Serial cable for WP-34S : few questions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Serial cable for WP-34S : few questions (/thread-3040.html) |
Serial cable for WP-34S : few questions - Francois Lanciault - 02-08-2015 04:49 PM Hi, I am building my own serial cable for the WP-34S and I have a few question: I know the ERASE button should short the +3V pad and the erase pad. What about the reset button? For what I could deduced it needs to short the reset pad with the ground pad. Can someone confirm ? The Tx pad means Tx at calculator level and should be connected to the Rx pin of the host computer. True ? Same for the Rx pad on the calculator; should be connected to the Tx pin on the computer ? Thank you! François RE: Serial cable for WP-34S : few questions - Marcus von Cube - 02-08-2015 05:20 PM (02-08-2015 04:49 PM)Francois Lanciault Wrote: I know the ERASE button should short the +3V pad and the erase pad. What about the reset button? For what I could deduced it needs to short the reset pad with the ground pad. Can someone confirm ? I can confirm. (02-08-2015 04:49 PM)Francois Lanciault Wrote: The Tx pad means Tx at calculator level and should be connected to the Rx pin of the host computer. True ? Also confirmed! Be aware that the voltage level is 0-3V, not RSR232 level! The latter can kill your calculator. An FTDI USB converter chip will do nicely. RE: Serial cable for WP-34S : few questions - Francois Lanciault - 02-08-2015 06:19 PM (02-08-2015 05:20 PM)Marcus von Cube Wrote: Also confirmed! Be aware that the voltage level is 0-3V, not RSR232 level! The latter can kill your calculator. An FTDI USB converter chip will do nicely. Thank you for this information! I was just about to plug everything directly to the RS-232 port of an old PC. So I guess the "official cable" was doing the conversion from +/- 12V to the 0-3V required. I think I have a converter from RS-232 to TTL level. Does 0-5V would do or it really needs to be 0-3V max ? François RE: Serial cable for WP-34S : few questions - Francois Lanciault - 02-08-2015 06:32 PM (02-08-2015 06:19 PM)Francois Lanciault Wrote:(02-08-2015 05:20 PM)Marcus von Cube Wrote: Also confirmed! Be aware that the voltage level is 0-3V, not RSR232 level! The latter can kill your calculator. An FTDI USB converter chip will do nicely. I think it is going to be ok. I have this converter: https://www.sparkfun.com/products/8780 And I can decide what voltage it will output so I will use 3V volts. Thanks again. François RE: Serial cable for WP-34S : few questions - John Galt - 02-11-2015 04:01 AM If you don't plan on erasing your calculator repeatedly, an inexpensive (commonly available for less than $5 USD) USB to serial converter cable is all that is required. Search for a description resembling "Prolific PL2303HX USB To RS232 TTL USB To COM Serial Adapter Cable". That, and a suitable current limiting resistor for each of the Tx and Rx lines. I use 1 KOhm. Even if you erase it, doing so is a simple matter of connecting the Erase pad to power while turning it on. The erase procedure, adapted from p. 167 of the WP 34S printed Owner's Manual, is as follows:
You are now ready to flash the calculator using the MySamBa Windows program. If you are not ready to do that yet, pressing the RESET button will turn the calculator off so that it does not continue to deplete the batteries. Press ON when you are ready to flash. The reason for initially stating "if you don't plan on erasing your calculator repeatedly" is that once an HP 30b has been converted to a WP 34S, updating its software does not require erasing it again. That procedure is described on p. 171 of the printed manual, and only requires connecting the Tx and Rx pads and signal ground. You can easily hold those three conductors in your fingers, or just two conductors if you remove one battery and connect signal ground to the battery center conductor which is also ground. The calculator's onboard power is perfectly adequate for flashing, provided the batteries are relatively fresh. Flashing draws considerably less current than running some programs, and it takes about 20 seconds. Press RESET after MySamBa reports the file was successfully sent, then, disconnect your programming connections, replace the battery if you removed one, and press ON. The above was adapted from several sources who contribute to this site. Edit to add picture below.
If you are observant you will note the green and white shrink tubes do not agree with the green and white cable conductors of the cable. That's because the cable I bought did not agree with its documentation, so be sure to verify yours. [attachment=1608] |
