question about quad memory module - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: question about quad memory module (/thread-6053.html) |
question about quad memory module - wojtek - 04-16-2016 09:18 PM Will quad memory module HP 82170A keep data when removed from the HP 41C? If so, for how long? RE: question about quad memory module - Geoff Quickfall - 04-16-2016 09:23 PM You can measure the length of time in, wait for it: SECONDS! :-) Try it! RE: question about quad memory module - wojtek - 04-16-2016 09:54 PM (04-16-2016 09:23 PM)Geoff Quickfall Wrote: You can measure the length of time in, wait for it: SECONDS! If I only had it... RE: question about quad memory module - Dave Frederickson - 04-16-2016 10:20 PM What you need is the HP-41 MEM-O-PAK which was a module wallet with battery backup. RE: question about quad memory module - TASP - 04-16-2016 10:53 PM I think I saw a PPC Journal article about how to install a cap in a module to extend pull time to hours. Might take me a while to find which issue . . . RE: question about quad memory module - wojtek - 04-17-2016 06:11 AM (04-16-2016 10:53 PM)TASP Wrote: I think I saw a PPC Journal article about how to install a cap in a module to extend pull time to hours. Thank you, I would be interested. The question regards changing batteriers in 41C with quad memory inserted. If quad module stay in a slot in 41C how much time one has for the battery change to not loose data in quad module, seconds? RE: question about quad memory module - wojtek - 04-17-2016 06:27 AM (04-16-2016 10:20 PM)Dave Frederickson Wrote: What you need is the HP-41 MEM-O-PAK which was a module wallet with battery backup. Thank you. For that price one could buy DM41 or DM41L from Swissmicros. BTW. How long DM41 and DM41L retain memory contents while batteries are pulled out? RE: question about quad memory module - Massimo Gnerucci - 04-17-2016 07:57 AM (04-17-2016 06:11 AM)wojtek Wrote:(04-16-2016 10:53 PM)TASP Wrote: I think I saw a PPC Journal article about how to install a cap in a module to extend pull time to hours. No, you have plenty of time if internal capacitors are ok. Even too much if you are trying to recover from a crash... ;) RE: question about quad memory module - Sylvain Cote - 04-17-2016 01:26 PM (04-16-2016 10:20 PM)Dave Frederickson Wrote: What you need is the HP-41 MEM-O-PAK which was a module wallet with battery backup. Very special little accessory that I acquire from Gene. Some pictures: inside, side, PCB & module. Sylvain RE: question about quad memory module - Ángel Martin - 04-17-2016 06:36 PM (04-17-2016 01:26 PM)Sylvain Cote Wrote: Very special little accessory that I acquire from Gene. Very nice! RE: question about quad memory module - Geoff Quickfall - 04-17-2016 06:57 PM I am so jealous! How about fabricating the board and making a kit for the non CL users? I know I would make one. Geoff RE: question about quad memory module - Sylvain Cote - 04-17-2016 07:47 PM (04-17-2016 06:57 PM)Geoff Quickfall Wrote: How about fabricating the board and making a kit for the man CL users? Geoff, I have put the unit on the project table and if I can replicate it without breaking it, I will gladly publish the PCB layout with the components so you can make one. Sylvain RE: question about quad memory module - Ángel Martin - 04-18-2016 05:07 AM (04-17-2016 06:57 PM)Geoff Quickfall Wrote: How about fabricating the board and making a kit for the non CL users? Everybody should have a CL! (and possibly a spare one). RE: question about quad memory module - Geoff Quickfall - 04-18-2016 06:25 AM Angel: :-) And see below: Sylvian: Merci! I think the Clonix module adapter would work perfectly in this application as they can be soldered to a standard bread board with the battery and caps attached and hard wired. That would preclude the need to create a dedicate PCA. Yes I remember, if you are quick, you can pull a quad from one machine and plug it into a second without losing data. Of course that is how the board that Sylvian has works. And only in seconds. RE: question about quad memory module - Sylvain Cote - 04-18-2016 07:58 AM (04-16-2016 10:53 PM)TASP Wrote: I think I saw a PPC Journal article about how to install a cap in a module to extend pull time to hours. PPC v6n7 24 cents RAM Mod RE: question about quad memory module - TASP - 04-18-2016 01:04 PM Oh thanks! That is the article. We have better capacitor technology these days, so with enough capacitance, the modules content might be protected for days instead of hours. RE: question about quad memory module - ElectroDuende - 04-18-2016 01:54 PM (04-18-2016 01:04 PM)TASP Wrote: Oh thanks! Better technology, maybe, but quality... :-( In the last year I have repaired the following items, all of them with the same very failure: - LG LCD TV, 4 years old - Samsung LCD computer monitor, 3 years old - Sony Micro stereo system, 7 years old - Unknown brand DTV receiver, 2 years old Guess what? Yes, all of them had faulty electrolytic capacitors in the power source section, and all of them were repaired for just some euro cents in spares, while the official repairing services were, either requesting hundreds of euros, or deeming the devices as non-repairable. RE: question about quad memory module - Diego Diaz - 04-19-2016 03:04 AM Hi all, This old post may give you some hints on how to proceed with the capacitor. http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv020.cgi?read=207685 Cheers from Canary Islands. Diego. |
