2015's calculator anniversary - the SR-52 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: 2015's calculator anniversary - the SR-52 (/thread-2804.html) Pages: 1 2 |
RE: 2015's calculator anniversary - the SR-52 - jebem - 02-07-2016 05:18 PM Thank you for the extra photos of your SR-52A, Etienne! Nice work of yours. That FroggySoft information is very useful too. Thanks. Concerning the card reader motor wheel outer diameter value, I'm not sure about what the correct value must be, because: - There are several revisions of the SR-52 (A thru L) and at least one SR-52A revision; - And it seems that there are different versions of the motor body as well (my specimen has a nude metallic body (dimensions published previously), while yours and FroggySoft motors appears to have a sort of plastic cover around the metal body?). On a very positive note: I managed to get an original paperback version of the "SR-52 and SR-52A Troubleshooting Guide"! Among other goodies, it contains specific information on the card reader controller variants and details the adjustment procedure for the photocoupler card sensor and motor speed. Katie was very kind to host a high resolution (300dpi) digitized copy for easy sharing among us. Thank you, Katie! RE: 2015's calculator anniversary - the SR-52 - Etienne Victoria - 02-07-2016 10:13 PM Thanks Jose and Katie for sharing the SR-52 troubleshooter ! This is the most interesting SR-52 document I've seen in years. No more fiddling around blindly with the pots to adjust the card reader :-) And the circuit schemes of the multiple variants will definitely help. The SR-52 motor pictured above indeed has a non-removable plastic case. I'll check the schematics to identify the revision nr. Etienne RE: 2015's calculator anniversary - the SR-52 - jebem - 02-26-2016 06:58 PM Another small update on my SR-52 restoration saga. 1. The failed electronics issue After swapping around the IC's from three different calculators, I managed to have one good working calculator. Once again, thank you Etienne for your "spares" supply ! As I see it, these electronic failures can be caused by over-voltage, as a result of applying energy from the external power adapter without having good Ni-Cd batteries installed (or having corroded or broken battery terminals for that matter). On top of that, most of the times the battery electrolytes leakage has spread all over the PCB components, and applying energy to the machine will not help at all. Besides that, there are a few more identified potential issues: 2.- The "flat cable" Keyboard PCA - Main PCA interconnect. This "16-wires cable" breaks easily, because it uses extremely rigid zinc alloy strips working as unifilar "wires". This results in multiple key register failures. I really am annoyed with myself, as I knew about this issue and still, due to careless handling, I manage to break a few of these brass strips. The cure is simple but delicate to implement. I'm planning to just solder the broken brass legs once I have all the other issues fixed. This will be the last procedure just before installing the PCA in the front cover. 3.- Main PCA broken/corroded zinc alloy battery contacts This is another very common issue with vintage Texas machines, mostly resulting from battery leaking corrosion. In order to make new spring lever contacts, I found an excellent German supplier at TAS, offering high quality brass sheet in thickness as thin as 0.1mm. This material can be cut with common scissors and it is easy to solder. 4.- The motor rubber driver wheel going gummy. This is a endemic issue on calculators from the 70's from any brand. As a mechanical component failure is not my area of expertise, I have been learning from good people's work published here and there concerning possible rubber wheel replacement solutions. Like Etienne's 8.2mm diameter wheel, I find that a 8mm outer diameter should be good enough to drag the magnetic card at a even speed. To test it, I ordered some silicone hose tubing from TAS. The inner diameter is 4mm and the outer diameter is 8mm. Not ideal, but very close to the required specs. I have cut a small slice of this silicone tubing and inserted it into the motor shaft. Because this motor shaft doesn't have an adjustment system to set the pressure against the pinch roller, I used some extra foam inserted between the motor body and its case, to reinforce the pressure from the original Texas foam. Using an external power supply, have applied 3Volt to the motor and inserted a previously used card. The card was dragged at uniform speed, at least from what I can see on my oscilloscope connected to the magnetic head coils. (I have these old used cards that have some data written by the previous owners, probably more than 30 years ago). The existing written data generates a stable signal with an estimate of about 6mVpp amplitude (2.1mVrms). I can't be more precise here as my old vintage oscilloscope can only resolve up to 10mV per division. More to come one of these weeks (I hope). Right now I'm quite busy on one of our datacenters in Spain with so many virtual appliances to create and validate. Customers comes first. Calculators are a hobby and shall wait. But of course the goodies found in the Cataluña restaurants like Jamón and vino tinto are really comforting me for having to work so hard. RE: 2015's calculator anniversary - the SR-52 - David Hayden - 02-27-2016 01:30 PM The SR-52 was the first programmable anything that I ever saw. A friend of my parents had one and I still remember him showing it to me while we were for dinner one night. I was completely mesmerized. He let me borrow it and I programmed a prime number finder. It's no exaggeration to say that the SR-52 and that night led to my career as a computer programmer. RE: 2015's calculator anniversary - the SR-52 - Gene - 02-27-2016 01:59 PM If so, then this was one of the best accomplishments of the SR-52. :-) RE: 2015's calculator anniversary - the SR-52 - brouhaha - 03-24-2023 05:27 PM (02-01-2016 11:07 PM)jebem Wrote: Here is the motor schematic drawing. Dimensions in mm. Thanks for sharing your diagram. I am a but confused. Is the inner diameter of the roller 2.0 mm or 4.3 mm? RE: 2015's calculator anniversary - the SR-52 - garyjm - 04-30-2023 07:15 PM I've been away from my calculator collecting passion for years now and have just recently returned :-). I remember when the SR-52 first came out. I was blown away! Somehow, I was able to afford a brand new one. I sold it long ago and sure wish I has it back! Currently I own five of them. One is in poor condition and not working and the other four work fine. Of course, none of the card readers work. The SR-52 is one of my favorite all time programmable calculators. I also own a lot of TI-58's and TI-59's, not to mention a lot of HP programmables. Long live the Texas Instruments SR-52!!! RE: 2015's calculator anniversary - the SR-52 - Kees Bouw - 04-30-2023 10:57 PM (04-30-2023 07:15 PM)garyjm Wrote: Of course, none of the card readers work. Why not fix them? It is relatively easy to do, much easier than fixing the HP card readers (which are too complicated and less reliable). RE: 2015's calculator anniversary - the SR-52 - John Garza (3665) - 05-02-2023 04:08 AM Maybe if you tell me where to get off-the-shelf replacements for the drive rollers on the 52, I'll agree with that last statement. HP mechanicals are more involved, but that's trivial time compared to fashioning a roller by hand. And O-rings and model airplane tubing are readily available to make replacement rollers for the HPs. -J RE: 2015's calculator anniversary - the SR-52 - garyjm - 05-03-2023 12:42 AM Kees Bouw: I do not have any formal electrical or mechanical education/background so would not be able to repair these. My background in in software. I will leave the repairs up to the experts in this area. I know the TI-59 card readers are easier to repair than the SR-52 as far as the gummy wheel. You can find the TI-59 gummy wheel repair kits on Ebay. RE: 2015's calculator anniversary - the SR-52 - Nicoverduin - 04-18-2024 08:11 AM (01-29-2016 08:06 PM)jebem Wrote:I am redesigning a new keyboard PCB voor the SR-52. However if I get it correct the order of connections is (seen from the right starting at the top: 1 = R1 2 = R2 3 = R3 4 = R4 5 = R5 6 = C1 7 = C2 8 = C3 9 = C4 10 = C5 11 = C6 12 = C7 13 = C8 14 = C9 15 = C10 16 = R6 is this correct anyone? |
