best from Germany, Juergen RE: 41CL Self-Update - rprosperi - 10-29-2017 07:41 PM (10-29-2017 04:50 PM)aurelio Wrote: is up to your experience a new fresh alkaline pack sufficient for upgrading a couple of CL (procedure time 3h about each one) or it's better to plug a new fresh pack each time? Of course this will depend on how many ROM images need to be updated in each machine, however you can definitely get at least 2-3 complete updates, even for CL units from very early on. I have done several update cylces with >200 ROM images to be updated on a single set of batteries, and then used it often for weeks after that, all on one set of batteries. I keep a new set of 4xN batteries ready nearby my work area, but I would not expect to need them for just upgrading 2 machines. RE: 41CL Self-Update - aurelio - 10-29-2017 08:06 PM (10-29-2017 07:41 PM)rprosperi Wrote:Thankyou Bob, I have to update 76 ROMs for each one and just started the second(10-29-2017 04:50 PM)aurelio Wrote: is up to your experience a new fresh alkaline pack sufficient for upgrading a couple of CL (procedure time 3h about each one) or it's better to plug a new fresh pack each time? in the first attempt left one ROM outdated: 17:52:41 File CFLDB.ROM saved 17:52:41 Report Outdated ROM images [boardGeneration: SECOND] 17:52:41 Report YFNZ-4F.ROM [Page:0x007 ID:YFNZ Rev:2017-06-19 YCRC:0x 50EF10] 17:52:41 Report Summary: 1 outdated of 512 ROM images 17:53:05 Received CLOSE_CHANNEL_REQUEST(0x57) 17:53:05 Sent CLOSE_CHANNEL_RESPONSE(0x58) 17:53:09 Serial COM1 closed. RE: 41CL Self-Update - JurgenRo - 10-29-2017 08:14 PM (10-29-2017 07:41 PM)rprosperi Wrote:(10-29-2017 04:50 PM)aurelio Wrote: is up to your experience a new fresh alkaline pack sufficient for upgrading a couple of CL (procedure time 3h about each one) or it's better to plug a new fresh pack each time? You might even want to hook up your 41CL via a USB power module to a permanent power source during update. The idea is by Diego Diaz. Find the schematics to build one here: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv020.cgi?read=183722#183722 You will need a doner HP-module for it. Juergen RE: 41CL Self-Update - Massimo Gnerucci - 10-29-2017 08:17 PM (10-29-2017 08:14 PM)JurgenRo Wrote: You might even want to hook up your 41CL via a USB power module to a permanent power source during update. The idea is by Diego Diaz. Find the schematics to build one here: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv020.cgi?read=183722#183722 You will need a doner HP-module for it. That's what I always keep hooked on my CL. RE: 41CL Self-Update - aurelio - 10-29-2017 09:41 PM (10-29-2017 08:14 PM)JurgenRo Wrote:thankyou Jurgen, I did not yet read it(10-29-2017 07:41 PM)rprosperi Wrote: Of course this will depend on how many ROM images need to be updated in each machine, however you can definitely get at least 2-3 complete updates, even for CL units from very early on. RE: 41CL Self-Update - rprosperi - 10-29-2017 11:47 PM (10-29-2017 08:06 PM)aurelio Wrote: Thankyou Bob, I have to update 76 ROMs for each one and just started the second Great news, 1 down, 1 to go. Please add comments here when done to confirm the process is simple and safe; hopefully with a few more success stories, other users will jump in too. I've no idea why that image was not updated, I'll leave it to Monte or Sylvain to comment on that. Though it appears the one you have installed is quite recent anyhow, so it's unlikely this is any kind of problem. Thanks for sharing your progress. RE: 41CL Self-Update - Mark Hardman - 10-30-2017 12:21 AM (10-29-2017 11:47 PM)rprosperi Wrote:(10-29-2017 08:06 PM)aurelio Wrote: Thankyou Bob, I have to update 76 ROMs for each one and just started the second Page 0x007 is in the OS sector. Aurelio, you will need to set OSUPDT mode to allow the update process to write to that page (see page 37 of the 41CL Update Functions manual). As noted above, writing the OS sector takes longer than normal. This is discussed earlier in this thread. Mark Hardman RE: 41CL Self-Update - Sylvain Cote - 10-30-2017 12:35 AM (10-29-2017 04:50 PM)aurelio Wrote: is up to your experience a new fresh alkaline pack sufficient for upgrading a couple of CL (procedure time 3h about each one) or it's better to plug a new fresh pack each time?I only use rechargeable 1.2V 500MAH NIMH N CELL x 4 kits on my 41CL machines I have done more than 50 upgrade and downgrade in the past 18 months with these batteries without any issue. I have done several update on the same set of battery with the same charge, also without issue. I intentionally started an update when the batteries were weak to validate how the update ROM was handling the BAT indicator. As soon as the BAT indicator lighted up, the ROM shut down the calculator and did update the ALPHA register correctly. After putting back charged batteries, I was able to continue the update right were it stopped. RE: 41CL Self-Update - rprosperi - 10-30-2017 12:35 AM (10-30-2017 12:21 AM)Mark Hardman Wrote: Page 0x007 is in the OS sector. Aurelio, you will need to set OSUPDT mode to allow the update process to write to that page (see page 37 of the 41CL Update Functions manual). As noted above, writing the OS sector takes longer than normal. This is discussed earlier in this thread. Nice catch Mark, I missed that. And I looked only a few words away too.... RE: 41CL Self-Update - Sylvain Cote - 10-30-2017 01:25 AM (10-30-2017 12:21 AM)Mark Hardman Wrote:(10-29-2017 11:47 PM)rprosperi Wrote: I've no idea why that image was not updated, I'll leave it to Monte or Sylvain to comment on that.Page 0x007 is in the OS sector. Aurelio, you will need to set OSUPDT mode to allow the update process to write to that page (see page 37 of the 41CL Update Functions manual). As noted above, writing the OS sector takes longer than normal. This is discussed earlier in this thread. I run all my updates with the OS sector protection active. I deactivate the protection only when an infrequent OS sector update is needed and reactivate the protection right after the update. Normal update process ... Code: CMOPEN /// open up the communication link Now, if the outdated ROM report contains OS sector ROM to update, then I do the following: WARNING: be sure to have enough energy left in your batteries before doing this part. Code: OSUPDT /// deactivate OS protection Terminate the update Code: CMCLOSE /// close down the communication link RE: 41CL Self-Update - aurelio - 10-30-2017 05:21 AM (10-29-2017 11:47 PM)rprosperi Wrote:Sure...(10-29-2017 08:06 PM)aurelio Wrote: Thankyou Bob, I have to update 76 ROMs for each one and just started the second Second attempt like the first YFNZ-4F.ROM not updated I used the actual zip file "rom_files_171021" downloaded from Monte's site. today I'll check on the manual trying to understand what I miss RE: 41CL Self-Update - Monte Dalrymple - 10-30-2017 05:49 AM (10-30-2017 05:21 AM)aurelio Wrote:(10-29-2017 11:47 PM)rprosperi Wrote: Great news, 1 down, 1 to go. Please add comments here when done to confirm the process is simple and safe; hopefully with a few more success stories, other users will jump in too.Sure... The ONLY change from YFNZ-4E to YFNZ-4F was to make the functions fully compatible with V5 boards with the larger Flash memory. So if you have -4E installed there isn't really any need to upgrade this image. RE: 41CL Self-Update - aurelio - 10-30-2017 07:36 AM (10-30-2017 05:49 AM)Monte Dalrymple Wrote:OK thanks(10-30-2017 05:21 AM)aurelio Wrote: Sure... RE: 41CL Self-Update - aurelio - 10-30-2017 12:20 PM (10-30-2017 01:25 AM)Sylvain Cote Wrote:Sorry to have lost the chained previous messages: actually I thought there could be a protection 'cause Monte told about it on this post when I read the message updt done or something like that on the machine..I changed my mind. When I will back home in the evening I will check much better. If I understood the flowchart each time you need to make a updt with this automated procedure you have to perform a complete scan, isn't it?(10-30-2017 12:21 AM)Mark Hardman Wrote: Page 0x007 is in the OS sector. Aurelio, you will need to set OSUPDT mode to allow the update process to write to that page (see page 37 of the 41CL Update Functions manual). As noted above, writing the OS sector takes longer than normal. This is discussed earlier in this thread. RE: 41CL Self-Update - Sylvain Cote - 10-30-2017 01:59 PM (10-30-2017 12:20 PM)aurelio Wrote: Sorry to have lost the chained previous messages: actually I thought there could be a protectionCorrect, this is the easiest way to do the update but unfortunately also the longest. Now, if you read the advanced update section of the presentation, you will see that there alternative way to do an update that are very fast, like ~15 minutes. But you must understand the process intimately because you are doing manually what the FLCHK? function is doing automatically. Sylvain |
