HP-41CX CPU broad install to HP-41C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-41CX CPU broad install to HP-41C (/thread-19552.html) |
HP-41CX CPU broad install to HP-41C - zixingcheche - 02-13-2023 04:42 AM Hi all Same as title, can I change the 41C’s CPU broad with 41CX’s CPU broad? I have working 41c & 41cx, but enter key of 41cx has some issue. I want to install the 41CX’s cpu into 41c. Any issues? Risk? Thanks! Thanks! RE: HP-41CX CPU broad install to HP-41C - ThomasF - 02-13-2023 07:49 AM Hi, No, that is not possible, since the 41CX has a totally different internal design. See e.g. the pictures here of the internals of the 41C and 41CX: HP41C Museum The C and CV had a separate board for the CPU and memory, but CX used both components on the keyboard PCB and a totally different board. Switching between C and CV is normally no problem, but the CX is a different beast ... Cheers, Thomas RE: HP-41CX CPU broad install to HP-41C - Harald - 02-13-2023 09:15 AM (02-13-2023 07:49 AM)ThomasF Wrote: The C and CV had a separate board for the CPU and memory, but CX used both components on the keyboard PCB and a totally different board. That depends. If the CX is a Halfnut, that is true, but if it is a Fullnut, then the boards can be interchanged. There might be a display driver incompatibility in some cases, but I can't remember. Maybe someone with more knowlage on the 41 can enlighten us. You can tell if the CX is a Fullnut or a Halfnut by looking at the display. The Halfnut has rounded display corners. Cheers, Harald RE: HP-41CX CPU broad install to HP-41C - ThomasF - 02-13-2023 09:39 AM (02-13-2023 09:15 AM)Harald Wrote:(02-13-2023 07:49 AM)ThomasF Wrote: The C and CV had a separate board for the CPU and memory, but CX used both components on the keyboard PCB and a totally different board. Thanks Harald! Yes, that it true - I was just thinking of the Halfnut CX, but there also exists Fullnut CX, and then it might work! Have swapped a lot of C and CV boards, but never had a CX board to swap ... Cheers, Thomas RE: HP-41CX CPU broad install to HP-41C - zixingcheche - 02-13-2023 01:34 PM Hi Thomas, Harald, Thank you for your reply! My 41cx is halfnut, and 41c is fullnut. So, the cpu broad can not be exchanged. Understand, thanks! BR, Bai |
