(41C) Simple elevator simulator program - acser - 04-12-2023 07:24 PM
Hello all,
This is a simple, single car elevator simulator program for the HP 41. There is only a button column in the elevator, but no elevator call buttons on floors (yet ).
Constructive ideas for simplification are most welcome (I am pretty sure there are plenty of opportunities).
Thanks in advance
A
(P.S.: I am amazed how simple and well thought out the HP-41 FOCAL programming language is and now see why RPL has never been able to fully displace it. It also amazes me how easy it is to write a modern Python or other high level programming language program which will be larger than 671 bytes, the size of this one.)
Registers:
R00: Number of floors 1-20, only up to 20 floors are supported now
R01-R20 These are the individual buttons. 1 if button was pressed and is lit, 0:otherwise
R21: Direction of travel for elevator car: 0=Stopped, 1=Down, 2=Up
R22: Current floor indicator
R23: Are there any buttons pressed and lit on the the elevator button column LIT? 0 = Not lit, 1 = Lit
R24: Lowest floor pressed/lit (MINBT) value
R25: Highest floor pressed/lit (MAXBT) value
01 LBL "EL"
02 1
03 STO 22
04 "FLRS=?"
05 PROMPT
06 STO 00
07 LBL "LOOP"
08 -1
09 "BTN=?"
10 AVIEW
11 PSE
12 X<0?
13 GTO "SKIP"
14 1
15 STO IND Y
16 LBL "SKIP"
17 XEQ "LIT?"
18 STO 23
19 "LIT="
20 ARCL X
21 AVIEW
22 XEQ "MAXBT"
23 RDN
24 STO 25
25 "MAXBT="
26 ARCL X
27 AVIEW
28 PSE
29 XEQ "MINBT"
30 RDN
31 STO 24
32 "MINBT="
33 ARCL X
34 AVIEW
35 PSE
36 RCL 23
37 X<=0?
38 GTO "NOTLIT"
39 RCL 21
40 X!=0?
41 GTO "NOTST"
42 RCL 22
43 RCL 24
44 X>Y?
45 XEQ "SETUP"
46 RCL 22
47 RCL 25
48 X<Y?
49 XEQ "SETDN"
50 LBL "NOTST"
51 RCL 23
52 X=0?
53 XEQ "SETST"
54 LBL "NOTLIT"
55 RCL 23
56 1
57 X!=Y?
58 GTO "STAY"
59 RCL 21
60 X=0?
61 GTO "STAY"
62 RCL IND 22
63 X=0?
64 GTO "STAY"
65 0
66 STO IND 22
67 "O/C="
68 RCL 22
69 ARCL X
70 AVIEW
71 XEQ "LIT?"
72 STO 23
73 XEQ "MAXBT"
74 RDN
75 STO 25
76 XEQ "MINBT"
77 RDN
78 STO 24
79 RCL 23
80 X=0?
81 XEQ "SETST"
82 RCL 23
83 X=0?
84 GTO "STAY"
85 RCL 22
86 RCL 25
87 X<Y?
88 XEQ "SETDN"
89 RCL 22
90 RCL 24
91 X>Y?
92 XEQ "SETUP"
93 LBL "STAY"
94 RCL 24
95 RCL 25
96 X!=Y?
97 GTO "MVEL"
98 RCL 22
99 X!=Y?
100 GTO "MVEL"
101 0
102 STO IND 22
103 LBL "MVEL"
104 XEQ "LIT?"
105 STO 23
106 RCL 23
107 X=0?
108 GTO "ENDMVEL"
109 2
110 RCL 21
111 X!=Y?
112 GTO "DN?"
113 1
114 ST+ 22
115 LBL "DN?"
116 RCL 21
117 1
118 X!=Y?
119 GTO "ENDMVEL"
120 1
121 ST- 22
122 LBL "ENDMVEL"
123 "END CFL="
124 RCL 22
125 ARCL X
126 AVIEW
127 PSE
128 GTO "LOOP"
129 LBL "LIT?"
130 RCL 00
131 LBL "L1"
132 RCL IND X
133 X>0?
134 RTN
135 RDN
136 1
137 -
138 X>0?
139 GTO "L1"
140 0
141 RTN
142 LBL "MINBT"
143 0
144 LBL "I1"
145 1
146 +
147 RCL IND X
148 X>0?
149 RTN
150 RDN
151 RCL 00
152 X<>Y
153 X<=Y?
154 GTO "I1"
155 0
156 RTN
157 LBL "MAXBT"
158 RCL 00
159 LBL "A1"
160 RCL IND X
161 X>0?
162 RTN
163 RDN
164 1
165 -
166 X>0?
167 GTO "A1"
168 0
169 RTN
170 LBL "SETST"
171 0
172 STO 21
173 RTN
174 LBL "SETDN"
175 1
176 STO 21
177 RTN
178 LBL "SETUP"
179 2
180 STO 21
181 RTN
182 END
